kernel 5.x.x :[ end Kernel panic - not syncing: VFS: Unable to mount root fs on
I intend to upgrade my system kernel on a Firefly board with RK3288W SoC.
To do this, I used the kernel found in your RockMy repository and 5.17.6 kernel mainline. I was able to build the image successfully, but for some reason the kernel can’t mount the file system and I’m not understanding why.In the old kernel that I was using (4.4.70), I don’t have this problem.
The partitions and the kernel commands line are given by the parameter.txt file, which contains the following:
PARMLFIRMWARE_VER:2.0.0
MACHINE_MODEL:rk3288
MACHINE_ID:007
MANUFACTURER:RK3288
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3288
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: GPT
CMDLINE:init=/sbin/init root=/dev/mmcblk2p7 rw rootwait console=ttyS2,115200 splash loglevel=7 acpi=off apm=off vt.global_cursor_default=0 consoleblank=0 initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00008000@0x00016000(back),0x00010000@0x0001e000(backup),0xc01000@0x0002e000(linuxroot)
It would be very helpful to find a solution to this problem.
LOGs:
kernel 5.8 (rockmyy):
U-Boot 2017.02-RK3288-06-g8adeb23-dirty (Jun 02 2017 - 17:57:28)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 816000000HZ
periph pll = 297000000HZ
ddr pll = 396000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059bc50c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059bc70c
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059cc30c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059cc50c
storage init OK!
GetParam
Load FDT from resource image.
no key node
No pmic detect.
can’t find dts node for pwm0
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
‘boot’ does not seem to be a partition nor an address
Unable to boot:boot
try to start recovery
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x00c215b0)
ramdisk @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0560d124 … OK
[ 0.000000][ T0] Booting Linux on physical CPU 0x500
[ 0.000000][ T0] Linux version 5.8.0-RockMyy32-Frosty (checho@checho-pc) (arm-linux-gnueabihf-gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1 SMP PREEMPT Mon May 16 12:24:11 -03 2022
[ 0.000000][ T0] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[ 0.000000][ T0] CPU: div instructions available: patching division code
[ 0.000000][ T0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000][ T0] OF: fdt: Machine model: Firefly-RK3288
[ 0.000000][ T0] Memory policy: Data cache writealloc
[ 0.000000][ T0] Zone ranges:
[ 0.000000][ T0] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000][ T0] Normal empty
[ 0.000000][ T0] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000][ T0] Movable zone start for each node
[ 0.000000][ T0] Early memory node ranges
[ 0.000000][ T0] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000][ T0] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000][ T0] percpu: Embedded 20 pages/cpu s51032 r8192 d22696 u81920
[ 0.000000][ T0] Built 1 zonelists, mobility grouping on. Total pages: 522752
[ 0.000000][ T0] Kernel command line: init=/sbin/init root=/dev/mmcblk2p7 rw rootwait console=ttyS2,115200 quiet splash loglevel=7 acpi=off apm=off vt.global_cursor_default=0 consoleblank=0 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00008000@0x00016000(back),0x00010000@0x0001e000(backup),0xc00800@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2017-06-02_17:57:28 SecureBootCheckOk=0
[ 0.000000][ T0] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000][ T0] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000][ T0] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000][ T0] Memory: 2050644K/2097152K available (13312K kernel code, 1419K rwdata, 7576K rodata, 1024K init, 4876K bss, 46508K reserved, 0K cma-reserved, 1310720K highmem)
[ 0.000000][ T0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000][ T0] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000][ T0] Trampoline variant of Tasks RCU enabled.
[ 0.000000][ T0] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.000000][ T0] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000][ T0] random: get_random_bytes called from start_kernel+0x578/0x7b8 with crng_init=0
[ 0.000000][ T0] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000][ T0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000005][ T0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000018][ T0] Switching to timer-based delay loop, resolution 41ns
[ 0.001152][ T0] Console: colour dummy device 80x30
[ 0.001187][ T0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.001201][ T0] pid_max: default: 32768 minimum: 301
[ 0.001304][ T0] LSM: Security Framework initializing
[ 0.001325][ T0] Yama: becoming mindful.
[ 0.001381][ T0] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001395][ T0] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002033][ T0] CPU: Testing write buffer coherency: ok
[ 0.002068][ T0] CPU0: Spectre v2: using BPIALL workaround
[ 0.002327][ T1] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.003039][ T1] Setting up static identity map for 0x100000 - 0x100060
[ 0.003179][ T1] rcu: Hierarchical SRCU implementation.
[ 0.003596][ T1] smp: Bringing up secondary CPUs …
[ 0.005328][ T0] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.005335][ T0] CPU1: Spectre v2: using BPIALL workaround
[ 0.007110][ T0] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.007116][ T0] CPU2: Spectre v2: using BPIALL workaround
[ 0.008859][ T0] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.008866][ T0] CPU3: Spectre v2: using BPIALL workaround
[ 0.008989][ T1] smp: Brought up 1 node, 4 CPUs
[ 0.009001][ T1] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.009010][ T1] CPU: All CPU(s) started in SVC mode.
[ 0.009591][ T1] devtmpfs: initialized
[ 0.018632][ T1] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.018945][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.018984][ T1] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.019226][ T1] xor: measuring software checksum speed
[ 0.028429][ T1] arm4regs : 1716.000 MB/sec
[ 0.038502][ T1] 8regs : 1324.000 MB/sec
[ 0.048577][ T1] 32regs : 1320.000 MB/sec
[ 0.048587][ T1] xor: using function: arm4regs (1716.000 MB/sec)
[ 0.048602][ T1] pinctrl core: initialized pinctrl subsystem
[ 0.049075][ T1] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.049949][ T1] NET: Registered protocol family 16
[ 0.050752][ T1] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.052190][ T1] cpuidle: using governor ladder
[ 0.052229][ T1] cpuidle: using governor menu
[ 0.053183][ T1] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.053195][ T1] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.121630][ T1] raid6: int32x8 gen() 228 MB/s
[ 0.138739][ T1] raid6: int32x8 xor() 131 MB/s
[ 0.155942][ T1] raid6: int32x4 gen() 221 MB/s
[ 0.173090][ T1] raid6: int32x4 xor() 128 MB/s
[ 0.190216][ T1] raid6: int32x2 gen() 344 MB/s
[ 0.207375][ T1] raid6: int32x2 xor() 180 MB/s
[ 0.224548][ T1] raid6: int32x1 gen() 377 MB/s
[ 0.241726][ T1] raid6: int32x1 xor() 122 MB/s
[ 0.241737][ T1] raid6: using algorithm int32x1 gen() 377 MB/s
[ 0.241768][ T1] raid6: … xor() 122 MB/s, rmw enabled
[ 0.241777][ T1] raid6: using intx1 recovery algorithm
[ 0.243750][ T1] vcc_5v: supplied by vcc_sys
[ 0.244469][ T1] vcc_host_5v: supplied by vcc_5v
[ 0.244955][ T1] vcc_otg_5v: supplied by vcc_5v
[ 0.245878][ T1] iommu: Default domain type: Translated
[ 0.247295][ T1] vgaarb: loaded
[ 0.247774][ T1] SCSI subsystem initialized
[ 0.247957][ T1] usbcore: registered new interface driver usbfs
[ 0.248067][ T1] usbcore: registered new interface driver hub
[ 0.248149][ T1] usbcore: registered new device driver usb
[ 0.248278][ T1] mc: Linux media interface: v0.10
[ 0.248310][ T1] videodev: Linux video capture interface: v2.00
[ 0.248419][ T1] pps_core: LinuxPPS API ver. 1 registered
[ 0.248430][ T1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.248449][ T1] PTP clock support registered
[ 0.248808][ T1] Advanced Linux Sound Architecture Driver Initialized.
[ 0.249370][ T1] Bluetooth: Core ver 2.22
[ 0.249411][ T1] NET: Registered protocol family 31
[ 0.249421][ T1] Bluetooth: HCI device and connection manager initialized
[ 0.249435][ T1] Bluetooth: HCI socket layer initialized
[ 0.249447][ T1] Bluetooth: L2CAP socket layer initialized
[ 0.249470][ T1] Bluetooth: SCO socket layer initialized
[ 0.250242][ T1] clocksource: Switched to clocksource arch_sys_counter
[ 1.327468][ T1] FS-Cache: Loaded
[ 1.327685][ T1] CacheFiles: Loaded
[ 1.336921][ T1] NET: Registered protocol family 2
[ 1.337553][ T1] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 12288 bytes, linear)
[ 1.337594][ T1] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.337726][ T1] TCP bind hash table entries: 8192 (order: 5, 163840 bytes, linear)
[ 1.337857][ T1] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.338210][ T1] UDP hash table entries: 512 (order: 2, 24576 bytes, linear)
[ 1.338290][ T1] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes, linear)
[ 1.338591][ T1] NET: Registered protocol family 1
[ 1.339072][ T1] RPC: Registered named UNIX socket transport module.
[ 1.339083][ T1] RPC: Registered udp transport module.
[ 1.339091][ T1] RPC: Registered tcp transport module.
[ 1.339098][ T1] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.339536][ T1] PCI: CLS 0 bytes, default 64
[ 1.340779][ T1] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 1.342694][ T1] Initialise system trusted keyrings
[ 1.342814][ T1] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ 1.349387][ T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.350266][ T1] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.350866][ T1] NFS: Registering the id_resolver key type
[ 1.350891][ T1] Key type id_resolver registered
[ 1.350901][ T1] Key type id_legacy registered
[ 1.350918][ T1] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.350933][ T1] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.352632][ T1] Key type cifs.spnego registered
[ 1.352658][ T1] Key type cifs.idmap registered
[ 1.352674][ T1] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.353034][ T1] fuse: init (API version 7.31)
[ 1.353759][ T1] JFS: nTxBlock = 8192, nTxLock = 65536
[ 1.361680][ T1] SGI XFS with security attributes, no debug enabled
[ 1.450994][ T1] NET: Registered protocol family 38
[ 1.451010][ T1] Key type asymmetric registered
[ 1.451020][ T1] Asymmetric key parser ‘x509’ registered
[ 1.451028][ T1] Asymmetric key parser ‘pkcs8’ registered
[ 1.451036][ T1] Key type pkcs7_test registered
[ 1.451169][ T1] bounce: pool size: 64 pages
[ 1.451220][ T1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 1.451280][ T1] io scheduler mq-deadline registered
[ 1.451291][ T1] io scheduler kyber registered
[ 1.457155][ T1] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.457173][ T1] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.457825][ T1] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.457840][ T1] dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.458342][ T1] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.460013][ T1] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.460798][ T1] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.461593][ T1] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 40, base_baud = 1500000) is a 16550A
[ 2.592568][ T1] printk: console [ttyS2] enabled
[ 2.598800][ T1] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 41, base_baud = 1500000) is a 16550A
[ 2.611405][ T1] rockchip-vop ff930000.vop: Adding to iommu group 0
[ 2.619263][ T1] rockchip-vop ff940000.vop: Adding to iommu group 1
[ 2.629954][ T1] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc11f9004)
[ 2.639307][ T1] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc11f9004)
[ 2.648680][ T1] usbcore: registered new interface driver udl
[ 2.659055][ T1] brd: module loaded
[ 2.671826][ T1] loop: module loaded
[ 2.676600][ T1] zram: Added device: zram0
[ 2.681556][ T1] usbcore: registered new interface driver rtsx_usb
[ 2.691375][ T1] libphy: Fixed MDIO Bus: probed
[ 2.696805][ T1] tun: Universal TUN/TAP device driver, 1.6
[ 2.704369][ T1] rk_gmac-dwmac ff290000.ethernet: IRQ eth_lpi not found
[ 2.712166][ T1] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
[ 2.719700][ T1] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 2.731062][ T1] PPP generic driver version 2.4.2
[ 2.737076][ T1] usbcore: registered new interface driver rt2500usb
[ 2.744443][ T1] usbcore: registered new interface driver rt73usb
[ 2.751600][ T1] usbcore: registered new interface driver rt2800usb
[ 2.758983][ T1] usbcore: registered new interface driver rndis_wlan
[ 2.766401][ T1] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.775509][ T1] usbcore: registered new interface driver pegasus
[ 2.782654][ T1] usbcore: registered new interface driver rtl8150
[ 2.789819][ T1] usbcore: registered new interface driver r8152
[ 2.796784][ T1] usbcore: registered new interface driver asix
[ 2.803648][ T1] usbcore: registered new interface driver ax88179_178a
[ 2.811287][ T1] usbcore: registered new interface driver cdc_ether
[ 2.818632][ T1] usbcore: registered new interface driver dm9601
[ 2.825696][ T1] usbcore: registered new interface driver smsc75xx
[ 2.832963][ T1] usbcore: registered new interface driver smsc95xx
[ 2.840216][ T1] usbcore: registered new interface driver net1080
[ 2.847371][ T1] usbcore: registered new interface driver rndis_host
[ 2.854814][ T1] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.863923][ T1] usbcore: registered new interface driver cdc_ncm
[ 2.871076][ T1] usbcore: registered new interface driver cdc_mbim
[ 2.878675][ T1] dwc2 ff540000.usb: supply vusb_d not found, using dummy regulator
[ 2.887544][ T1] dwc2 ff540000.usb: supply vusb_a not found, using dummy regulator
[ 2.948467][ T1] dwc2 ff540000.usb: DWC OTG Controller
[ 2.954552][ T1] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 2.963265][ T1] dwc2 ff540000.usb: irq 45, io mem 0xff540000
[ 2.970199][ T1] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 2.980248][ T1] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.989118][ T1] usb usb1: Product: DWC OTG Controller
[ 2.995170][ T1] usb usb1: Manufacturer: Linux 5.8.0-RockMyy32-Frosty dwc2_hsotg
[ 3.003747][ T1] usb usb1: SerialNumber: ff540000.usb
[ 3.010257][ T1] hub 1-0:1.0: USB hub found
[ 3.015273][ T1] hub 1-0:1.0: 1 port detected
[ 3.021022][ T1] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[ 3.029864][ T1] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[ 3.162297][ T1] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 3.171249][ T1] dwc2 ff580000.usb: DWC OTG Controller
[ 3.177320][ T1] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.186023][ T1] dwc2 ff580000.usb: irq 46, io mem 0xff580000
[ 3.192923][ T1] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 3.202963][ T1] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.211833][ T1] usb usb2: Product: DWC OTG Controller
[ 3.217876][ T1] usb usb2: Manufacturer: Linux 5.8.0-RockMyy32-Frosty dwc2_hsotg
[ 3.226532][ T1] usb usb2: SerialNumber: ff580000.usb
[ 3.232973][ T1] hub 2-0:1.0: USB hub found
[ 3.237994][ T1] hub 2-0:1.0: 1 port detected
[ 3.244756][ T1] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.252859][ T1] ehci-pci: EHCI PCI platform driver
[ 3.258669][ T1] ehci-platform: EHCI generic platform driver
[ 3.265568][ T1] usbcore: registered new interface driver cdc_acm
[ 3.272692][ T1] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.282537][ T1] usbcore: registered new interface driver usblp
[ 3.289506][ T1] usbcore: registered new interface driver cdc_wdm
[ 3.296707][ T1] usbcore: registered new interface driver usbserial_generic
[ 3.304823][ T1] usbserial: USB Serial support registered for generic
[ 3.312369][ T1] usbcore: registered new interface driver ftdi_sio
[ 3.319608][ T1] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.328652][ T1] usbcore: registered new interface driver keyspan
[ 3.335794][ T1] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 3.345442][ T1] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 3.354540][ T1] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 3.363528][ T1] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 3.372534][ T1] usbcore: registered new interface driver option
[ 3.379578][ T1] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.388268][ T1] usbcore: registered new interface driver oti6858
[ 3.395409][ T1] usbserial: USB Serial support registered for oti6858
[ 3.402937][ T83] usb 1-1: new high-speed USB device number 2 using dwc2
[ 3.410728][ T1] usbcore: registered new interface driver pl2303
[ 3.417782][ T1] usbserial: USB Serial support registered for pl2303
[ 3.425254][ T1] usbcore: registered new interface driver qcserial
[ 3.432491][ T1] usbserial: USB Serial support registered for Qualcomm USB modem
[ 3.441111][ T1] usbcore: registered new interface driver sierra
[ 3.448157][ T1] usbserial: USB Serial support registered for Sierra USB modem
[ 3.457208][ T1] usbcore: registered new interface driver iforce
[ 3.464285][ T1] usbcore: registered new interface driver pxrc
[ 3.471166][ T1] usbcore: registered new interface driver xpad
[ 3.478093][ T1] usbcore: registered new interface driver usbtouchscreen
[ 3.486382][ T1] i2c /dev entries driver
[ 3.494570][ T1] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 3.503076][ T1] fan53555-reg: supplied by vcc_sys
[ 3.511575][ T1] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 3.520107][ T1] fan53555-reg: supplied by vcc_sys
[ 3.529684][ T1] rtc-hym8563 0-0051: registered as rtc0
[ 3.536180][ T1] rtc-hym8563 0-0051: setting system clock to 2017-01-01T14:29:04 UTC (1483280944)
[ 3.548407][ T1] REG1: supplied by vcc_sys
[ 3.554005][ T1] REG2: supplied by vcc_sys
[ 3.559628][ T1] REG3: supplied by vcc_sys
[ 3.565220][ T1] REG4: supplied by vcc_sys
[ 3.570823][ T1] REG5: supplied by vcc_sys
[ 3.576447][ T1] REG6: supplied by vcc_sys
[ 3.582166][ T1] REG7: supplied by vcc_sys
[ 3.587633][ T1] REG8: supplied by vcc_sys
[ 3.588621][ T83] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[ 3.593103][ T1] REG9: supplied by vcc_sys
[ 3.602464][ T83] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.607906][ T1] REG10: supplied by vcc_20
[ 3.616097][ T83] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 3.621410][ T83] hub 1-1:1.0: USB hub found
[ 3.627722][ T1] REG11: supplied by vcc_20
[ 3.631904][ T83] hub 1-1:1.0: 4 ports detected
[ 3.637593][ T1] REG12: supplied by vcc_20
[ 3.649027][ T1] IR NEC protocol handler initialized
[ 3.654934][ T1] IR RC5(x/sz) protocol handler initialized
[ 3.661404][ T1] IR RC6 protocol handler initialized
[ 3.667261][ T1] IR JVC protocol handler initialized
[ 3.673116][ T1] IR Sony protocol handler initialized
[ 3.679069][ T1] IR SANYO protocol handler initialized
[ 3.685117][ T1] IR Sharp protocol handler initialized
[ 3.691165][ T1] IR MCE Keyboard/mouse protocol handler initialized
[ 3.698475][ T1] IR XMP protocol handler initialized
[ 3.704329][ T1] ir_imon_decoder: IR iMON protocol handler initialized
[ 3.711930][ T1] IR RCMM protocol handler initialized
[ 3.717958][ T1] usbcore: registered new interface driver uvcvideo
[ 3.725177][ T1] USB Video Class driver (1.1.1)
[ 3.730546][ T1] gspca_main: v2.14.0 registered
[ 3.736643][ T1] vcc28_dvp: supplied by vcc_io
[ 3.742138][ T1] dovdd_1v8: supplied by vcc28_dvp
[ 3.746363][ C0] random: fast init done
[ 3.747847][ T1] vcc_flash: supplied by vcc_io
[ 3.762027][ T1] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[ 3.776199][ T1] sdhci: Secure Digital Host Controller Interface driver
[ 3.783926][ T1] sdhci: Copyright(c) Pierre Ossman
[ 3.789594][ T1] Synopsys Designware Multimedia Card Interface Driver
[ 3.797529][ T1] dwmmc_rockchip ff0c0000.mmc: IDMAC supports 32-bit address mode.
