OV13850摄像头问题。
从官方淘宝网站购买 OV13850摄像头模块 按照MIPI CSI 摄像头配置完成后 进入系统 打开Camera 无错误弹出, 但是摄像预览区域为黑色 摄像头贴纸已经去掉 发现串口Dug 有以下log 麻烦各位看看 是什么问题。 线已经插拔试过几次了
[ 91.051132] Enter::rk29_hw_params----52
[ 91.056124] Enter:rk29_hw_params, 86,rate=44100
[ 91.060995] Enter:rk29_hw_params, 104,LRCK=64
[ 93.380530] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ hal.ver
[ 93.388396] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ trace
[ 93.396008] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ camboard.ver
[ 93.404327] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ libisp.ver
[ 93.412450] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ isi.ver
[ 93.648264] binder: release 143:475transaction 23610 in, still active
[ 93.654829] binder: send failed reply fortransaction 23610 to 1265:1265
[ 93.859608] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ hal.ver
[ 93.867395] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ trace
[ 93.874988] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ camboard.ver
[ 93.883206] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ libisp.ver
[ 93.891210] init: sys_prop: permission denieduid:1000 name:sys_graphic.cam_ isi.ver
[ 93.902666] D1:camsys_mipiphy_clkin_cb(29):camsys_marvin mipi phy clk in tur n on
[ 93.910072] D1:camsys_mipiphy_clkin_cb(29):camsys_marvin mipi phy clk in tur n on
[ 93.917427] D1:camsys_open(710):camsys_marvin(ed8fc510) is opened!
[ 93.923679] D1:camsys_extdev_register(226):Get RK30_PIN2_PB6(78) gpio(active : 0) for dev_id 0x2000000 success!
[ 93.933646] D1:camsys_extdev_register(226):Get RK30_PIN2_PB7(79) gpio(active : 0) for dev_id 0x2000000 success!
[ 93.943584] D1:camsys_extdev_register(226):Get RK30_PIN0_PB3(11) gpio(active : 1) for dev_id 0x2000000 success!
[ 93.953545] rockchip_gpio_set:GPIO7-13 level= 1
[ 93.958081]rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 93.963938]rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 93.970627]rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpi o7-13 to output,data=0x207600,result=0x207600
[ 93.981483] D1:camsys_mrv_iomux_cb(90):marvin pinctrl select: isp_mipi_fl
[ 93.988246] D1:camsys_extdev_register(248):Extdev(dev_id: 0x2000000) registe r success
[ 94.001087] D1:camsys_mrv_clkin_cb(344):camsys_marvin clock(f: 210000000 Hz) in turn on
[ 94.009070] D1:camsys_rk3288_cfg(49):Isp_SoftRst: 1
[ 94.014047] D1:camsys_rk3288_cfg(49):Isp_SoftRst: 0
[ 94.018966] D1:camsys_mrv_clkout_cb(379):camsys_marvin clock out(rate: 24000 000Hz) turn on
[ 94.028251] D1:camsys_sysctl_extdev(326):Sysctl 11 success, gpio(11) set 1
[ 94.036152] D1:camsys_sysctl_extdev(330):Sysctl 8 success, gpio(79) set 1
[ 94.043986] D1:camsys_sysctl_extdev(330):Sysctl 7 success, gpio(78) set 1
[ 94.054029] E:camsys_i2c_write(77): i2c writedev(addr:0x20) failed!
[ 94.061550] E:camsys_i2c_write(77): i2c writedev(addr:0x6c) failed!
[ 94.067889] D1:camsys_sysctl_extdev(326):Sysctl 7 success, gpio(78) set 0
[ 94.074691] D1:camsys_sysctl_extdev(326):Sysctl 8 success, gpio(79) set 0
[ 94.081486] D1:camsys_sysctl_extdev(330):Sysctl 11 success, gpio(11) set 0
[ 94.089439] D1:camsys_mrv_clkin_cb(361):camsys_marvin clock in turn off
[ 94.096055] D1:camsys_mrv_clkout_cb(391):camsys_marvin clock out turn off
[ 94.104912] D1:camsys_extdev_deregister(308):Extdev(dev_id: 0x2000000) is de register success
[ 94.113335] D1:camsys_irq_disconnect(635):All thread disconnect camsys_marvi n irq success!
[ 94.121605] D1:camsys_mipiphy_clkin_cb(31):camsys_marvin mipi phy clk in tur n off
[ 94.129071] D1:camsys_mipiphy_clkin_cb(31):camsys_marvin mipi phy clk in tur n off
[ 94.136552] D1:camsys_release(734):camsys_marvin(ed8fc510) is closed
[ 94.143448] D1:camsys_mipiphy_clkin_cb(29):camsys_marvin mipi phy clk in tur n on
[ 94.150859] D1:camsys_mipiphy_clkin_cb(29):camsys_marvin mipi phy clk in tur n on
[ 94.158257] D1:camsys_open(710):camsys_marvin(ed8fc510) is opened!
[ 94.164474] D1:camsys_mrv_iomux_cb(90):marvin pinctrl select: isp_dvp10bit
[ 94.171531] D1:camsys_extdev_register(248):Extdev(dev_id: 0x1000000) registe r success
[ 94.184384] D1:camsys_mrv_clkin_cb(344):camsys_marvin clock(f: 210000000 Hz) in turn on
[ 94.192379] D1:camsys_rk3288_cfg(49):Isp_SoftRst: 1
[ 94.197381] D1:camsys_rk3288_cfg(49):Isp_SoftRst: 0
[ 94.202305] D1:camsys_mrv_clkout_cb(379):camsys_marvin clock out(rate: 24000 000Hz) turn on
[ 94.211599] E:camsys_sysctl_extdev(333):Sysctl 11 failed, because gpio is NU LL!
[ 94.219968] E:camsys_sysctl_extdev(333):Sysctl 8 failed, because gpio is NUL L!
[ 94.228240] E:camsys_sysctl_extdev(333):Sysctl 7 failed, because gpio is NUL L!
[ 94.238713] E:camsys_i2c_write(77): i2c writedev(addr:0x60) failed!
[ 94.245033] E:camsys_sysctl_extdev(333):Sysctl 7 failed, because gpio is NUL L!
[ 94.252263] E:camsys_sysctl_extdev(333):Sysctl 8 failed, because gpio is NUL L!
[ 94.259487] E:camsys_sysctl_extdev(333):Sysctl 11 failed, because gpio is NU LL!
[ 94.267933] D1:camsys_mrv_clkin_cb(361):camsys_marvin clock in turn off
[ 94.274574] D1:camsys_mrv_clkout_cb(391):camsys_marvin clock out turn off
[ 94.283389] D1:camsys_extdev_deregister(308):Extdev(dev_id: 0x1000000) is de register success
[ 94.291805] D1:camsys_irq_disconnect(635):All thread disconnect camsys_marvi n irq success!
[ 94.300058] D1:camsys_mipiphy_clkin_cb(31):camsys_marvin mipi phy clk in tur n off
[ 94.307524] D1:camsys_mipiphy_clkin_cb(31):camsys_marvin mipi phy clk in tur n off
[ 94.314996] D1:camsys_release(734):camsys_marvin(ed8fc510) is closed
[ 94.322012] D1:camsys_mipiphy_clkin_cb(29):camsys_marvin mipi phy clk in tur n on
[ 94.329418] D1:camsys_mipiphy_clkin_cb(29):camsys_marvin mipi phy clk in tur n on
[ 94.336831] D1:camsys_open(710):camsys_marvin(ed8fc510) is opened!
