Problems with new iHC-3308GW
Hello. I have got new device. I set up my PC as DHCP client. Directly connected to the device’s port LAN2. PC does not get IP address. Documentation says “press recovery button”, but there’s no button named recovery on the body, and this does not show this button. I guess it is the one marked arrow up. I press it, nothing happens. Ok, this one having “recovery” word on the picture. I am not Chinese thus only guess two Chinese characters mean “button”. On some other page (can not find it any more!) I have seen to press recovery button and turn on device holding the button - for factory reset, and red LED will not turn on. This does not work - LED turns on as I do not hold the button, and nothing changes.
Is my device faulty?
Is it possible to get specialist support for this device?
P.S. I get “错误:请点击滑块验证按钮,验证通过后再提交!” lucky it is copyable to clipboard, but there’s no slider on the screen!
Hello, what is your firmware used in iHC3308GW?Ubuntu18 or Buildroot?
Factory default is buildroot system. Did you upgrade it to OpenWRT system?
This is where recovery button is :
I unboxed the device and unable to connect to it. Unable to find what and how should I proceed.
As a result I need OpenWrt in the box, but as I can not connect to the device, result is not achievable.
The picture you shared shows headphone input, not recovery button.
哦,对不起,我的错误。
I still unable to make this device working. Connected through serial port, but do not see the serial port setting for 1500000 baud. Nothing in the terminal at any speeds. Adapter does not show connect signal.
How to reach support for this device?
Did you try “adb shell” ?
https://wiki.t-firefly.com/en/Core-3308Y/adb_introduction.html#commonly-used-adb-commands
This new device I have is a brick. Does not respond to the serial port or LAN.
It was confirmed it does not have any image (even U-boot).
It is not possible for that!
Try this https://wiki.t-firefly.com/en/Core-3308Y/maskrom_mode.html , if you device actually be a brick.
Is the power light off?
That piece of writing really expanded my mind. The Reliable C_S4PM2_2507 exam camp questions exam is approaching. Hope I ace it!
I’m amazed by this article, thank you for sharing it. C-OCM-2503 free learning cram helped me achieve a promotion and salary boost. Get it for free today!
KaoGuTi提供的培訓工具包含關於Network Appliance NS0-005認證考試的學習資料及類比訓練題,更重要的是還會給出跟考試很接近的練習題和答案。選擇KaoGuTi可以保證你可以在短時間內學習及加強IT專業方面的知識,還可以以高分數通過Network Appliance NS0-005的認證考試。
