Hey guys,
I’m playing with Station M2 (which is the same hardware as rk3566-firefly-roc-pc board) and bluetooth is not working properly for me on Armbian and ubuntu.
I’m using armbian with 5.18.0-rc4-media kernel.
dmesg reports there’s a conflict between hci uart port and serial@fdd50000, and hci socket is not available in the system, hciconfig does not show anything.
I tried recompiling .dtd with everything related to serial@fdd50000 removed, and now hciconfig does display the socket, but it is always in DOWN state.
hci0: Type: Primary Bus: UART
BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0
DOWN
RX bytes:0 acl:0 sco:0 events:0 errors:0
TX bytes:4 acl:0 sco:0 commands:1 errors:0
Dmesg also shows “[ 15.682377] Bluetooth: hci0: command 0x0c03 tx timeout”
Any idea how can this be fixed?
Bluetooth uses uart1, which will not conflict with serial@fdd50000(uart0).
Confirm which wifi-bt module is used and whether the Bluetooth firmware is loaded normally.
This repository may have the information you need. https://gitlab.com/firefly-linux/external/rkwifibt/-/tree/rk356x/firefly
时间的蝴蝶 Posted at 5/17/2022 16:10
Confirm which wifi-bt …
This is my dmesg:
===[ 12.510796] rockchip-pinctrl pinctrl: pin gpio0-17 already requested by fdd50000.serial; cannot claim for serial0-0
[ 12.510809] rockchip-pinctrl pinctrl: pin-17 (serial0-0) status -22
[ 12.510816] rockchip-pinctrl pinctrl: could not request pin 17 (gpio0-17) from group bt-enable-h on device rockchip-pinctrl
[ 12.510822] hci_uart_bcm serial0-0: Error applying setting, reverse things back
[ 12.559615] random: crng init done
[ 12.559634] random: 7 urandom warning(s) missed due to ratelimiting
[ 12.753899] cfg80211: failed to load regulatory.db
[ 12.765637] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.firefly,rk3566-roc-pc.txt failed with error -2
[ 12.765660] brcmfmac mmc2:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43455-sdio.firefly,rk3566-roc-pc.txt
[ 12.969434] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 12.980319] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
what concerns me is line 3, some gpio pin (one that enables bluetooth chip?) is allocated for uart0, according to logs. Im using armbian with rk3566-firefly-roc-pc.dtd, heres the decompiled device tree:
serial@fdd50000 {
compatible = “rockchip,rk3568-uart\0snps,dw-apb-uart”;
reg = <0x00 0xfdd50000 0x00 0x100>;
interrupts = <0x00 0x74 0x04>;
clocks = <0x1c 0x0b 0x1c 0x2c>;
clock-names = “baudclk\0apb_pclk”;
dmas = <0x24 0x00 0x24 0x01>;
dma-names = “tx\0rx”;
pinctrl-0 = <0x25>;
pinctrl-names = “default”;
reg-io-width = <0x04>;
reg-shift = <0x02>;
status = “okay”;
phandle = <0xe1>;
serial@fe650000 {
compatible = "rockchip,rk3568-uart\0snps,dw-apb-uart";
reg = <0x00 0xfe650000 0x00 0x100>;
interrupts = <0x00 0x75 0x04>;
clocks = <0x0e 0x11f 0x0e 0x11c>;
clock-names = "baudclk\0apb_pclk";
dmas = <0x24 0x02 0x24 0x03>;
dma-names = "tx\0rx";
pinctrl-0 = <0x90 0x91>;
pinctrl-names = "default";
reg-shift = <0x02>;
status = "okay";
uart-has-rtscts;
phandle = <0x10a>;
bluetooth {
compatible = "brcm,bcm43438-bt";
clocks = <0x92 0x01>;
clock-names = "lpo";
device-wake-gpios = <0x93 0x11 0x00>;
host-wake-gpios = <0x93 0x10 0x00>;
shutdown-gpios = <0x93 0x0f 0x00>;
pinctrl-0 = <0x94 0x95 0x96>;
vbat-supply = <0x23>;
vddio-supply = <0x45>;
could it be that my .dtd file is incorrect?
I checked the rkwifibt repo and it does not seem to work
# sh bt_load_broadcom_firmware</div><div>brcm_patchram_plus1: no process found
###AMPAK FW Auto detection patch version = [v1.1 20161117]##
Can't get device info: No such devic
root@os:/rkwifibt# cp: cannot stat '/data/cfg/device_info.txt': No such file or director
port --enable_hci could not be opened, error 2
The chip is AP6255
lexaguskov Posted at 5/21/2022 18:31
This is my dmesg:
===[ 12.510796] rockchip-pinctrl pinctrl: pin gpio0-17 already requested by …
Did you ever get a solution to this? Not having Bluetooth on my Ubuntu Station M2 is the single outstanding issue that keeps me from full functionality.
Any tips for disabling the serial TTY on pin for UART0 are really welcome.
— Jeremiah
HPE6-A86試験教材は、多くの人々がソフトパワーを向上させるのに役立ちました。彼らは同僚よりも効率的であるため、リーダーからより多くの注目を集めています。私たちは皆普通の専門家です。私たちは機会に値することを示すために力を示さなければなりません。 HPE6-A86練習エンジンを使用することは、体力を改善するための最も重要なステップです。バタフライ効果のように、あなたの選択の1つがあなたの人生に影響するかもしれないことを知っています。また、HPE6-A86試験の質問は、HPE6-A86試験に合格して夢のような認定を取得するための適切な試験ツールとなります。
I can’t thank you enough for your article, it truly made a mark on me. Wish me luck as I’m getting ready to take the 300-810 reliable test tips exam!
I’m really grateful for your article, it left an indelible mark. Free Reliable exam H19-413_V1.0 experience exam papers shared here. Best of luck in your exam!
No delay, just liking this awesome content. Best wishes to everyone! latest KCSA exam book test questions are now available for free.
