Hello.
Can anybody comment on the issue regarding RGMII voltage levels?
What I mean is the schematic MB-JM3-RK3568-V11-20210412.pdf
The signals GMAC1_TXD0_M1, GMAC1_TXD1_M1 are based on the 3,3V power domain.
On the other hand the signals GMAC1_TXD2_M1, GMAC1_TXD3_M1 are based on the 1,8V power domain.
And all these four signals are wired directly to the U28 RTL8211F-CG.
As we can see the RTL8211F-CG is configured as “RGMII Power Source = 1,8V (default)”.
So, is it possible to use RGMII TX 3,3V-levels with RTL8211F-CG 1,8V powered IOs?
Solved.
Dear support (if you exist at all).
Kindly look for the mistakes in the Core-3568J Product Specification.pdf (V1.0).
It contains wrong “IO Power domain” values in the table.
sorry, the io is 1.8V. please refer to Product SpecificationV2.1
https://download.t-firefly.com/产品规格文档/核心板/Core-3568J-四核高性能AI核心板-规格书.pdf?v=1620639527
In Sprunked, players craft music using creepy sound effects, unsettling beats, and spooky character designs, creating an immersive experience that’s both thrilling and creative.
There’s something deeply satisfying about shaving off 0.01 seconds in Speed Stars. It’s a game of inches, timing, and perfect execution — and it never gets old.
RGMII employs LVTTL or LVCMOS signals, which are digital signals with low logic voltages. 3.3V, 2.5V, or 1.8V, depending on the chip architecture or FPGA/ASIC platform utilized. However, many modern systems choose 1.8V to reduce power consumption and electromagnetic interference (EMI).
Oh, RGMII voltage levels, huh? Sounds like a super fun game figuring that out! Hope the image helps others dealing with similar hardware issues. Good luck to everyone diving into these speedstarsspeedstars configurations!
Die ISTQB CTAL-TA-German Zertifizierungsprüfung ist sehr populär in IT-Industrie. Es spielt eine übergreifende Bedeutung für die Leute, die ihre Arbeitsstelle erhöhen wollen. Und es ist auch die Wahl, die Leute klar sehen können. Außerdem dadurch können Sie Ihre Fähigkeit verbessern und mehr verwendbare Technik beherrschen. Damit können Sie Ihre Arbeit besser fertigen und auch anderen Ihre Fähigkeit zeigen.
Came across this thread and it reminded me of a tool I used before for simple seat or name labeling. It’s lightweight and doesn’t require signup, might be useful for some people here:
https://thatsmyseat.online/
Thank you for your article, it’s been a real eye-opener for me. I attribute my career progress and salary increase to the Salesforce-MuleSoft-Developer-I reliable exam cram test, and today it’s available to everyone for free!
Die ISQI CPRE-FL_Syll_3.0 Zertifizierungsprüfung ist schon eine der beliebten IT-Zertifizierungsprüfungen geworden. Aber für die Prüfung braucht man viel Zeit und Energie, um die Fachkenntnisse gut zu beherrschen. Im diesem Zeitalter, wo die Zeit sehr geschätzt wird, betrachtet man Zeit wie Geld. Das Schulungsprogramm zur ISQI CPRE-FL_Syll_3.0 Zertifizierungsprüfung von Zertpruefung dauert ungefähr 20 Stunden. Dann können Sie Ihre Fachkenntnisse konsolidierern und sich gut auf die ISQI CPRE-FL_Syll_3.0 Zertifizierungsprüfung vorbereiten.
