Docker on RK3566 ubuntu 20.04
I am trying to install docker on my RK3566. I’ve been trying to get this working for weeks. I can’t seem to do it, so I hope to find help here. I am now running the latest firmware ubuntu 20.04
This is the result after sudo dockerd:
INFO[2021-11-09T12:50:08.951270122Z] Starting up
INFO[2021-11-09T12:50:08.953969629Z] detected 127.0.0.53 nameserver, assuming systemd-resolved, so using resolv.conf: /run/systemd/resolve/resolv.conf
INFO[2021-11-09T12:50:08.956234531Z] parsed scheme: “unix” module=grpc
INFO[2021-11-09T12:50:08.956366079Z] scheme “unix” not registered, fallback to default scheme module=grpc
INFO[2021-11-09T12:50:08.956478376Z] ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 }] } module=grpc
INFO[2021-11-09T12:50:08.956549546Z] ClientConn switching balancer to “pick_first” module=grpc
INFO[2021-11-09T12:50:08.960274020Z] parsed scheme: “unix” module=grpc
INFO[2021-11-09T12:50:08.960383109Z] scheme “unix” not registered, fallback to default scheme module=grpc
INFO[2021-11-09T12:50:08.960465946Z] ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 }] } module=grpc
INFO[2021-11-09T12:50:08.960513490Z] ClientConn switching balancer to “pick_first” module=grpc
INFO[2021-11-09T12:50:09.022254757Z] [graphdriver] using prior storage driver: overlay2
WARN[2021-11-09T12:50:09.027864073Z] Your kernel does not support cgroup memory limit
WARN[2021-11-09T12:50:09.027959452Z] Your kernel does not support CPU realtime scheduler
WARN[2021-11-09T12:50:09.027992995Z] Your kernel does not support cgroup blkio weight
WARN[2021-11-09T12:50:09.028024497Z] Your kernel does not support cgroup blkio weight_device
WARN[2021-11-09T12:50:09.028054540Z] Your kernel does not support cgroup blkio throttle.read_bps_device
WARN[2021-11-09T12:50:09.028085750Z] Your kernel does not support cgroup blkio throttle.write_bps_device
WARN[2021-11-09T12:50:09.028115793Z] Your kernel does not support cgroup blkio throttle.read_iops_device
WARN[2021-11-09T12:50:09.028146128Z] Your kernel does not support cgroup blkio throttle.write_iops_device
WARN[2021-11-09T12:50:09.028175879Z] Unable to find pids cgroup in mounts
INFO[2021-11-09T12:50:09.028838287Z] Loading containers: start.
WARN[2021-11-09T12:50:09.035265768Z] Running modprobe bridge br_netfilter failed with message: modprobe: WARNING: Module bridge not found in directory /lib/modules/4.19.193
modprobe: WARNING: Module br_netfilter not found in directory /lib/modules/4.19.193
, error: exit status 1
WARN[2021-11-09T12:50:09.238487739Z] Could not load necessary modules for Conntrack: Running modprobe nf_conntrack failed with message: modprobe: WARNING: Module nf_conntrack not found in directory /lib/modules/4.19.193, error: exit status 1
INFO[2021-11-09T12:50:09.239232400Z] Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address
INFO[2021-11-09T12:50:09.302080888Z] stopping event stream following graceful shutdown error=“” module=libcontainerd namespace=moby
failed to start daemon: Error initializing network controller: Error creating default “bridge” network: Failed to program NAT chain: Failed to inject DOCKER in PREROUTING chain: iptables failed: iptables --wai
Try it with Station M2 firmware.
https://www.stationpc.com/
Tnx for the reply,
But I get the same result. It seems that kernel modules are missing . I have to do something with modprobe and need the kernel modules but can’t find them anywhere. Am unfortunately a layman in linux land. I’m afraid I’ll have to go back to a raspberry PI.
adriaanvn Posted at 11/21/2021 01:14
Tnx for the reply,
But I get the same result. It seems that kernel modules are missing . I have to …
We will check it.
