I am a novice to this B2B technology (basic DIY/RaspberryPi/Linux knowledge), so forgive me questions.
Driver, RKdevInfoWrite installation and use is OK (e.g. readingLAN MAC is successfull).
RK3308B is connected to the network and visible in DHCP table.
First Question: What is the default system installed on the RK3308?
Second question, Attempts to connect:
2. Attempt to login using Putty (SSH): connection refused
3. Attempt to login using WinScp (SFTP) not successful
4. Attempt to login using WinScp (FTP)
‘Prompting for credentials: username’
tried several options (root, firefly, rockchip, …)
in all cases: ‘target machine actively refused connection’.
Can somebody provide the login information?
Third question,
Attempt to use SD card to boot
Attempt to write a linux distribution with BalenaEtcher gives error: ‘not a bootable image’, Etcher doesn’t not allow to write.
ImageWriter does write the image, but no changes in the behavior, I suspect the SD is indeed not bootable.
How can we write a bootable SD-card?
We probably will have more questions.
Thanks for the support,
L.
Hi,
Some progress, successfully installed ‘ROC-RK3308B-CC-PLUS Ubuntu Desktop Firmware’. The hardware is visible on LAN under a new name: ‘firefly’. Now stuck on username and password…
Used the obvious ones… root, firefly, rockchip…
Thanks,
L.
Melden Sie sich an EMC D-ECS-DY-23 Zertifizierungsprüfung an? Haben Sie vor zu vielen Prüfungsunterlagen Kopfschmerzen? Wir ZertFragen können diese Probleme auflösen und wir sind die Website, an der Sie glauben können. Wenn Sie unsere Unterlagen zur EMC D-ECS-DY-23 Prüfung benutzen, können Sie sehr leicht die EMC D-ECS-DY-23 Prüfung bestehen. Sie sollen keine Zeit an den Unterlagen verschwenden, die vielleicht keinen Sinn haben. Probieren Sie bitte den Service von ZertFragen.
Depois de comparar vários casinos online, percebi que poucos eram realmente simples. A pesquisa acabou me levando até roulettino casino, então resolvi conferir. O site apresenta bônus de boas-vindas, campanhas voltadas para Portugal e condições que parecem mais claras. Achei positivo porque não promete coisas fora da realidade.
I can’t thank you enough for your article, it really made an impression. The D-MSS-DS-23 test forum exam questions are the foundation for your career growth—get them for free!
This is such a brilliant article, thank you for sharing your perspective. I’m facing the Valid XSOAR-Engineer test answers exam soon. Hope I pass with ease!
I’m amazed by the depth of your article, thank you for sharing! Get access to the Valid GH-300 exam questions exam that helped me earn a promotion and pay raise—today, it’s free for all! Good luck on your career path.
