ROC-RK3399-PC-PLUS - Custom Android 10 Firmware
This has the normal tablet layout with navigation bar, top notifications.
Just install a different launcher if you don’t want a tv launcher.
v1.2
Add Sleep to Power Off menu
Add Kodi, Nova Video Player, Night Video Player, SmartYoutubeTV auto frame-rate switching support.
Update Magisk Root app and boot image
v1.1 - 2020-09-29
Add TvSettings
  • Add TvSettings launcher icon so it can be used in any browser not just Leanback ones
  • Add Connect button to Wifi Settings in TvSettings so it can be clicked with a ir remote
  • Fix Screensaver options in TvSettings to work after screen timeout
    Set DayDream as default screensaver.
    (After a few minutes the screensaver will kick in, if not connected to the internet, the desktop will turn black since it can’t download screensaver pictures to display, if not using internet, change to a different screensaver that doesn’t use data)
    Click 7 times on About Device - Build Info to enable developer Options, under Developer Options see new settings:
  • Add Go to Recovery
  • Add Go to Maskrom Mode
  • Add Flash partition images(useful for flashing boot, recovery images)
Updated to rk10 SDK
New Circular Bootanimation
Remove battery icons
Animation speedup for faster UI
Density changed to 240(better for 1080p displays)
Spoof ethernet as a wifi connection
(Can play games like Asphalt that only works on wifi(phones) with an ethernet connection now))
Add-blocker(improve browsing experience with 1000’s of ads removed)
Add some preinstall apps(Kodi, Nova, SmartYoutubeTV, MiXplorer etc.)
Webview updated to latest version
Dark Mode by default(apps will display with dark colors that support it)
Fix Home button not working with airmouse remotes
10-bit H264 Video Playback support added, works in Kodi
Fix Youtube freezing problem with VP9 codec videos
Mouse support for browsing in web-browsers
(Hold in DPAD_CENTER button and drag airmouse pointer up or down to browse like on a PC using a mouse scroll wheel)
Make System partition writable
Magisk adb support
Update video codecs
Add hdmi CEC support
Fix some apps to display in horizontal mode instead of being rotated 90 degrees
Set RkTvLauncher as default launcher
  • Fix different launchers to use Recent apps screen.
    Double press Home button to view recent apps
    (Scroll all the way left to click clear all recent apps button)
    Remove LED blinking wit ir remote
    Changed Wif to 13 channelsAdd Exfat Filesystem support
    Removed root and added Magisk Root
    Add HD Audio passthourg support - Use Kodi
    Add OpenGAPPS
    Add Google Voice search(Need an airmouse with voice button to use eg. G10,G20,G30 airmouse remotes)
Download Link:
https://mega.nz/file/kjgQFKAb#N-QZ5wqLDOuV4kw9pesScoX1dTV5OklUDhCFmK7Iiak
Flash with AndroidTool v2.71
(EraseFlash then Upgrade)
Hello lonewolf31, nice custom firmware. I am just starting out on building my own custom firmware of android 10 of this device and kind of lost. I am wondering if you know of any tutorials on what I can edit a custom firmware like changing boot animation and the firefly splash screen. Also, I am wondering how you installed the google play store. Any pointers to tutorials will be greatly appreciated.
Thanks
This is my favorite point: Animation speedup for faster UI klondike solitaire
The custom Android 10 firmware for ROC-RK3399-PC-PLUS is designed to optimize performance, stability, and compatibility with various peripherals. It supports advanced features like multi-display, hardware acceleration, and improved system security, making it ideal for embedded systems, industrial applications for Minecraft Mod APK, and developers seeking a stable, customizable Android platform for this board.
To achieve success in drive mad 3, players must master speed control and precision driving, as even the slightest miscalculation can lead to crashes and setbacks in their quest to conquer challenging tracks.
The attention to detail is impressive—from the added HDMI CEC support and UI performance tweaks, to thoughtful touches like spoofing Ethernet as Wi-Fi for game compatibility Survival Race
Your ability to connect with readers through relatable stories and practical advice is truly commendable. Baldi’s Basics Plus
LunaHarris Posted at 5/31/2025 17:22
Your ability to connect with readers through relatable stories and practical advice is truly commend …
Get ready to pass your CMQ-OE exam with confidence using verified and updated study materials. Each question is crafted by industry experts to ensure accuracy and real exam relevance. Practicing with CMQ-OE Dumps helps you master core topics, improve problem-solving skills, and build exam confidence. Trust VALID4SURE for reliable, high-quality resources that guarantee success and make your certification journey smooth and effective.
This article really resonated with me, thank you for sharing! Here are the New-Jersey-Real-Estate-Salesperson Latest version materials, free of charge—best of luck!
Your article is absolutely stunning, I’m so grateful for your share! Sharing the Valid LEED-AP-Homes exam discount voucher exam that helped me with my career advancement and raise—it’s free for all today. Best of luck on your professional journey!
The article changed the way I think. The New PCA exam preparation system helped me secure a promotion and raise. Now it’s free for all. Hope your promotion is right around the corner!