[ 3.806206][ T1] dwmmc_rockchip ff0c0000.mmc: Using internal DMA controller.
[ 3.814378][ T1] dwmmc_rockchip ff0c0000.mmc: Version ID is 270a
[ 3.821414][ T1] dwmmc_rockchip ff0c0000.mmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 3.832909][ T1] vcc_sd: supplied by vcc_io
[ 3.959080][ T1] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.983103][ T1] dwmmc_rockchip ff0d0000.mmc: IDMAC supports 32-bit address mode.
[ 3.991804][ T1] dwmmc_rockchip ff0d0000.mmc: Using internal DMA controller.
[ 3.999996][ T1] dwmmc_rockchip ff0d0000.mmc: Version ID is 270a
[ 4.007026][ T1] dwmmc_rockchip ff0d0000.mmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[ 4.018715][ T1] dwmmc_rockchip ff0d0000.mmc: Failed getting OCR mask: 0
[ 4.026558][ T1] mmc_host mmc1: card is non-removable.
[ 4.032656][ T1] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[ 4.041125][ T1] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[ 4.062452][ T1] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.086443][ T1] dwmmc_rockchip ff0f0000.mmc: IDMAC supports 32-bit address mode.
[ 4.095146][ T1] dwmmc_rockchip ff0f0000.mmc: Using internal DMA controller.
[ 4.103351][ T1] dwmmc_rockchip ff0f0000.mmc: Version ID is 270a
[ 4.110392][ T1] dwmmc_rockchip ff0f0000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo
[ 4.122167][ T1] mmc_host mmc2: card is non-removable.
[ 4.133857][ T122] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[ 4.140967][ T1] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.142326][ T122] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[ 4.166141][ T1] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.173675][ T1] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.174711][ T122] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 4.181236][ T1] hid: raw HID events driver (C) Jiri Kosina
[ 4.199196][ T1] usbcore: registered new interface driver usbhid
[ 4.206206][ T1] usbhid: USB HID core driver
[ 4.211432][ T1] ashmem: initialized
[ 4.217055][ T1] usbcore: registered new interface driver snd-usb-audio
[ 4.223160][ T122] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[ 4.225804][ T1] u32 classifier
[ 4.233234][ T122] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[ 4.237030][ T1] input device check on
[ 4.242610][ T83] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[ 4.242749][ T83] mmc2: new high speed MMC card at address 0001
[ 4.243357][ T83] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[ 4.243786][ T83] mmcblk2boot0: mmc2:0001 AJTD4R partition 1 4.00 MiB
[ 4.244313][ T83] mmcblk2boot1: mmc2:0001 AJTD4R partition 2 4.00 MiB
[ 4.245412][ T83] mmcblk2rpmb: mmc2:0001 AJTD4R partition 3 4.00 MiB, chardev (240:0)
[ 4.250705][ T1] Initializing XFRM netlink socket
[ 4.258421][ T122] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 4.265560][ T83] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8
[ 4.268975][ T1] NET: Registered protocol family 10
[ 4.296016][ T122] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[ 4.298874][ T1] Segment Routing with IPv6
[ 4.303825][ T122] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[ 4.314905][ T1] RPL Segment Routing with IPv6
[ 4.333626][ T122] mmc_host mmc1: Bus speed (slot 0) = 187500Hz (slot req 100000Hz, actual 93750HZ div = 1)
[ 4.334916][ T1] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 4.371870][ T1] NET: Registered protocol family 17
[ 4.377641][ T1] NET: Registered protocol family 15
[ 4.383523][ T1] Bluetooth: RFCOMM TTY layer initialized
[ 4.389775][ T1] Bluetooth: RFCOMM socket layer initialized
[ 4.396329][ T1] Bluetooth: RFCOMM ver 1.11
[ 4.401317][ T1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.408732][ T1] Bluetooth: HIDP socket layer initialized
[ 4.415184][ T1] 8021q: 802.1Q VLAN Support v1.8
[ 4.420658][ T1] lib80211: common routines for IEEE802.11 drivers
[ 4.427791][ T1] Key type dns_resolver registered
[ 4.433622][ T1] ThumbEE CPU extension supported.
[ 4.439179][ T1] Registering SWP/SWPB emulation handler
[ 4.445437][ T1] Loading compiled-in X.509 certificates
[ 4.453544][ T1] Btrfs loaded, crc32c=crc32c-generic
[ 4.473907][ T113] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc11f9004)
[ 4.483184][ T113] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc11f9004)
[ 4.492272][ T113] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[ 4.504640][ T113] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc11fc264)
[ 4.513700][ T113] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.521910][ T113] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 4.531156][ T113] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[ 4.541261][ T113] rk_gmac-dwmac ff290000.ethernet: IRQ eth_lpi not found
[ 4.549007][ T113] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
[ 4.556566][ T113] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 4.565233][ T113] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[ 4.572338][ T113] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[ 4.579436][ T113] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
[ 4.587146][ T113] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
[ 4.595707][ T113] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 4.608302][ T113] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 4.615559][ T113] rk_gmac-dwmac ff290000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[ 4.624326][ T113] rk_gmac-dwmac ff290000.ethernet: DWMAC1000
[ 4.630949][ T113] rk_gmac-dwmac ff290000.ethernet: DMA HW capability register supported
[ 4.640093][ T113] rk_gmac-dwmac ff290000.ethernet: RX Checksum Offload Engine supported
[ 4.649233][ T113] rk_gmac-dwmac ff290000.ethernet: COE Type 2
[ 4.655852][ T113] rk_gmac-dwmac ff290000.ethernet: TX Checksum insertion supported
[ 4.664502][ T113] rk_gmac-dwmac ff290000.ethernet: Wake-Up On Lan supported
[ 4.672492][ T113] rk_gmac-dwmac ff290000.ethernet: Normal descriptors
[ 4.679889][ T113] rk_gmac-dwmac ff290000.ethernet: Ring mode enabled
[ 4.687190][ T113] rk_gmac-dwmac ff290000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 4.696921][ T113] rk_gmac-dwmac ff290000.ethernet: device MAC address 7a:91:66:34:ed:94
[ 5.538272][ T129] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 5.737357][ T113] libphy: stmmac: probed
[ 5.741945][ T113] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 5.753326][ T113] mdio_bus stmmac-0:01: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 5.765509][ T1] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.774135][ T1] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.785188][ T1] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.793363][ T122] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.795484][ T1] ALSA device list:
[ 5.803790][ T122] cfg80211: failed to load regulatory.db
[ 5.807873][ T1] No soundcards found.
[ 5.818695][ T1] dw-apb-uart ff690000.serial: forbid DMA for kernel console
[ 5.843507][ T1] erofs: (device mmcblk2p7): erofs_read_superblock: cannot find valid erofs superblock
[ 5.870548][ T1] erofs: (device mmcblk2p7): erofs_read_superblock: cannot find valid erofs superblock
[ 5.881532][ T1] List of all partitions:
[ 5.886236][ T1] 0100 4096 ram0
[ 5.886238][ T1] (driver?)
