Hello,
Can anybody from linux guru can help me with build errors ?
Millions thanks in advance
[code]/usr/bin/make -j3 -C /home/user/firefly/buildroot/output/rockchip_rk3566/build/rkwifibt-1.0.0/src/CY_WL_API/ CC=/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-gcc
make[2]: Nothing to be done for ‘all’.
PATH=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin:/home/user/firefly/buildroot/output/rockchip_rk3566/host/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” AR=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-ar” AS=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-as” LD=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-ld” NM=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-nm” CC=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-gcc” GCC=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-gcc” CPP=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-cpp” CXX=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-g++” FC=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-gfortran” F77=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-gfortran” RANLIB=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-ranlib” READELF=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-readelf” STRIP=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-strip” OBJCOPY=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-objcopy” OBJDUMP=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-objdump” AR_FOR_BUILD=“/usr/bin/ar” AS_FOR_BUILD=“/usr/bin/as” CC_FOR_BUILD=“/usr/bin/gcc” GCC_FOR_BUILD=“/usr/bin/gcc” CXX_FOR_BUILD=“/usr/bin/g++” LD_FOR_BUILD=“/usr/bin/ld” CPPFLAGS_FOR_BUILD=“-I/home/user/firefly/buildroot/output/rockchip_rk3566/host/include” CFLAGS_FOR_BUILD=“-O2 -I/home/user/firefly/buildroot/output/rockchip_rk3566/host/include” CXXFLAGS_FOR_BUILD=“-O2 -I/home/user/firefly/buildroot/output/rockchip_rk3566/host/include” LDFLAGS_FOR_BUILD=“-L/home/user/firefly/buildroot/output/rockchip_rk3566/host/lib -Wl,-rpath,/home/user/firefly/buildroot/output/rockchip_rk3566/host/lib” FCFLAGS_FOR_BUILD=“” DEFAULT_ASSEMBLER=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-as” DEFAULT_LINKER=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/aarch64-buildroot-linux-gnu-ld” CPPFLAGS=“-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64” CFLAGS=“-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Os " CXXFLAGS=”-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Os " LDFLAGS=“” FCFLAGS=" -Os " FFLAGS=" -Os " PKG_CONFIG=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/bin/pkg-config” STAGING_DIR=“/home/user/firefly/buildroot/output/rockchip_rk3566/host/aarch64-buildroot-linux-gnu/sysroot” INTLTOOL_PERL=/usr/bin/perl /usr/bin/make -j3 -C /home/user/firefly/buildroot/../kernel/ M=/home/user/firefly/buildroot/output/rockchip_rk3566/build/rkwifibt-1.0.0/realtek/bluetooth_uart_driver ARCH=arm
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (
