I’m testing the Ubuntu 20.04 image (ROC-RK3566-PC-UBUNTU20.04-GPT-20211012-1456), and am having trouble getting the WiFi network adapter to work. It detects the device as wlan0, but I can’t seem to get it connecting. I’ve tried setting up a wpa_supplicant.conf file, but that didn’t get picked up. With nmtui, there is no wireless network. Adding it manually doesn’t seem to work either. Any assistance would be appreciated.
Can you provide some logs? Like dmesg or syslog when you try to connect wifi
Make sure your device has an antenna.
Check /vendor/etc/firmware/, which file is nvram.txt link to?
For example: If your device is using AP6255(you can see it on the wifi module of your device)
then the nvram.txt should link to nvram_ap6255.txt, otherwise, wlan0 can’t detect any AP
use command to connect to AP:
nmcli dev wifi connect APName password 123456
The content is top-notch, liking it right now. Upgrade your IT skills with free New H11-861_V4.0 associate level exam. Wishing you all the best!
I’m absolutely loving this content, giving it a like. The CTFL-UT reliable study guide questions are the key to success—get them for free and unlock your promotion!
This article is superb, thank you for sharing such a masterpiece. Here comes the EMEA-Advanced-Support new braindumps sheet exam! Wish me luck and success!