[ 5.894662][ T1] b300 15267840 mmcblk2
[ 5.894664][ T1] driver: mmcblk
[ 5.903825][ T1] b301 4096 mmcblk2p1 2d230000-0000-4e50-8000-07bf00004ea9
[ 5.903826][ T1]
[ 5.915409][ T1] b302 4096 mmcblk2p2 2c170000-0000-4472-8000-6173000065f3
[ 5.915410][ T1]
[ 5.926982][ T1] b303 4096 mmcblk2p3 4b650000-0000-487c-8000-2fb100007d14
[ 5.926983][ T1]
[ 5.938564][ T1] b304 32768 mmcblk2p4 b4590000-0000-4111-8000-70a100007eb5
[ 5.938565][ T1]
[ 5.950148][ T1] b305 32768 mmcblk2p5 8c520000-0000-4728-8000-3a6c0000247d
[ 5.950149][ T1]
[ 5.961730][ T1] b306 32768 mmcblk2p6 fe460000-0000-440c-8000-363a00007e15
[ 5.961731][ T1]
[ 5.973311][ T1] b307 2094080 mmcblk2p7 614e0000-0000-4b53-8000-1d28000054a9
[ 5.973312][ T1]
[ 5.984892][ T1] b308 12989423 mmcblk2p8 4a510000-0000-4d08-8000-507d00003353
[ 5.984893][ T1]
[ 5.996476][ T1] No filesystem could mount root, tried:
[ 5.996477][ T1] reiserfs
[ 6.002706][ T1] ext3
[ 6.006024][ T1] ext4
[ 6.008951][ T1] ext2
[ 6.011877][ T1] squashfs
[ 6.014803][ T1] vfat
[ 6.018117][ T1] iso9660
[ 6.021043][ T1] hfsplus
[ 6.024261][ T1] ntfs
[ 6.027478][ T1] fuseblk
[ 6.030404][ T1] udf
[ 6.033620][ T1] jfs
[ 6.036449][ T1] xfs
[ 6.039277][ T1] erofs
[ 6.042105][ T1] btrfs
[ 6.045127][ T1]
[ 6.050587][ T1] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,7)
[ 6.060793][ T1] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 5.8.0-RockMyy32-Frosty #1
[ 6.069732][ T1] Hardware name: Rockchip (Device Tree)
[ 6.075775][ T1] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.085206][ T1] [] (show_stack) from [] (dump_stack+0x80/0x9c)
[ 6.094055][ T1] [] (dump_stack) from [] (panic+0xd4/0x2dc)
[ 6.102516][ T1] [] (panic) from [] (mount_block_root+0x294/0x328)
[ 6.111656][ T1] [] (mount_block_root) from [] (prepare_namespace+0x170/0x1ac)
[ 6.121960][ T1] [] (prepare_namespace) from [] (kernel_init_freeable+0x1f8/0x264)
[ 6.132653][ T1] [] (kernel_init_freeable) from [] (kernel_init+0x8/0x110)
[ 6.142569][ T1] [] (kernel_init) from [] (ret_from_fork+0x14/0x2c)
[ 6.151802][ T1] Exception stack(0xee8f9fb0 to 0xee8f9ff8)
[ 6.158211][ T1] 9fa0: 00000000 00000000 00000000 00000000
[ 6.168124][ T1] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.178037][ T1] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 6.186198][ C2] CPU2: stopping
[ 6.189994][ C2] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.8.0-RockMyy32-Frosty #1
[ 6.198935][ C2] Hardware name: Rockchip (Device Tree)
[ 6.204967][ C2] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.214397][ C2] [] (show_stack) from [] (dump_stack+0x80/0x9c)
[ 6.223243][ C2] [] (dump_stack) from [] (handle_IPI+0x2bc/0x39c)
[ 6.232286][ C2] [] (handle_IPI) from [] (gic_handle_irq+0x84/0x90)
[ 6.241521][ C2] [] (gic_handle_irq) from [] (__irq_svc+0x6c/0xa8)
[ 6.250656][ C2] Exception stack(0xee921f60 to 0xee921fa8)
[ 6.257073][ C2] 1f60: 00000000 eefbe3f0 00000000 c0117b80 00000000 00000000 ee920000 00000004
[ 6.266987][ C2] 1f80: c170a730 ee921fb8 c170a770 00000000 00000009 ee921fb0 c0106e08 c0106df8
[ 6.276897][ C2] 1fa0: 60000013 ffffffff
[ 6.281569][ C2] [] (__irq_svc) from [] (arch_cpu_idle+0x1c/0x38)
[ 6.290613][ C2] [] (arch_cpu_idle) from [] (do_idle+0x108/0x28c)
[ 6.299655][ C2] [] (do_idle) from [] (cpu_startup_entry+0x18/0x20)
[ 6.308889][ C2] [] (cpu_startup_entry) from [<0010162c>] (0x10162c)
[ 6.317246][ C0] CPU0: stopping
[ 6.321033][ C0] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.8.0-RockMyy32-Frosty #1
[ 6.329974][ C0] Hardware name: Rockchip (Device Tree)
[ 6.336007][ C0] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.345436][ C0] [] (show_stack) from [] (dump_stack+0x80/0x9c)
[ 6.354283][ C0] [] (dump_stack) from [] (handle_IPI+0x2bc/0x39c)
[ 6.363324][ C0] [] (handle_IPI) from [] (gic_handle_irq+0x84/0x90)
[ 6.372559][ C0] [] (gic_handle_irq) from [] (__irq_svc+0x6c/0xa8)
[ 6.381693][ C0] Exception stack(0xc1701f18 to 0xc1701f60)
[ 6.388109][ C0] 1f00: 00000000 eef963f0
[ 6.398023][ C0] 1f20: 00000000 c0117b80 00000000 00000000 c1700000 00000001 c170a730 c1701f70
[ 6.407936][ C0] 1f40: c170a770 000001c9 00000000 c1701f68 c0106e08 c0106df8 60000013 ffffffff
[ 6.417850][ C0] [] (__irq_svc) from [] (arch_cpu_idle+0x1c/0x38)
[ 6.426891][ C0] [] (arch_cpu_idle) from [] (do_idle+0x108/0x28c)
[ 6.435931][ C0] [] (do_idle) from [] (cpu_startup_entry+0x18/0x20)
[ 6.445166][ C0] [] (cpu_startup_entry) from [] (start_kernel+0x6c4/0x7b8)
[ 6.455080][ C0] [] (start_kernel) from [<00000000>] (0x0)
[ 6.462467][ C1] CPU1: stopping
[ 6.466264][ C1] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.8.0-RockMyy32-Frosty #1
[ 6.475205][ C1] Hardware name: Rockchip (Device Tree)
[ 6.481238][ C1] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.490667][ C1] [] (show_stack) from [] (dump_stack+0x80/0x9c)
[ 6.499514][ C1] [] (dump_stack) from [] (handle_IPI+0x2bc/0x39c)
[ 6.508555][ C1] [] (handle_IPI) from [] (gic_handle_irq+0x84/0x90)
[ 6.517791][ C1] [] (gic_handle_irq) from [] (__irq_svc+0x6c/0xa8)
[ 6.526925][ C1] Exception stack(0xee91ff60 to 0xee91ffa8)
[ 6.533344][ C1] ff60: 00000000 eefaa3f0 00000000 c0117b80 00000000 00000000 ee91e000 00000002
[ 6.543259][ C1] ff80: c170a730 ee91ffb8 c170a770 00000000 00000000 ee91ffb0 c0106e08 c0106df8
[ 6.553170][ C1] ffa0: 60000013 ffffffff
[ 6.557841][ C1] [] (__irq_svc) from [] (arch_cpu_idle+0x1c/0x38)
[ 6.566883][ C1] [] (arch_cpu_idle) from [] (do_idle+0x108/0x28c)
[ 6.575924][ C1] [] (do_idle) from [] (cpu_startup_entry+0x18/0x20)
[ 6.585158][ C1] [] (cpu_startup_entry) from [<0010162c>] (0x10162c)
[ 6.593523][ T1] —[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,7) ]—
-kernel 4.4.70:
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Unable to boot:boot
try to start backup
kernel @ 0x02000000 (0x007146a0)
Loading Device Tree to 05600000, end 0560fb4d … OK
[ 0.000000] Linux version 4.4.70 (forkworks@forkworks-ThinkPad-W520) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #25 SMP Thu May 24 20:20:01 ART 2018
[ 0.000000] Machine model: Firefly-RK3288
[ 0.000000] PERCPU: Embedded 13 pages/cpu @eef8a000 s24448 r8192 d20608 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522752
[ 0.000000] Kernel command line: init=/sbin/init root=/dev/mmcblk2p7 rw rootwait console=ttyS2,115200 quiet splash loglevel=7 acpi=off apm=off vt.global_cursor_default=0 consoleblank=0 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00008000@0x00016000(back),0x00010000@0x0001e000(backup),0xc00800@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2017-06-02_17:57:28 SecureBootCheckOk=0
[ 0.000000] Memory: 2060564K/2097152K available (11264K kernel code, 863K rwdata, 3076K rodata, 2048K init, 601K bss, 36588K reserved, 0K cma-reserved, 1310720K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0c00000 (12256 kB)
[ 0.000000] .init : 0xc1000000 - 0xc1200000 (2048 kB)
[ 0.000000] .data : 0xc1200000 - 0xc12d7db0 ( 864 kB)
[ 0.000000] .bss : 0xc12d9000 - 0xc136f53c ( 602 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] L2C: failed to init: -19
[ 0.000018] Switching to timer-based delay loop, resolution 41ns
[ 0.001652] Console: colour dummy device 80x30
[ 0.001679] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.001695] pid_max: default: 32768 minimum: 301
[ 0.001781] Security Framework initialized
[ 0.001792] Yama: becoming mindful.
[ 0.001846] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001858] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002531] Initializing cgroup subsys devices
[ 0.002549] Initializing cgroup subsys freezer
[ 0.002575] CPU: Testing write buffer coherency: ok
[ 0.002605] ftrace: allocating 40724 entries in 120 pages
[ 0.074904] CPU0: update cpu_capacity 430
[ 0.074918] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.075163] Setting up static identity map for 0x100000 - 0x100058
[ 0.077707] CPU1: update cpu_capacity 430
[ 0.077713] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.079344] CPU2: update cpu_capacity 430
[ 0.079349] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.080965] CPU3: update cpu_capacity 430
[ 0.080971] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.081038] Brought up 4 CPUs
[ 0.081064] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.081070] CPU: All CPU(s) started in SVC mode.