Tnx for the reply,
Have you installed docker according to the tutorial? https://docs.docker.com/engine/install/ubuntu/
root@firefly:~# systemctl status docker
��● docker.service-Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2021-11-22 03:14:41 UTC; 6s ago
TriggeredBy: ��● docker.socket
Docs: https://docs.docker.com
Main PID: 667 (dockerd)
Tasks: 9
Memory: 95.1M
CGroup: /system.slice/docker.service
��└��─667 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
root@firefly:~# lsmod
Module Size Used by
ipt_MASQUERADE 16384 1
nf_conntrack_netlink 40960 0
nfnetlink 16384 2 nf_conntrack_netlink
xfrm_user 32768 1
xfrm_algo 16384 1 xfrm_user
iptable_nat 16384 1
nf_nat_ipv4 16384 2 ipt_MASQUERADE,iptable_nat
nf_nat 49152 1 nf_nat_ipv4
br_netfilter 24576 0
bridge 143360 1 br_netfilter
stp 16384 1 bridge
Everything seems normal. Did you make any other changes? What was your specific operation and where did the abnormality occur?
Thans for the reply. This gives hope that it can work. I have tried several installations of docker. To be clear i have installed the firmware again, from there i have follow the instructions in the link you have send. This is the result (last steps):
firefly@firefly:~$ sudo apt-get install docker-ce docker-ce-cli containerd.io
Reading package lists… Done
Building dependency tree
The following additional packages will be installed:
apparmor docker-ce-rootless-extras git git-man liberror-perl pigz
slirp4netns
Suggested packages:
apparmor-profiles-extra apparmor-utils cgroupfs-mount | cgroup-lite
gettext-base git-daemon-run | git-daemon-sysvinit git-doc git-el
git-email git-gui gitk gitweb git-cvs git-mediawiki git-svn
The following NEW packages will be installed:
apparmor containerd.io docker-ce docker-ce-cli docker-ce-rootless-extras
git git-man liberror-perl pigz slirp4netns
0 upgraded, 10 newly installed, 0 to remove and 109 not upgraded.
Need to get 78.5 MB of archives.
After this operation, 372 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://download.docker.com/linux/ubuntu focal/stable arm64 containerd.io arm64 1.4.12-1 [16.8 MB]
Get:2 http://mirrors.aliyun.com/ubuntu-ports focal/universe arm64 pigz arm64 2.4-1 [47.8 kB]
Get:3 https://download.docker.com/linux/ubuntu focal/stable arm64 docker-ce-cli arm64 5:20.10.11~3-0~ubuntu-focal [34.7 MB]
Get:4 http://mirrors.aliyun.com/ubuntu-ports focal-updates/main arm64 apparmor arm64 2.13.3-7ubuntu5.1 [455 kB]
Get:5 http://mirrors.aliyun.com/ubuntu-ports focal/main arm64 liberror-perl all 0.17029-1 [26.5 kB]
Get:6 http://mirrors.aliyun.com/ubuntu-ports focal-updates/main arm64 git-man all 1:2.25.1-1ubuntu3.2 [884 kB]
Get:7 https://download.docker.com/linux/ubuntu focal/stable arm64 docker-ce arm64 5:20.10.11~3-0~ubuntu-focal [14.0 MB]
Get:8 http://mirrors.aliyun.com/ubuntu-ports focal-updates/main arm64 git arm64 1:2.25.1-1ubuntu3.2 [4344 kB]
Get:9 https://download.docker.com/linux/ubuntu focal/stable arm64 docker-ce-rootless-extras arm64 5:20.10.11~3-0~ubuntu-focal [7175 kB]
Get:10 http://mirrors.aliyun.com/ubuntu-ports focal/universe arm64 slirp4netns arm64 0.4.3-1 [69.2 kB]
Fetched 78.5 MB in 4s (21.7 MB/s)
Preconfiguring packages …
Selecting previously unselected package pigz.
(Reading database … 151937 files and directories currently installed.)
Preparing to unpack …/0-pigz_2.4-1_arm64.deb …
Unpacking pigz (2.4-1) …
Selecting previously unselected package apparmor.
Preparing to unpack …/1-apparmor_2.13.3-7ubuntu5.1_arm64.deb …
Unpacking apparmor (2.13.3-7ubuntu5.1) …
Selecting previously unselected package containerd.io.
Preparing to unpack …/2-containerd.io_1.4.12-1_arm64.deb …
Unpacking containerd.io (1.4.12-1) …
Selecting previously unselected package docker-ce-cli.
Preparing to unpack …/3-docker-ce-cli_5%3a20.10.11~3-0~ubuntu-focal_arm64.deb …
Unpacking docker-ce-cli (5:20.10.11~3-0~ubuntu-focal) …
Selecting previously unselected package docker-ce.
Preparing to unpack …/4-docker-ce_5%3a20.10.11~3-0~ubuntu-focal_arm64.deb …
Unpacking docker-ce (5:20.10.11~3-0~ubuntu-focal) …
Selecting previously unselected package docker-ce-rootless-extras.
