How to do a/b OTA Update in ROC-RK3399-PC devices
Hi, Compiled the source code and created source ota.zip using the below commands,
Step 1: Compiled source code and out directory generated.
Step 2 : mkdir dist_output
Step 3 : make dist DIST_DIR=dist_output
Step 4 : ./build/tools/releasetools/ota_from_target_files dist_output/rk3399_roc_pc_plus-target_files-eng.naren.zip ota_update.zip
ota_update.zip file generated in the source code directory.
FYI :
I have unzipped the OTA.zip file but am unable to find “payload.bin”
May I know, What is the procedure to update/flash OTA.zip file into the target device.
The content is excellent, and I’m giving it a like. Free FS-Con-101 Training Kit exam papers are here. Wishing you the best of luck on your exam!