[ 0.082184] devtmpfs: initialized
[ 0.095727] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.096032] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.096056] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.096431] pinctrl core: initialized pinctrl subsystem
[ 0.097269] NET: Registered protocol family 16
[ 0.098002] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.124745] cpuidle: using governor ladder
[ 0.154763] cpuidle: using governor menu
[ 0.180094] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.180104] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.227137] vcc_5v: supplied by vcc_sys
[ 0.227552] vcc_host_5v: supplied by vcc_5v
[ 0.227982] vcc_otg_5v: supplied by vcc_5v
[ 0.228967] iommu: Adding device ff930000.vop to group 0
[ 0.229044] iommu: Adding device ff940000.vop to group 1
[ 0.229126] iommu: Adding device ff9a0000.vpu-service to group 2
[ 0.229204] iommu: Adding device ff9c0000.hevc-service to group 3
[ 0.230667] SCSI subsystem initialized
[ 0.230894] usbcore: registered new interface driver usbfs
[ 0.230953] usbcore: registered new interface driver hub
[ 0.231003] usbcore: registered new device driver usb
[ 0.231126] Linux video capture interface: v2.00
[ 0.231169] pps_core: LinuxPPS API ver. 1 registered
[ 0.231176] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.231205] PTP clock support registered
[ 0.232361] Advanced Linux Sound Architecture Driver Initialized.
[ 0.232978] Bluetooth: Core ver 2.21
[ 0.233011] NET: Registered protocol family 31
[ 0.233019] Bluetooth: HCI device and connection manager initialized
[ 0.233031] Bluetooth: HCI socket layer initialized
[ 0.233042] Bluetooth: L2CAP socket layer initialized
[ 0.233069] Bluetooth: SCO socket layer initialized
[ 0.234390] clocksource: Switched to clocksource arch_sys_counter
[ 0.282257] NET: Registered protocol family 2
[ 0.282767] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.282843] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 0.283006] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.283059] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 0.283104] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 0.283315] NET: Registered protocol family 1
[ 0.283604] RPC: Registered named UNIX socket transport module.
[ 0.283613] RPC: Registered udp transport module.
[ 0.283619] RPC: Registered tcp transport module.
[ 0.283625] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.284610] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 0.286425] Initialise system trusted keyring
[ 0.295364] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.297070] NFS: Registering the id_resolver key type
[ 0.297097] Key type id_resolver registered
[ 0.297104] Key type id_legacy registered
[ 0.297125] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.297730] fuse init (API version 7.23)
[ 0.301726] NET: Registered protocol family 38
[ 0.301756] Key type asymmetric registered
[ 0.301769] Asymmetric key parser ‘x509’ registered
[ 0.301841] bounce: pool size: 64 pages
[ 0.302022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.302038] io scheduler noop registered
[ 0.302051] io scheduler deadline registered
[ 0.302084] io scheduler cfq registered (default)
[ 0.302406] rockchip-usb-phy ff770000.syscon:usbphy: vbus_drv is not assigned!
[ 0.305167] rk-vcodec ff9a0000.vpu-service: probe device
[ 0.305216] rk-vcodec ff9a0000.vpu-service: vpu mmu dec eeb14e10
[ 0.305407] rk-vcodec ff9a0000.vpu-service: allocator is drm
[ 0.305472] rk-vcodec ff9a0000.vpu-service: checking hw id 4831
[ 0.305955] rk-vcodec ff9a0000.vpu-service: init success
[ 0.306433] rk-vcodec ff9c0000.hevc-service: probe device
[ 0.306482] rk-vcodec ff9c0000.hevc-service: vpu mmu dec eeb15210
[ 0.306651] rk-vcodec ff9c0000.hevc-service: allocator is drm
[ 0.306712] rk-vcodec ff9c0000.hevc-service: checking hw id 6867
[ 0.307036] rk-vcodec ff9c0000.hevc-service: init success
[ 0.309052] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.309066] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.309800] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.309813] dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.310358] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.312154] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 0.312802] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.313443] console [ttyS2] disabled
[ 0.313482] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.155682] console [ttyS2] enabled
[ 1.159861] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.169382] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 40, base_baud = 1500000) is a 16550A
[ 1.179411] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.186930] ff960000.mipi.0 supply power not found, using dummy regulator
[ 1.196453] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0c5293c)
[ 1.204419] rockchip-drm displaU-Boot 2017.02-RK3288-06-g8adeb23-dirty (Jun 02 2017 - 17:57:28)
CPU: rk3288
cpu version = 0
128 MiB
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
no key node
No pmic detect.
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Unable to boot:boot
try to start backup
[ 0.301726] NET: Registered proy-subsystem: bound ff930000.vop (ops 0xc0c5293c)
[ 1.211774] dw-mipi-dsi ff960000.mipi: No PHY APB clock specified
[ 1.217885] dw-mipi-dsi ff960000.mipi: no reset control specified
[ 1.224032] rockchip-drm display-subsystem: bound ff960000.mipi (ops 0xc0c4f6d4)
[ 1.231643] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
[ 1.238274] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.246074] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.256562] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0c4f354)
[ 1.263954] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.271969] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 1.279298] rockchip-drm display-subsystem: failed to parse display resources
[ 1.335672] dw-mipi-dsi ff960000.mipi: failed to wait for phy clk lane stop state
[ 1.400427] Console: switching to colour frame buffer device 170x48
[ 1.456814] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.485622] usbcore: registered new interface driver udl
[ 1.491662] mali ffa30000.gpu: Failed to get regulator
[ 1.496820] mali ffa30000.gpu: Power control initialization failed
[ 1.504096] brd: module loaded
[ 1.512815] loop: module loaded
[ 1.516632] zram: Added device: zram0
[ 1.520329] lkdtm: No crash points registered, enable through debugfs
[ 1.527509] tun: Universal TUN/TAP device driver, 1.6
[ 1.532555] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.539989] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 1.549449] PPP generic driver version 2.4.2
[ 1.553972] usbcore: registered new interface driver rndis_wlan
[ 1.560109] usbcore: registered new interface driver rt2800usb
[ 1.566019] Rockchip WiFi SYS interface (V1.00) …
[ 1.571013] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.578471] usbcore: registered new interface driver pegasus
[ 1.584171] usbcore: registered new interface driver rtl8150
[ 1.589884] usbcore: registered new interface driver r8152
[ 1.595441] usbcore: registered new interface driver asix
[ 1.600878] usbcore: registered new interface driver ax88179_178a
[ 1.607034] usbcore: registered new interface driver cdc_ether
[ 1.612907] usbcore: registered new interface driver dm9601
[ 1.618557] usbcore: registered new interface driver smsc75xx
[ 1.624346] usbcore: registered new interface driver smsc95xx
[ 1.630149] usbcore: registered new interface driver net1080
[ 1.635873] usbcore: registered new interface driver rndis_host
[ 1.641832] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.649318] usbcore: registered new interface driver cdc_ncm
[ 1.655042] usbcore: registered new interface driver cdc_mbim
[ 1.661115] ff540000.usb supply vusb_d not found, using dummy regulator
[ 1.667789] ff540000.usb supply vusb_a not found, using dummy regulator
[ 1.794552] dwc2 ff540000.usb: DWC OTG Controller
[ 1.799272] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 1.806368] dwc2 ff540000.usb: irq 45, io mem 0x00000000
[ 1.811896] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.818697] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.825931] usb usb1: Product: DWC OTG Controller
[ 1.830631] usb usb1: Manufacturer: Linux 4.4.70 dwc2_hsotg
[ 1.836209] usb usb1: SerialNumber: ff540000.usb
[ 1.841396] hub 1-0:1.0: USB hub found
[ 1.845199] hub 1-0:1.0: 1 port detected
[ 1.849651] ff580000.usb supply vusb_d not found, using dummy regulator
[ 1.856325] ff580000.usb supply vusb_a not found, using dummy regulator
[ 2.134430] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 2.141924] dwc2 ff580000.usb: DWC OTG Controller
[ 2.146673] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 2.153734] dwc2 ff580000.usb: irq 46, io mem 0x00000000
[ 2.159187] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.165994] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.173208] usb usb2: Product: DWC OTG Controller
[ 2.177927] usb usb2: Manufacturer: Linux 4.4.70 dwc2_hsotg
[ 2.183494] usb usb2: SerialNumber: ff580000.usb
[ 2.188710] hub 2-0:1.0: USB hub found
[ 2.192485] hub 2-0:1.0: 1 port detected
[ 2.197619] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.204159] ehci-platform: EHCI generic platform driver
[ 2.209602] ehci-platform ff500000.usb: EHCI Host Controller
[ 2.215459] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
[ 2.223382] ehci-platform ff500000.usb: irq 44, io mem 0xff500000
[ 2.244421] usb 1-1: new high-speed USB device number 2 using dwc2
[ 2.264420] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[ 2.270753] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.277554] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.284800] usb usb3: Product: EHCI Host Controller
[ 2.289674] usb usb3: Manufacturer: Linux 4.4.70 ehci_hcd
[ 2.295083] usb usb3: SerialNumber: ff500000.usb
[ 2.300314] hub 3-0:1.0: USB hub found
[ 2.304090] hub 3-0:1.0: 1 port detected
[ 2.308641] usbcore: registered new interface driver cdc_acm
[ 2.314294] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.322375] usbcore: registered new interface driver cdc_wdm
[ 2.328166] usbcore: registered new interface driver usb-storage
[ 2.334252] usbcore: registered new interface driver usbserial
[ 2.340211] usbcore: registered new interface driver usbserial_generic
[ 2.346791] usbserial: USB Serial support registered for generic
[ 2.352841] usbcore: registered new interface driver cp210x
[ 2.358463] usbserial: USB Serial support registered for cp210x
[ 2.364460] usbcore: registered new interface driver ftdi_sio
[ 2.370229] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.377679] usbcore: registered new interface driver keyspan