Preparing to unpack …/5-docker-ce-rootless-extras_5%3a20.10.11~3-0~ubuntu-focal_arm64.deb …
Unpacking docker-ce-rootless-extras (5:20.10.11~3-0~ubuntu-focal) …
Selecting previously unselected package liberror-perl.
Preparing to unpack …/6-liberror-perl_0.17029-1_all.deb …
Unpacking liberror-perl (0.17029-1) …
Selecting previously unselected package git-man.
Preparing to unpack …/7-git-man_1%3a2.25.1-1ubuntu3.2_all.deb …
Unpacking git-man (1:2.25.1-1ubuntu3.2) …
Selecting previously unselected package git.
Preparing to unpack …/8-git_1%3a2.25.1-1ubuntu3.2_arm64.deb …
Unpacking git (1:2.25.1-1ubuntu3.2) …
Selecting previously unselected package slirp4netns.
Preparing to unpack …/9-slirp4netns_0.4.3-1_arm64.deb …
Unpacking slirp4netns (0.4.3-1) …
Setting up slirp4netns (0.4.3-1) …
Setting up liberror-perl (0.17029-1) …
Setting up apparmor (2.13.3-7ubuntu5.1) …
Created symlink /etc/systemd/system/sysinit.target.wants/apparmor.service → /lib/systemd/system/apparmor.service.
Setting up containerd.io (1.4.12-1) …
Created symlink /etc/systemd/system/multi-user.target.wants/containerd.service → /lib/systemd/system/containerd.service.
Setting up docker-ce-cli (5:20.10.11~3-0~ubuntu-focal) …
Setting up pigz (2.4-1) …
Setting up git-man (1:2.25.1-1ubuntu3.2) …
Setting up docker-ce-rootless-extras (5:20.10.11~3-0~ubuntu-focal) …
Setting up docker-ce (5:20.10.11~3-0~ubuntu-focal) …
Created symlink /etc/systemd/system/multi-user.target.wants/docker.service → /lib/systemd/system/docker.service.
Created symlink /etc/systemd/system/sockets.target.wants/docker.socket → /lib/systemd/system/docker.socket.
Job for docker.service failed because the control process exited with error code.
See “systemctl status docker.service” and “journalctl -xe” for details.
invoke-rc.d: initscript docker, action “start” failed.
● docker.service - Docker Application Container Engine
Active: activating (auto-restart) (Result: exit-code) since Mon 2021-11-22 09:45:14 UTC; 21ms ago
TriggeredBy: ● docker.socket
Process: 7696 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 7696 (code=exited, status=1/FAILURE)
dpkg: error processing package docker-ce (–configure):
installed docker-ce package post-installation script subprocess returned error exit status 1
Setting up git (1:2.25.1-1ubuntu3.2) …
Processing triggers for systemd (245.4-4ubuntu4.0firefly1) …
docker-ce
E: Sub-process /usr/bin/dpkg returned an error code (1)
firefly@firefly:~$ sudo docker run hello-world
docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
See ‘docker run --help’.
firefly@firefly:~$
firefly@firefly:~$ systemctl status docker
Active: failed (Result: exit-code) since Mon 2021-11-22 10:03:36 UTC; 44s ago
Process: 1089 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAIL>
Main PID: 1089 (code=exited, status=1/FAILURE)
Nov 22 10:03:36 firefly systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
Nov 22 10:03:36 firefly systemd[1]: Stopped Docker Application Container Engine.
Nov 22 10:03:36 firefly systemd[1]: docker.service: Start request repeated too quickly.
Nov 22 10:03:36 firefly systemd[1]: docker.service: Failed with result ‘exit-code’.
Nov 22 10:03:36 firefly systemd[1]: Failed to start Docker Application Container Engine.
