Kodi - HD Audio Passthrough Setup
Setup HD Audio Passthrough Support on ROC-RK3399-PC-PLUS
Need to use Custom Android 10 firmware, any one of the 2 posted by me in the forum.
Go to Settings - Sound
Decode & Bitstream
Select HDMI Bitstream
Open Kodi
Go to Settings - System
Enable Expert Settings at the bottom Left
Go to Audio
Scroll down and enable the
‘Allow Passthrough option’
Select all the audio codecs your avr supports,
but keep ‘Enable Dolby Digital(AC3) Transcoding’ disabled unless you only use a tv or SPDIF that only supports AC3
Refer to this guide for more detailed settings
https://kodi.wiki/view/Audio_quickstart_guide
You will need an AVR Receiver to play movies with DTS-HD, True-HD, Dolby Digital, DTS-HD-MA sound etc.
Amazon or a local audio shop should have them.
Make sure to also get 5.1 or 7.1 speakers if buying an AVR seperately and not as a complete package.
You connect your ROC-RK3399-PC-PLUS device with an HDMI cable to it and then another HDMI cable from the AVR to your tv.
https://www.amazon.com/4k-hdr-receiver/s?k=4k+hdr+receiver
SC-100Jの認定を取得するのが簡単ではないことが心配な場合。 SC-100J試験の質問は、お客様のニーズを満たすことができます。一度SC-100J試験資料を使用すれば、時間の浪費を心配する必要はありません。高い効率が私たちの大きな利点です。 SC-100J学習教材の練習と統合に20〜30時間を費やすだけで、良い結果が得られます。長年の開発プラクティスの後、SC-100Jテストトレントは絶対に最高です。 SC-100J試験の資料を選択すると、より良い未来を受け入れることができます。
This article has helped me understand many complex concepts, and I’ve gained a lot. I was promoted and received a raise with the help of the Valid visual CCDM cert exam. Now it’s available for free to all. Best wishes for your promotions!
Your article is astonishing, I truly appreciate you sharing it! Elevate your career with the free Latest SPP exam questions vce test questions—key to promotions and raises!
What a captivating article, I truly appreciate your sharing it. Enhance your IT expertise by downloading free Reliable test NP-Con-102 simulator fee. Wishing you all the best!
Liking this instantly, it’s that good! I earned my promotion and salary increase with the Valid FCSS_LED_AR-7.6 test topics. Now, it’s free for everyone. Wishing you all early promotions!
