How can I solve this problem?
firefly@firefly:~/rknn-toolkit-1.3.0/examples/darknet/yolov3$ python3 test.py
yolov3.weight exist.
→ Loading model
done
→ Building model
done
→ Export RKNN model
done
→ init runtime
E Only support ntb mode on ARM64 platform. But can not find device with ntb mode.
E Catch exception when init runtime!
E Traceback (most recent call last):
E File “rknn/api/rknn_base.py”, line 963, in rknn.api.rknn_base.RKNNBase.init_runtime
E File “rknn/api/rknn_runtime.py”, line 161, in rknn.api.rknn_runtime.RKNNRuntime.init
E File “rknn/api/rknn_platform_utils.py”, line 268, in rknn.api.rknn_platform_utils.start_ntp_or_adb
E Exception: Init runtime environment failed!
E Current device id is: None
E Devices connected:
E
init runtime failed.
I solved it with an update.
apt-get install firefly-3399pronpu-driver
The article gave me so many new ideas. With Latest AB-Abdomen study plan, you get access to valuable content at no cost, designed for your benefit.
CertJukenを通じて最新のFortinetのFCP_FAC_AD-6.5試験の問題と解答早めにを持てて、弊社の問題集があればきっと君の強い力になります。
This article is so uplifting, thank you for sharing it! I’m heading into the Valid 300-220 exam dumps exam soon – wish me success!
This article is truly an outstanding work, and I’ve benefited greatly from it. Good luck on your exam! Here are the free Practice CEDP Exam study materials.
Thank you for your article, it truly broadened my mind and vision. The New SAFe-RTE exam experience exam is upon me. Hope I pass it with ease!
