Hi Sirs,
In Linux Kernel driver, the driver don’t support PCIe L1.1 and L1.2.
Could you please provide the sample code?
And I have check the TRM, the L1sub Status FSM don’t have any description about the status.
Please provide the details register description.
Thanks
In the Chapter 18 PCIe Controller of Rockchip RK3568 TRM Part2 V1.1-20210301.pdf, all the descriptions of PCIe are already available.
Maybe you need to look at these entries: PCIE_CLIENT_POWER_CON, PCIE_CLIENT_POWER_STATUS.
时间的蝴蝶 Posted at 11/22/2021 10:38
In theChapter 18 PCIe ControllerofRockchip RK3568 TRM Part2 V1.1-20210301.pdf, all the descri …
Hi Sirs,
I have check the TRM. And Enable The RC and DUT L1.2.
And check the l1sub status, the status is 3.
[0x0300] 0x00230313 CLIENT_LTSSM_STATUS
[22:20] [ RW] pm_current_data_rate = 0x2
[ 17] [ RW] rdlh_link_up = 0x1
[ 16] [ RW] smlh_link_up = 0x1
[10:08] [ RW] l1sub_state = 0x3
[05:00] [ RW] smlh_ltssm_state = 0x13
[0x0014] 0x00000133 CLIENT_INTR_STATUS_PMC
[ 8] [ W1C] pm_dstate_update_int = 0x1
[ 7] [ W1C] linkst_out_l0s_int = 0x0
[ 6] [ RO] linkst_out_l2_int = 0x0
[ 5] [ W1C] linkst_out_l1_int = 0x1
[ 4] [ W1C] linkst_out_l1sub_int = 0x1
[ 3] [ W1C] linkst_in_l0s_int = 0x0
[ 2] [ W1C] linkst_in_l2_int = 0x0
[ 1] [ W1C] linkst_in_l1_int = 0x1
[ 0] [ W1C] linkst_in_l1sub_int = 0x1
[0x002c] 0x00000008 CLIENT_POWER_CON
[31:16] [ WO] write_enable = 0x0
[ 13] [ W1C] clk_req_n_con = 0x0
[ 12] [ W1C] clk_req_n_bypass = 0x0
[11:10] [ RW] p2_cpm_disable = 0x0
[ 9] [ RW] app_clk_pm_en = 0x0
[ 8] [ RW] sys_aux_pwr_det = 0x0
[ 6] [ RW] app_l1sub_disable = 0x0
[ 5] [ RW] app_xfer_pending = 0x0
[ 4] [ RW] app_req_exit_l1 = 0x0
[ 3] [ RW] app_ready_entr_l23 = 0x1
[ 2] [ RW] app_req_entr_l1 = 0x0
[ 1] [ RW] app_pm_xmt_pme = 0x0
[ 0] [ RW] app_clk_req_n = 0x0
I have try to set the clkreq to bypass mode. And set the clkreq to tri-state. But the l1sub status is not correct.
Please help to provide the way to configure the PCIe ASPM.
Thanks,
Die Produkte von EchteFrage werden den Kandidaten nicht nur helfen, die Cisco 300-835 Zertifizierrungsprüfung zu bestehen, sondern Ihnen auch einen einjährigen kostenlosen Update-Service bieten. Sie wird den Kunden die neuesten Cisco 300-835 Prüfungsmaterialien so schnell wie möglich liefern, so dass sich die Kunden über die Prüfungsinformationen zur Cisco 300-835 Zertifizierung informieren können. Deshalb ist EchteFrage eine erstklassige Website. Außerdem ist der Service hier auch ausgezeichnet.
I appreciate your article, it really gave me a new perspective. The rich resources in MS-102 reliable exam vce are provided at no cost to enhance your understanding.
I’m really inspired by the article, thanks a lot for sharing! This is the CTAL-TAE latest test camp file exam that helped me get ahead with a promotion and raise. It’s free today—wishing you success in your career!
