[Core-PX30-JD4] Can not boot from SD card
Hi,
I have a Core-PX30-JD4 with the industrial mainboard MB-JD4-RK3328 & PX30 , so the story is i am trying to boot the OS from SD card rather than flash directly to eMMC with the new firmware I just have build by using buildroot rootfs exactly like the tutorial in here link to have an .img file in rockdev/pack . But when i use etcher to flash the firmware to the SD card, it popped up a warning message that it can not find the partition table, I can see that there are 2 parameter.txt and package-file, but the problem is that i do not know how to apply those to flash with dd or etcher.
So if there is anyone know the answer or even any hint please help?
Also, I have another question that in other board like beagle bone we have a button to hold to make the board boot from sd card rather than eMMC, is there a similar to do so in this board or we have to do some command in uboot command line to make it boot from SDcard?
Thanks you for any helps,
Tu
Hi, because it is different from the general firmware format, you cannot use the tool Etcher to make a boot card.
You can use the tool ‘SD_Firmware_Tool.exe’ to make a boot card, select the ‘SD Boot’ option. Reference, https://wiki.t-firefly.com/en/Firefly-RK3399/05-upgrade_firmware_sd.html
The default boot priority of TF card is higher than eMMC. When the boot card is recognized, it will boot from the TF card.
时间的蝴蝶 Posted at 3/28/2022 16:21
Hi, because it is different from the general firmware format, you cannot use the tool Etcher to make …
Thank you for your answer. I can do it now.
I’m really thankful for your article, it left a strong impression. The New OGEA-101 study guide platform offers detailed material at no cost, aimed at assisting you.
DeutschPrüfung ist eine professionelle Webseite, die die neuesten Testaufgaben und Antworten von Salesforce Plat-Arch-203 Zertifizierungsprüfung bietet. Es ist sicherlich Ihre beste Wahl, mit unseren Lehrbüchern die Salesforce Plat-Arch-203 Prüfung vorzubereiten. DeutschPrüfung wird Ihnen helfen, in begrenzter Zeit die Plat-Arch-203 Prüfung so schnell wie möglich zu bestehen. Wenn es irgendein Qualitätsproblem von den Lehrbüchern gibt oder Wenn Sie die Plat-Arch-203 Prüfung nicht bestehen, versprechen wir Ihnen eine bedingungslose volle Rückerstattung.