[ 2.383364] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.391227] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.398644] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.406536] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.413902] usbcore: registered new interface driver option
[ 2.419514] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.426645] usbcore: registered new interface driver oti6858
[ 2.432337] usbserial: USB Serial support registered for oti6858
[ 2.438406] usbcore: registered new interface driver pl2303
[ 2.444000] usbserial: USB Serial support registered for pl2303
[ 2.449982] usbcore: registered new interface driver qcserial
[ 2.455854] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.462870] usbcore: registered new interface driver sierra
[ 2.468483] usbserial: USB Serial support registered for Sierra USB modem
[ 2.475641] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 2.482337] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.489496] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 2.490343] usbcore: registered new interface driver iforce
[ 2.490415] usbcore: registered new interface driver xpad
[ 2.505213] usbcore: registered new interface driver usbtouchscreen
[ 2.505711] hub 1-1:1.0: USB hub found
[ 2.505784] hub 1-1:1.0: 4 ports detected
[ 2.519246] ==gsl_ts_init==
[ 2.522067] ret=0
[ 2.524276] i2c /dev entries driver
[ 2.529057] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.536001] fan53555-reg: supplied by vcc_sys
[ 2.540659] vdd_cpu: No configuration
[ 2.546192] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.553093] fan53555-reg: supplied by vcc_sys
[ 2.557770] vdd_gpu: No configuration
[ 2.565157] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 2.572364] REG1: supplied by vcc_sys
[ 2.576907] REG2: supplied by vcc_sys
[ 2.581322] vcc28_dvp: supplied by vcc_io
[ 2.585519] dovdd_1v8: supplied by vcc28_dvp
[ 2.589845] vcc_sd: supplied by vcc_io
[ 2.593771] vcc_flash: supplied by vcc_io
[ 2.598005] REG3: supplied by vcc_sys
[ 2.602441] REG4: supplied by vcc_sys
[ 2.606878] REG5: supplied by vcc_sys
[ 2.611294] REG6: supplied by vcc_sys
[ 2.615851] REG7: supplied by vcc_sys
[ 2.620136] REG8: supplied by vcc_sys
[ 2.624694] REG9: supplied by vcc_sys
[ 2.628968] REG10: supplied by vcc_20
[ 2.633514] REG11: supplied by vcc_20
[ 2.638070] REG12: supplied by vcc_20
[ 2.642725] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0d34000
[ 2.650321] GSLX680 Enter gsl_ts_probe
[ 2.974405] gsl_ts_probe–1317, i2c_master_recv fail
[ 2.979390] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f0d36000
[ 2.986705] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0d38000
[ 2.994140] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0d3a000
[ 3.001599] usbcore: registered new interface driver uvcvideo
[ 3.007356] USB Video Class driver (1.1.1)
[ 3.015825] rockchip-thermal ff280000.tsadc: Missing rockchip,grf property
[ 3.022749] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 3.032361] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.041093] Bluetooth: Virtual HCI driver ver 1.5
[ 3.045975] Bluetooth: HCI UART driver ver 2.3
[ 3.050417] Bluetooth: HCI UART protocol H4 registered
[ 3.055569] Bluetooth: HCI UART protocol LL registered
[ 3.060701] Bluetooth: HCI UART protocol ATH3K registered
[ 3.066198] usbcore: registered new interface driver bfusb
[ 3.071745] usbcore: registered new interface driver btusb
[ 3.079285] cpu cpu0: Failed to get cpu_leakage
[ 3.084171] cpufreq-dt cpufreq-dt: failed register driver: -17
[ 3.090066] cpufreq-dt: probe of cpufreq-dt failed with error -17
[ 3.096278] sdhci: Secure Digital Host Controller Interface driver
[ 3.102450] sdhci: Copyright(c) Pierre Ossman
[ 3.106838] Synopsys Designware Multimedia Card Interface Driver
[ 3.113448] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.120732] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 3.127532] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 3.133311] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 3.143063] dwmmc_rockchip ff0c0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.274643] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.296104] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
[ 3.304710] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.312097] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 3.319124] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 3.324934] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 3.334684] dwmmc_rockchip ff0d0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.343008] dwmmc_rockchip ff0d0000.dwmmc: Failed getting OCR mask: 0
[ 3.349640] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq
[ 3.356234] dwmmc_rockchip ff0d0000.dwmmc: could not set regulator OCR (-22)
[ 3.363272] dwmmc_rockchip ff0d0000.dwmmc: failed to enable vmmc regulator
[ 3.384430] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.404468] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
[ 3.410828] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[ 3.419139] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[ 3.425967] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[ 3.433751] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[ 3.443510] dwmmc_rockchip ff0f0000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 3.465475] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.483780] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.490783] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.496327] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[ 3.503354] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.512433] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.517841] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.524957] usbcore: registered new interface driver usbhid
[ 3.527760] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.531083] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 3.541473] usbhid: USB HID core driver
[ 3.545557] ashmem: initialized
[ 3.550120] usbcore: registered new interface driver snd-usb-audio
[ 3.558909] u32 classifier
[ 3.561616] Netfilter messages via NETLINK v0.30.
[ 3.566398] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.567029] mmc2: MAN_BKOPS_EN bit is not set
[ 3.567988] mmc_host mmc2: Bus speed (slot 0) = 49500000Hz (slot req 52000000Hz, actual 49500000HZ div = 0)
[ 3.568104] mmc2: new high speed MMC card at address 0001
[ 3.568404] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[ 3.576913] mmcblk2boot0: mmc2:0001 AJTD4R partition 1 4.00 MiB
[ 3.577025] mmcblk2boot1: mmc2:0001 AJTD4R partition 2 4.00 MiB
[ 3.581285] mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
[ 3.584492] mmcblk2rpmb: mmc2:0001 AJTD4R partition 3 4.00 MiB
[ 3.586720] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 3.586723] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 3.586726] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 3.586728] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 3.586730] back: 0x002c00000 – 0x003c00000 (16 MB)
[ 3.586732] backup: 0x003c00000 – 0x005c00000 (32 MB)
[ 3.586735] linuxroot: 0x005c00000 – 0x185d00000 (6145 MB)
[ 3.589343] mmcblk2: p1 p2 p3 p4 p5 p6 p7
[ 3.589344] dwmmc_rockchip ff0d0000.dwmmc: Successfully tuned phase to 97
[ 3.591132] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.591149] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 3.685389] ctnetlink v0.93: registering with nfnetlink.
[ 3.690767] ip_set: protocol 6
[ 3.693820] IPVS: Registered protocols ()
[ 3.697857] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 3.705217] IPVS: Creating netns size=1104 id=0
[ 3.709764] IPVS: ipvs loaded.
[ 3.712994] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.718383] Initializing XFRM netlink socket
[ 3.723042] NET: Registered protocol family 10
[ 3.728006] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.733501] sit: IPv6 over IPv4 tunneling driver
[ 3.738445] NET: Registered protocol family 17
[ 3.742892] NET: Registered protocol family 15
[ 3.747368] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.759978] Bridge firewalling registered
[ 3.764049] Bluetooth: RFCOMM socket layer initialized
[ 3.769204] Bluetooth: RFCOMM ver 1.11
[ 3.772954] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.778874] Bluetooth: HIDP socket layer initialized
[ 3.783872] 8021q: 802.1Q VLAN Support v1.8
[ 3.788067] lib80211: common routines for IEEE802.11 drivers
[ 3.793740] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.798599] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 3.803405] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6335
[ 3.810275] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.817410] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.824834] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0.
[ 3.834035] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.839260] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.843987] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.848546] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[ 3.856740] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[ 3.864839] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[ 3.872836] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[ 3.881188] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 3.887927] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.893161] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 3.897718] [BT_RFKILL]: ** disable irq
[ 3.901624] [BT_RFKILL]: bt_default device registered.
[ 3.906799] Key type dns_resolver registered
[ 3.911475] ThumbEE CPU extension supported.
[ 3.915766] Registering SWP/SWPB emulation handler
[ 3.921008] Loading compiled-in X.509 certificates
[ 3.926724] W : [File] : drivers/gpu/arm/midgard_for_linux/platform/rk/mali_kbase_config_rk.c; [Line] : 107; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 3.942577] vendor storage:20160801 ret = 0
[ 3.942766] mali ffa30000.gpu: GPU identified as 0x0750 r1p0 status 0
[ 3.943100] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 271; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 3.954551] mali ffa30000.gpu: Probed as mali0
[ 3.955079] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 3.955084] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[ 3.955087] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[ 3.955155] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 3.955158] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 3.960330] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.960331] Ring mode enabled
[ 3.960334] DMA HW capability register supported
[ 3.960334] Normal descriptors
[ 3.960335] RX Checksum Offload Engine supported (type 2)
[ 3.960336] TX Checksum insertion supported
[ 3.960337] Wake-Up On Lan supported
[ 3.960363] Enable RX Mitigation via HW Watchdog Timer
[ 3.975125] devfreq ffa30000.gpu: Couldn’t update frequency transition information.