[ 94.343118] rockchip_gpio_set:GPIO7-13 level= 0
[ 94.347670]rockchip_gpio_direction_output:set GPIO7-13 level 0
[ 94.353535]rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 94.360221]rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpi o7-13 to output,data=0x207600,result=0x207600
[ 94.371146] D1:camsys_mrv_iomux_cb(90):marvin pinctrl select: isp_mipi_fl
[ 94.377949]rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 94.384843]_rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function= isp_pin, type=3
[ 94.393171]rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 94.399610] _rockchip_pinconf_set:GPIO-7 13data=0xc000000,type=3
[ 94.405647] D1:camsys_extdev_register(248):Extdev(dev_id: 0x2000000) registe r success
[ 94.418489] D1:camsys_mrv_clkin_cb(344):camsys_marvin clock(f: 210000000 Hz) in turn on
[ 94.426480] D1:camsys_rk3288_cfg(49):Isp_SoftRst: 1
[ 94.431492] D1:camsys_rk3288_cfg(49):Isp_SoftRst: 0
[ 94.436414] D1:camsys_mrv_clkout_cb(379):camsys_marvin clock out(rate: 24000 000Hz) turn on
[ 94.445735] E:camsys_sysctl_extdev(333):Sysctl 11 failed, because gpio is NU LL!
[ 94.454099] E:camsys_sysctl_extdev(333):Sysctl 8 failed, because gpio is NUL L!
[ 94.462390] E:camsys_sysctl_extdev(333):Sysctl 7 failed, because gpio is NUL L!
[ 94.472841] E:camsys_i2c_write(77): i2c writedev(addr:0x6c) failed!
[ 94.479126] E:camsys_sysctl_extdev(333):Sysctl 7 failed, because gpio is NUL L!
[ 94.486372] E:camsys_sysctl_extdev(333):Sysctl 8 failed, because gpio is NUL L!
[ 94.493578] E:camsys_sysctl_extdev(333):Sysctl 11 failed, because gpio is NU LL!
[ 94.501953] D1:camsys_mrv_clkin_cb(361):camsys_marvin clock in turn off
[ 94.508591] D1:camsys_mrv_clkout_cb(391):camsys_marvin clock out turn off
[ 94.517487] D1:camsys_extdev_deregister(308):Extdev(dev_id: 0x2000000) is de register success
[ 94.525907] D1:camsys_irq_disconnect(635):All thread disconnect camsys_marvi n irq success!
[ 94.534172] D1:camsys_mipiphy_clkin_cb(31):camsys_marvin mipi phy clk in tur n off
[ 94.541652] D1:camsys_mipiphy_clkin_cb(31):camsys_marvin mipi phy clk in tur n off
[ 94.549114] D1:camsys_release(734):camsys_marvin(ed8fc510) is closed
[ 36.478653] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 36.486097] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 36.493495] D1:camsys_open(710): camsys_marvin(ee377210) is opened!
[ 36.500350] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 420000000 Hz) in turn on
[ 36.508327] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 36.513416] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 36.518319] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 36.523578] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 36.530526] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 36.536325] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 36.543345] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 36.550537] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 36.558397] E:camsys_sysctl_extdev(333): Sysctl 9 failed, because gpio is NULL!
[ 36.565675] E:camsys_sysctl_extdev(333): Sysctl 10 failed, because gpio is NULL!
[ 36.573102] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 36.580144] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 36.587143] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 36.595033] E:camsys_sysctl_extdev(333): Sysctl 9 failed, because gpio is NULL!
[ 36.602296] E:camsys_sysctl_extdev(333): Sysctl 10 failed, because gpio is NULL!
[ 36.609651] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 36.617998] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 36.625023] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 36.631969] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 36.639868] E:camsys_sysctl_extdev(333): Sysctl 9 failed, because gpio is NULL!
[ 36.647134] E:camsys_sysctl_extdev(333): Sysctl 10 failed, because gpio is NULL!
[ 36.869907] D1:camsys_mrv_iommu_cb(276): map fd 60 ,client fd 58
[ 36.869907]
[ 36.877390] rk_iommu ff914000.isp_mmu: (isp_mmu) Enabled
[ 36.929418] D1:camsys_mrv_iommu_cb(276): map fd 61 ,client fd 58
[ 36.929418]
[ 36.936875] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 36.975216] D1:camsys_mrv_iommu_cb(276): map fd 62 ,client fd 58
[ 36.975216]
[ 36.982664] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 37.020635] D1:camsys_mrv_iommu_cb(276): map fd 63 ,client fd 58
[ 37.020635]
[ 37.028041] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 37.040837] D1:camsys_rk3288_mipihpy_cfg(108): mipi phy 1 standby!