firefly@firefly:/lib/systemd$ sudo dockerd
INFO[2021-11-22T10:08:45.329972187Z] Starting up
INFO[2021-11-22T10:08:45.332549370Z] detected 127.0.0.53 nameserver, assuming systemd-resolved, so using resolv.conf: /run/systemd/resolve/resolv.conf
INFO[2021-11-22T10:08:45.334581425Z] parsed scheme: “unix” module=grpc
INFO[2021-11-22T10:08:45.334715592Z] scheme “unix” not registered, fallback to default scheme module=grpc
INFO[2021-11-22T10:08:45.334805426Z] ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 }] } module=grpc
INFO[2021-11-22T10:08:45.334849760Z] ClientConn switching balancer to “pick_first” module=grpc
INFO[2021-11-22T10:08:45.338750826Z] parsed scheme: “unix” module=grpc
INFO[2021-11-22T10:08:45.338863118Z] scheme “unix” not registered, fallback to default scheme module=grpc
INFO[2021-11-22T10:08:45.338982994Z] ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock 0 }] } module=grpc
INFO[2021-11-22T10:08:45.339034328Z] ClientConn switching balancer to “pick_first” module=grpc
INFO[2021-11-22T10:08:45.395058890Z] [graphdriver] using prior storage driver: overlay2
WARN[2021-11-22T10:08:45.400113214Z] Your kernel does not support cgroup memory limit
WARN[2021-11-22T10:08:45.400203339Z] Your kernel does not support CPU realtime scheduler
WARN[2021-11-22T10:08:45.400228131Z] Your kernel does not support cgroup blkio weight
WARN[2021-11-22T10:08:45.400251465Z] Your kernel does not support cgroup blkio weight_device
WARN[2021-11-22T10:08:45.400287048Z] Your kernel does not support cgroup blkio throttle.read_bps_device
WARN[2021-11-22T10:08:45.400317674Z] Your kernel does not support cgroup blkio throttle.write_bps_device
WARN[2021-11-22T10:08:45.400341299Z] Your kernel does not support cgroup blkio throttle.read_iops_device
WARN[2021-11-22T10:08:45.400370174Z] Your kernel does not support cgroup blkio throttle.write_iops_device
WARN[2021-11-22T10:08:45.400400216Z] Unable to find pids cgroup in mounts
INFO[2021-11-22T10:08:45.401045095Z] Loading containers: start.
WARN[2021-11-22T10:08:45.406576588Z] Running modprobe bridge br_netfilter failed with message: modprobe: WARNING: Module bridge not found in directory /lib/modules/4.19.193
WARN[2021-11-22T10:08:45.584499046Z] Could not load necessary modules for Conntrack: Running modprobe nf_conntrack failed with message: modprobe: WARNING: Module nf_conntrack not found in directory /lib/modules/4.19.193, error: exit status 1
INFO[2021-11-22T10:08:45.585364719Z] Default bridge (docker0) is assigned with an IP address 172.17.0.0/16. Daemon option --bip can be used to set a preferred IP address
INFO[2021-11-22T10:08:45.649108580Z] stopping event stream following graceful shutdown error=“” module=libcontainerd namespace=moby
failed to start daemon: Error initializing network controller: Error creating default “bridge” network: Failed to program NAT chain: Failed to inject DOCKER in PREROUTING chain: iptables failed: iptables --wait -t nat -A PREROUTING -m addrtype --dst-type LOCAL -j DOCKER: iptables v1.8.4 (legacy): Couldn’t load match addrtype':No such file or directory Try iptables -h’ or ‘iptables --help’ for more information.
(exit status 2)
The command you use returns this result
sudo /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
INFO[2021-11-22T11:14:03.381513264Z] Starting up
failed to load listeners: no sockets found via socket activation: make sure the service was started by systemd
adriaanvn Posted at 11/22/2021 19:09
Thans for the reply. This gives hope that it can work. I have tried several installations of docker …
I am afraid we are not using the same firmware, I am using this Station_M2_Ubuntu_20.04_GPT_20211109_0910.img.
Please check your system:
ls /lib/modules/
cat /proc/version
Thanks it works,
I saw that the modules directory was not present on my system. Just to be on the safe side, I reinstalled the system with the firmware again with the version you provided and from the link you gave in your first reply. Had allready downloaded this and also thought I was running it. Now I don’t get any error messages. And docker version shows that version 20.20.11 is running. Apparently I flashed the wrong img file. Thank you again very much.
adriaanvn Posted at 11/24/2021 18:45
Thanks it works,
I saw that the modules directory was not present on my system. Just to be on the …
Hi Firefly Support,
I’m having the same issue with installing Docker/ Ubuntu 20.04 LTS.
Board RK-3566 PC with firmware ROC-RK3566-PC-UBUNTU20.04-GPT-20211216-1031.
This firmware is missing some modules, which prevent the correct installation of Docker.
Example:
Is there a possibility of adding these modules to this firmware?
Thanks
Great content; my like is locked in. 250-583 latest practice questions was key to my career and salary growth. Now, I’m sharing it for free with you!