[ 4.991322] libphy: stmmac: probed
[ 4.994958] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 5.001455] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 5.139924] asoc-simple-card es8323-sound: ES8323 HiFi ↔ ff890000.i2s mapping ok
[ 5.147741] asoc-simple-card es8323-sound: ASoC: no source widget found for MICBIAS1
[ 5.155634] asoc-simple-card es8323-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 5.164867] asoc-simple-card es8323-sound: ASoC: no sink widget found for IN1P
[ 5.172108] asoc-simple-card es8323-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 5.180802] asoc-simple-card es8323-sound: ASoC: no source widget found for HPOL
[ 5.188205] asoc-simple-card es8323-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 5.197417] asoc-simple-card es8323-sound: ASoC: no source widget found for HPOR
[ 5.204813] asoc-simple-card es8323-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 5.217061] asoc-simple-card sound: dit-hifi ↔ ff8b0000.sound mapping ok
[ 5.224452] dhd_module_init: in
[ 5.224453]
[ 5.224458] =======================================================
[ 5.224460] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 5.224461] =======================================================
[ 5.224463] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[ 5.224465] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 5.224468] [WLAN_RFKILL]: wifi turn on power. -1
[ 5.224470] RTL871X: module init start
[ 5.224472] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 5.224558] usbcore: registered new interface driver rtl8188eu
[ 5.224561] RTL871X: module init ret=0
[ 5.224961] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.227600] rtc-hym8563 0-0051: setting system clock to 2017-01-01 13:44:52 UTC (1483278292)
[ 5.235364] dovdd_1v8: disabling
[ 5.235368] vcc_sd: disabling
[ 5.235803] ALSA device list:
[ 5.235806] #0: rockchip,es8323-codec
[ 5.235807] #1: SPDIF
[ 5.313847] ======== dhd_wlan_init_plat_data ========
[dE[ 5.319095] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 5.319100] ttyS2 - failed to request DMA
[ 5.328324] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 5.333888] dhd_wlan_init_gpio: host_oob_irq: 232
[ 5.334555] EXT4-fs (mmcblk2p7): couldn’t mount as ext3 due to feature incompatibilities
[ 5.334846] EXT4-fs (mmcblk2p7): couldn’t mount as ext2 due to feature incompatibilities
[ 5.354758] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 5.360061] dhd_wifi_platform_load: Enter
[ 5.364111] Power-up adapter ‘DHD generic adapter’
[ 5.369128] wifi_platform_set_power = 1
[ 5.372960] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 5.378114] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 5.382811] [WLAN_RFKILL]: wifi turn on power. -1
[ 5.405740] EXT4-fs (mmcblk2p7): recovery complete
[ 5.410948] EXT4-fs (mmcblk2p7): mounted filesystem with ordered data mode. Opts: (null)
[ 5.419074] VFS: Mounted root (ext4 filesystem) on device 179:7.
[ 5.425492] devtmpfs: mounted
[ 5.429370] Freeing unused kernel memory: 2048K (c1000000 - c1200000)
[ 5.594465] wifi_platform_bus_enumerate device present 1
[ 5.599787] ======== Card detection to detect SDIO card! ========
[ 5.605918] mmc1:mmc host rescan start!
[ 5.625901] bcmsdh_register: register client driver
[ 5.631003] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 5.636038] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 5.640835] bus num (host idx)=1, slot num (rca)=1
[ 5.645683] found adapter info ‘DHD generic adapter’
[ 5.650740] sdioh_attach: set sd_f2_blocksize 256
[ 5.655984] F1 signature read @0x18000000=0x15264345
[ 5.657825] random: init: uninitialized urandom read (12 bytes read, 70 bits of entropy available)
[ 5.673257] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
[ 5.680299] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
[ 5.687300] dhd_conf_set_chiprev: chip=0x4345, chiprev=6
[ 5.692661] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 5.701493] wl_create_event_handler(): thread:wl_event_handler:88 started
[ 5.701501] tsk Enter, tsk = 0xedf815c8
[ 5.712296] wl_escan_attach: Enter
[ 5.715744] wl_escan_init: Enter
[ 5.723138] wl_create_event_handler(): thread:wl_escan_handler:8c started
[ 5.724147] tsk Enter, tsk = 0xedff0170
[ 5.733891] dhd_attach(): thread:dhd_watchdog_thread:91 started
[ 5.741903] dhd_attach(): thread:dhd_dpc:92 started
[ 5.743731] init: plymouth-upstart-bridge main process (135) terminated with status 1
[ 5.743758] init: plymouth-upstart-bridge main process ended, respawning
[[ 5.761533] dhd_deferred_work_init: work queue initialized
[ 5.773645] Dongle Host Driver, version 1.363.59.144.7 (r)
[ 5.779556] Register interface [wlan0] MAC: cc:4b:73:8a:fa:94
[ 5.779556]
[ 5.780697] init: plymouth-upstart-bridge main process (148) terminated with status 1
[ 5.780721] init: plymouth-upstart-bridge main process ended, respawning
[ 5.801394] wl_event_handler: was terminated
[t[ 5.805791] dhd_wl_ioctl: returning as busstate=0
[ 5.810529] bcmsdh_oob_intr_unregister: Enter
[ 5.814908] bcmsdh_oob_intr_unregister: irq is not registered
[ 5.814922] dhd_txglom_enable: enable 0
[ 5.814925] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0, txglom_bucket_size=0
[ 5.814927] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 5.814929] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[ 5.814931] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=1
[ 5.814933] sdioh_set_mode: set txglom_mode to copy
[ 5.814935] dhd_bus_devreset: WLAN OFF DONE
[ 5.814985] wifi_platform_set_power = 0
[ 5.814987] ======== PULL WL_REG_ON(-1) LOW! ========
[ 5.814989] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 5.815000] [WLAN_RFKILL]: wifi shut off power.
[ 5.815045] dhd_module_init: Exit err=0
[ 5.848378] init: ureadahead main process (139) terminated with status 5
[ 5.848479] init: plymouth-upstart-bridge main process (153) terminated with status 1
[ 5.848497] init: plymouth-upstart-bridge main process ended, respawning
[ 5.960400] random: mountall: uninitialized urandom read (12 bytes read, 92 bits of entropy available)
  • Starting Mount filesystems on boote[74G[ OK ]
  • Starting Signal sysvinit that the rootfs is mountede[74G[ OK ]
  • Starting Populate /dev filesysteme[74G[ OK ]
  • Stopping Populate /dev filesysteme[74G[ OK ]
  • Starting Fix-up /sys/kernel/debug filesysteme[74G[ OK ]
  • Stopping Fix-up /sys/kernel/debug filesysteme[74G[ OK ]
  • Starting Clean /tmp directorye[74G[ OK ]
  • Starting Populate and link to /run filesysteme[74G[ OK ]
  • Stopping Populate and link to /run filesysteme[74G[ OK ]
  • Stopping Track if upstart is running in a containere[74G[ OK ]
  • Stopping Clean /tmp directorye[74G[ OK ]
  • Starting Initialize or finalize resolvconfe[74G[ OK ]
  • Starting set console keymape[74G[ OK ]
  • Starting Signal sysvinit that virtual filesystems are mountede[74G[ OK ]
  • Starting Bridge udev events into upstarte[74G[ OK ]
  • Stopping set console keymape[74G[ OK ]
  • Starting Signal sysvinit that local filesystems are mountede[74G[ OK ]
  • Starting restore software rfkill statee[74G[ OK ]
  • Starting device node and kernel event managere[74G[ OK ]
  • Starting Signal sysvinit that remote filesystems are mountede[74G[ OK ]
  • Starting NFSv4 id ↔ name mappere[74G[ OK ]
  • Starting load modules from /etc/modulese[74G[ OK ]
  • Starting cold plug devicese[74G[ OK ]
  • Starting run fbset before lightdme[74G[ OK ]
  • Starting log initial device creatione[74G[ OK ]
  • Stopping restore software rfkill statee[74G[ OK ]
  • Stopping load modules from /etc/modulese[74G[ OK ]
  • Stopping run fbset before lightdme[74G[ OK ]
  • Starting flush early job output to logse[74G[ OK ]
  • Starting D-Bus system message buse[74G[ OK ]
  • Stopping Mount filesystems on boote[74G[ OK ]
  • Stopping flush early job output to logse[74G[ OK ]
  • Stopping cold plug devicese[74G[ OK ]
  • Stopping log initial device creatione[74G[ OK ]
  • Starting SystemD login management servicee[74G[ OK ]
  • Starting configure network device securitye[74G[ OK ]
  • Starting save udev log and update rulese[74G[ OK ]
  • Starting set console fonte[74G[ OK ]
  • Stopping save udev log and update rulese[74G[ OK ]
  • Stopping set console fonte[74G[ OK ]
  • Starting userspace bootsplashe[74G[ OK ]
  • Stopping userspace bootsplashe[74G[ OK ]
  • Starting Send an event to indicate plymouth is upe[74G[ OK ]
  • Starting system logging daemone[74G[ OK ]
  • Stopping Send an event to indicate plymouth is upe[74G[ OK ]
  • Stopping rpcsec_gss daemone[74G[ OK ]
  • Starting System V initialisation compatibilitye[74G[ OK ]
  • Starting configure virtual network devicese[74G[ OK ]
  • Starting configure network devicee[74G[ OK ]
  • Starting Mount network filesystemse[74G[ OK ]
  • Starting Upstart job to start rpcbind on boot onlye[74G[ OK ]
  • Starting Failsafe Boot Delaye[74G[ OK ]
  • Stopping Upstart job to start rpcbind on boot onlye[74G[ OK ]
  • Stopping System V initialisation compatibilitye[74G[ OK ]
  • Starting System V runlevel compatibilitye[74G[ OK ]
  • Starting anac(h)ronistic crone[74G[ OK ]
  • Starting save kernel messagese[74G[ OK ]
  • Starting Restore Sound Card Statee[74G[ OK ]
  • Starting regular background program processing daemone[74G[ OK ]
  • Stopping Restore Sound Card Statee[74G[ OK ]
  • Stopping save kernel messagese[74G[ OK ]
  • Starting RPC portmapper replacemente[74G[ OK ]
  • Stopping Mount network filesystemse[74G[ OK ]
  • Starting NSM status monitore[74G[ OK ]
  • Loading cpufreq kernel modules… e[80G
  • Starting Bridge file events into upstarte[74G[ OK ]
  • Starting Bridge socket events into upstarte[74G[ OK ]
e[74G[ OK ]
  • CPU0… e[80G * Starting NFSv4 id ↔ name mappere[74G[ OK ]
  • CPU1… e[80G * Starting NFSv4 id ↔ name mappere[74G[ OK ]
  • CPU2… e[80G * CPU3… e[80G * CPUFreq Utilities: Setting performance CPUFreq governor… e[80G
    e[74G[ OK ]
  • Starting NTP server ntpd * Starting NFSv4 id ↔ name mappere[74G[ OK ]
e[80G
e[74G[ OK ]
  • Starting NFSv4 id ↔ name mappere[74G[e[31mfaile[39;49m]
  • Stopping NFSv4 id ↔ name mappere[74G[ OK ]
  • Starting OpenSSH servere[74G[ OK ]
0
mount: can’t find /storage/sbox in /etc/fstab or /etc/mtab
e[He[J * Stopping System V runlevel compatibilitye[74G[ OK ]
void Serial::setUsbPort() AVAILABLE USB-PORTS: ()
Ubuntu 14.04.5 LTS ubuntu ttyS2
ubuntu login: root (automatic login)
Welcome to Ubuntu 14.04.5 LTS (GNU/Linux 4.4.70 armv7l)
  • Documentation: https://help.ubuntu.com/
    root@ubuntu:~# ^C
    root@ubuntu:~# ^C
    root@ubuntu:~#
    Terminating…
    Thanks for using picocom
  • kernel 5.17.6:
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 816000000HZ
periph pll = 297000000HZ
ddr pll = 396000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059bc50c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059bc70c
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059cc30c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059cc50c
storage init OK!
