[help] How to use usb type c for display
I am using android 6.1 on firefly-rk3399 board.
The firefly-rk3399 board has HDMI and Type-C (usb 3.0,dp 1.2) ports.
Now, my board only outputs HDMI.
I want to display the screen through the Type-C (usb 3.0, dp 1.2) port.
(Even if it’s not a dual monitor, it’s good to have only Type-C output.)
Should I upgrade my Android version?
I would appreciate it if you could tell me how to solve it.
Hello, sorry for keeping you waiting. The engineer is following this. He will reply you soon.
I also want this feature, too.
EC-A3399C
Pass4Test는AZ-900시험문제가 변경되면AZ-900덤프업데이트를 시도합니다. 업데이트가능하면 바로 업데이트하여 업데이트된 최신버전을 무료로 제공해드리는데 시간은 1년동안입니다. AZ-900시험을 패스하여 자격증을 취득하고 싶은 분들은Pass4Test제품을 추천해드립니다.온라인서비스를 찾아주시면 할인해드릴게요.
N10-009J試験に参加する前に、試験を知りたい場合、弊社の公式サイトを訪問できます。そして、弊社のN10-009J試験ガイドのデモをダウンロードすることは簡単で、便利です。クリックするだけ必要からです。後、弊社のN10-009J資料はすべてN10-009J試験に関わることがわかります。N10-009J資料の全てのページはN10-009J試験に関連しています。N10-009J資料は素晴らしいものです。
That article was a real treasure trove of knowledge. Free Exam 156-836 actual tests exam papers available. Best of luck to everyone!
This article gave me new motivation, thank you for sharing! This P3O-Foundation vce files set helped me climb the career ladder and get a salary raise. Now, it’s available for free to all. Wishing you all the best in your professional growth!
312-85の学習質問は、文化レベルの種類に関係なく、さまざまなレベルのユーザーに適しています。たとえ文化レベルが高くても、312-85トレーニング資料で自分に合ったものを見つけることができます。学習方法。それで、312-85学習教材のすべてのユーザーにとって、絶好の機会であり、さまざまなタイプから選択できます。また、ますます多くの学生が312-85テストガイドを選択します。 Certified Threat Intelligence Analystの学習質問を選択してください!
Your article was truly enlightening and refreshing, thank you! Get the Latest test 1z0-809 simulations test questions for free—your key to the next level in your career!
I really appreciate your article, it opened my eyes to new possibilities. Free Certification Plat-Dev-201 dumps exam questions—good luck to everyone!
Your article truly impressed me, I’m grateful for it. Wish me luck as I’m getting ready to take the Reliable exam JN0-750 simulator free exam!
為了每位IT認證考試的考生切身利益,我們網站提供PDFExamDumps Salesforce的AP-220考試培訓資料是根據考生的需要而定做的,由我們PDFExamDumps資質深厚的IT專家專門研究出來的,他們的奮鬥結果不僅僅是為了幫助你們通過考試,而且是為了讓你們有一個更好的明天。
The article is so thought-provoking, thank you for your valuable share! The Free C-BCBDC-2505 practice test papers are now available for free. Wishing you all the best!