[ 37.046960] W:camsys_phy_ops(449): mipiphy->phy_index(-1271932684) != extdev->phy.info.mipi.phy_index(1)!
[ 37.056598] D1:camsys_rk3288_mipihpy_cfg(218): mipi phy(1) turn on(lane: 0x3 bit_rate: 600Mbps)
[ 37.154613] init: sys_prop: permission denied uid:10019 name:sys.gmali.version
[ 37.232266] init: sys_prop: permission denied uid:10019 name:sys.glibgui
[ 37.245447] D1:camsys_irq_connect(513): Thread(pid: 1176) connect camsys_marvin irq success! mis: 0x5c4 icr: 0x5c8
[ 37.255877] D1:camsys_irq_connect(513): Thread(pid: 1177) connect camsys_marvin irq success! mis: 0x1500 icr: 0x1504
再试一次的log
用附件替换掉hardware/rk29/camera/SiliconImage/isi/drv/OV13850/source/OV13850_tables.c试试
OV13850_tables.zip (6.88 KB)
客服给过了 替换 make firefly-k3288.img 刷入 kernel 还是一样的log 但是用5.1的固件 就可以的
不是刷kernel,这个的摄像头驱动是在上层的
嗯 好的 我试试看 多谢你了
全部编译后 烧写 正常了 多谢了 :handshake
楼主,我也有这个问题,摄像头预览区域一片黑,但是我的串口没有相关错误打印,我不知道什么原因,有什么修改建议吗?
检查mclk
多谢楼主分享!!!!!!!!!!!!!!!!
为什么不能下载啊 大神们
我也遇到这个问题了
k3399_firefly_mid:/ $ dmesg | grep "camsys"
[    4.014447] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.014636] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.024607] gpio-54 (camsys_gpio): gpiod_request: status -16
[    4.024842] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[    4.035756] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.036140] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.050776] gpio-54 (camsys_gpio): gpiod_request: status -16
[    4.064115] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.064347] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.077937] gpio-54 (camsys_gpio): gpiod_request: status -16
[    4.078059] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[    4.091082] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.091280] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.122188] E:camsys_i2c_write(84): i2c write dev(addr:0x78) failed!,err = -6
[    4.152699] E:camsys_i2c_write(84): i2c write dev(addr:0x5a) failed!,err = -6
[    4.208352] gpio-54 (camsys_gpio): gpiod_request: status -16
[    4.219265] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.219519] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.230059] gpio-54 (camsys_gpio): gpiod_request: status -16
[    4.230188] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[    4.241042] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.241227] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.252153] gpio-54 (camsys_gpio): gpiod_request: status -16
[    4.265743] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.266130] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.281092] gpio-54 (camsys_gpio): gpiod_request: status -16
[    4.282042] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[    4.296068] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[    4.296467] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[    4.326844] E:camsys_i2c_write(84): i2c write dev(addr:0x78) failed!,err = -6
[    4.355940] E:camsys_i2c_write(84): i2c write dev(addr:0x5a) failed!,err = -6
用的firefly8.1的sdk,sensor是ov13850,摄像头没有图像。想问题一下我这个是什么情况呢???
大佬,已经解决了吗?
wfjdemmye 发表于 2019-11-25 22:40
我也遇到这个问题了
用的firefly8.1的sdk,sensor是ov13850,摄像头没有图像。想问题一下我这个是什么情 …
你这个I2C都没通,估计是power on ,power off, reset脚没有配置对。确认一下啊IO引脚是不是配对先
楼主好!
我的ov13850日志里记录:
ov13850 1-0010: driver version : 00.01.01
ov13850 1-0010: could not get module information!
ov13850 1-0010: Detected ov00d850 sensor, revision 0xb1
ov13850 2-0010: driver version : 00.01.01
ov13850 2-0010: could not get module information!
ov13850 2-0010: Unexpected sensor id(000000), ret(-5)
后面部分(2-0010)是怎么回事呢,我的摄像头能打开显示图像,不过在分辨率高的情况下打开后关闭容易出现卡死问题,与上面的日志有什么关系吗?
感谢
