Armbian and LibreELEC for rk3288
Versions of ArmbianTV and Libreelec.
Download links for new versions are now located here.
Dir rk3288
https://disk.yandex.ru/d/fRZwre9HDgAKHw?w=1
https://users.armbian.com/balbes150/
https://mega.nz/#F!j9QSDQSQ!6WpasOlbZYIInfw6yo4phQ
Using ArmbianTV.
  1. Download,
  2. Unpack,
  3. burn the resulting image to the SD card.
  4. Connect the SD card and turn on the power.
Launch LE
New image Libreelec (unoficcicial)
For rk3288, I release special images LE , there is no need to change anything, the system works immediately after writing to the SD card. All this works with almost all hardware (LAN WiFi HDMI sound) without additional settings.
dir rk3288 \ armv7 (name image rk3288)
https://yadi.sk/d/8vNYuuxynz1L0w?w=1
A prerequisite for starting - you must first erase the u-boot on the eMMC. This can be done using the USB tools, or you can use a special Multitool image created by Jock at this link. Please note DO NOT use Mulltitoo to install the system in eMMC, this will create a serious problem.
https://forum.armbian.com/topic/ … 8-tv-box-boards-q8/
I checked the installation of ArmbianTV in eMMC with the standard armbian-config utility. Everything works. The system is installed in eMMC and normally starts from eMMC. After installing Armbian in eMMC. I checked the launch of Libreeelc from a USB flash drive. Everything starts perfectly and works with USB and SD cards. Thus, you can easily use different systems by simply connecting the media to the desired system. You can also install Libreelec in eMMC. :slight_smile:
Ver 20210409 ArmbianTV and Libreelec
Ver ArmbianTV 20210505 kernel 5.10.34
LibreELEC ver 20210505 kernel 5.10.34
Ver kernel 5.10.37
Armbian and Libreelec kernel 5.10.42
Armbian and Libreelec kernel 5.10.43
add image Hirsute
ver 20210721 kernel 5.10.52
LibreELEC ver 20210907 kernel 5.14
I’m in awe of this article, thank you for sharing it. I’m giving you access to the Construction-Manager latest test simulator online exam that played a role in my promotion and salary increase. It’s free today—best wishes for your career!
Thank you for the article, it really broadened my outlook. The Latest AZ-400 dumps free download exam questions are available for free—your ticket to a promotion and salary increase!
This article is a great source of inspiration, thank you! Enhance your IT expertise and get free MS-900 reliable practice questions book. Wishing you all the best!
