eth0/eth1 interfaces don't work
We are using RK3568 with our carrier board (custom board) and factory carrier board (devboard).
For network we are using the same chip RTL8211F-CG as on devboard.
As result, eth0/eth1 interfaces don’t work. We can’t understand what is a reason.
Linux log files for both carrier boards:
https://drive.google.com/drive/folders/1NSIV9fVs46fIZl5xVFDJeWoZRdWsY0YS?usp=sharing
Hi, we suggest that you can check the Ethernet-related circuit on the board first. Thanks.
From the information, the PHY device, RTL8211F-CG, is not recognized.
You need to rule out hardware problems, whether the power supply, reset, and clock of the RTL8211F-CG are normal.
This will provide some help. https://gitlab.com/firefly-linux/docs/-/tree/rk356x/firefly/Common/GMAC
Оther four custom boards have an another error with DMA:
[ 10.334142] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[ 10.334168] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 10.334176] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[ 10.443937] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[ 10.443963] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[ 10.443971] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
[ 10.577682] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[ 10.577708] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 10.577715] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[ 10.687930] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[ 10.687966] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[ 10.687973] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
[ 10.824357] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[ 10.824383] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 10.824390] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[ 10.934578] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
[ 10.934606] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_hw_setup: DMA engine initialization failed
[ 10.934635] rk_gmac-dwmac fe2a0000.ethernet eth1: stmmac_open: Hw setup failed
valeriy.simakov Posted at 3/25/2022 15:23
[ 10.334142] rk_gmac-dwmac fe010000.e …
That’s usually a problem with the operating clock.
Thank you for your article, it was a real revelation to me. Get ahead in your career with the free C-S4CPB-2508 latest test topics pdf test questions—your key to promotion!
DumpTOP Salesforce Revenue-Cloud-Consultant-Accredited-Professional 덤프는Salesforce Revenue-Cloud-Consultant-Accredited-Professional실제시험 변화의 기반에서 스케줄에 따라 업데이트 합니다. 만일 테스트에 어떤 변화가 생긴다면 될수록 2일간의 근무일 안에Salesforce Revenue-Cloud-Consultant-Accredited-Professional 덤프를 업데이트 하여 고객들이 테스트에 성공적으로 합격 할 수 있도록 업데이트 된 버전을 구매후 서비스로 제공해드립니다. 업데이트할수 없는 상황이라면 다른 적중율 좋은 덤프로 바꿔드리거나 덤프비용을 환불해드립니다.
KaoGuTi為每個需要通過CrowdStrike的CCCS-203b考試認證的考生提供了一個明確和卓越的解決方案,我們為你提供CrowdStrike的CCCS-203b考試詳細的問題及答案, 我們團隊的IT專家是最有經驗和資格的,我們的考試測試題及答案幾乎和真實得考試一樣,做到這樣的確很了不起,更重要的是我們KaoGuTi網站在全球範圍內執行這項考試培訓通過率最大。
This article is a real eye-opener, thanks for sharing! Wish me success as I prepare for the Valid PDD study plan exam!
The process should be as smooth as the date itself. The ability to Call Girl Book online with ease is a sign of a good agency. MumbaiFunGirl offers a seamless booking interface. As the most trusted and reliable agency, we ensure your reservation is confirmed instantly, with the girl arriving exactly as promised.
rickboy203 Posted at 1/23/2026 10:16
This article is a real eye-opener, thanks for sharing! Wish me success as I prepare for the Valid PD …
The process should be as smooth as the date itself. The ability to Mumbai Call Girl with ease is a sign of a good agency. MumbaiFunGirl offers a seamless booking interface. As the most trusted and reliable agency, we ensure your reservation is confirmed instantly, with the girl arriving exactly as promised.