GetParam
Load FDT from resource image.
no key node
No pmic detect.
can’t find dts node for pwm0
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
‘boot’ does not seem to be a partition nor an address
Unable to boot:boot
try to start recovery
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x00779780)
ramdisk @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0560d1ef … OK
[ 0.000000] Linux version 5.17.6 (checho@checho-pc) (arm-linux-gnueabihf-gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #2 SMP Thu May 12 17:14:15 -03 2022
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] OF: fdt: Machine model: Firefly-RK3288
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] percpu: Embedded 16 pages/cpu s34072 r8192 d23272 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522752
[ 0.000000] Unknown kernel command line parameters “splash acpi=off apm=off mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00008000@0x00016000(back),0x00010000@0x0001e000(backup),0xc00800@0x0002e000(linuxroot) storagemedia=emmc SecureBootCheckOk=0”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Memory: 2059792K/2097152K available (12288K kernel code, 1870K rwdata, 3512K rodata, 1024K init, 449K bss, 37360K reserved, 0K cma-reserved, 1310720K highmem)
[ 0.000000] ftrace: allocating 48189 entries in 95 pages
[ 0.000000] ftrace: allocated 95 pages with 6 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3f8/0x6b4 with crng_init=0
[ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000020] Switching to timer-based delay loop, resolution 41ns
[ 0.001122] Console: colour dummy device 80x30
[ 0.001172] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.001192] pid_max: default: 32768 minimum: 301
[ 0.001279] LSM: Security Framework initializing
[ 0.001302] Yama: becoming mindful.
[ 0.001420] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001440] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002081] CPU: Testing write buffer coherency: ok
[ 0.002129] CPU0: Spectre v2: using BPIALL workaround
[ 0.002354] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.003144] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.003164] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.003281] Setting up static identity map for 0x100000 - 0x100060
[ 0.003397] rcu: Hierarchical SRCU implementation.
[ 0.003843] smp: Bringing up secondary CPUs …
[ 0.005517] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.005532] CPU1: Spectre v2: using BPIALL workaround
[ 0.007314] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.007329] CPU2: Spectre v2: using BPIALL workaround
[ 0.009077] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.009092] CPU3: Spectre v2: using BPIALL workaround
[ 0.009212] smp: Brought up 1 node, 4 CPUs
[ 0.009228] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.009241] CPU: All CPU(s) started in SVC mode.
[ 0.009890] devtmpfs: initialized
[ 0.021153] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.021387] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.021413] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.021642] pinctrl core: initialized pinctrl subsystem
[ 0.022608] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.023389] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.024945] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.025629] cpuidle: using governor ladder
[ 0.025675] cpuidle: using governor menu
[ 0.026637] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.026655] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.041915] platform ff980000.hdmi: Fixing up cyclic dependency with ff940000.vop
[ 0.042000] platform ff980000.hdmi: Fixing up cyclic dependency with ff930000.vop
[ 0.053153] rockchip-gpio ff750000.gpio: probed /pinctrl/gpio@ff750000
[ 0.053849] rockchip-gpio ff780000.gpio: probed /pinctrl/gpio@ff780000
[ 0.054531] rockchip-gpio ff790000.gpio: probed /pinctrl/gpio@ff790000
[ 0.055205] rockchip-gpio ff7a0000.gpio: probed /pinctrl/gpio@ff7a0000
[ 0.055956] rockchip-gpio ff7b0000.gpio: probed /pinctrl/gpio@ff7b0000
[ 0.056635] rockchip-gpio ff7c0000.gpio: probed /pinctrl/gpio@ff7c0000
[ 0.057317] rockchip-gpio ff7d0000.gpio: probed /pinctrl/gpio@ff7d0000
[ 0.058071] rockchip-gpio ff7e0000.gpio: probed /pinctrl/gpio@ff7e0000
[ 0.058741] rockchip-gpio ff7f0000.gpio: probed /pinctrl/gpio@ff7f0000
[ 0.082256] iommu: Default domain type: Translated
[ 0.082272] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.084444] SCSI subsystem initialized
[ 0.084642] usbcore: registered new interface driver usbfs
[ 0.084704] usbcore: registered new interface driver hub
[ 0.084751] usbcore: registered new device driver usb
[ 0.084857] videodev: Linux video capture interface: v2.00
[ 0.084907] pps_core: LinuxPPS API ver. 1 registered
[ 0.084917] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.084941] PTP clock support registered
[ 0.085350] Advanced Linux Sound Architecture Driver Initialized.
[ 0.085940] Bluetooth: Core ver 2.22
[ 0.085985] NET: Registered PF_BLUETOOTH protocol family
[ 0.085997] Bluetooth: HCI device and connection manager initialized
[ 0.086013] Bluetooth: HCI socket layer initialized
[ 0.086026] Bluetooth: L2CAP socket layer initialized
[ 0.086062] Bluetooth: SCO socket layer initialized
[ 0.086914] clocksource: Switched to clocksource arch_sys_counter
[ 0.157661] NET: Registered PF_INET protocol family
[ 0.157840] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.159000] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 12288 bytes, linear)
[ 0.159047] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.159126] TCP bind hash table entries: 8192 (order: 5, 163840 bytes, linear)
[ 0.159314] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.159420] UDP hash table entries: 512 (order: 2, 24576 bytes, linear)
[ 0.159471] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes, linear)
[ 0.159681] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.160252] RPC: Registered named UNIX socket transport module.
[ 0.160269] RPC: Registered udp transport module.
[ 0.160278] RPC: Registered tcp transport module.
[ 0.160286] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.736332] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 0.746313] Initialise system trusted keyrings
[ 0.746473] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ 0.753201] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.754651] NFS: Registering the id_resolver key type
[ 0.754681] Key type id_resolver registered
[ 0.754692] Key type id_legacy registered
[ 0.754710] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.755620] fuse: init (API version 7.36)
[ 0.850567] NET: Registered PF_ALG protocol family
[ 0.850586] Key type asymmetric registered
[ 0.850597] Asymmetric key parser ‘x509’ registered
[ 0.850771] bounce: pool size: 64 pages
[ 0.850892] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.850905] io scheduler mq-deadline registered
[ 0.850915] io scheduler kyber registered
[ 0.857402] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.857424] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.858279] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.858297] dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.859485] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.861297] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 42, base_baud = 1500000) is a 16550A
[ 0.862272] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 43, base_baud = 1500000) is a 16550A
[ 0.863180] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 44, base_baud = 1500000) is a 16550A
[ 1.876062] printk: console [ttyS2] enabled
[ 1.881707] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 45, base_baud = 1500000) is a 16550A
[ 1.893465] rockchip-vop ff930000.vop: Adding to iommu group 0
[ 1.900723] rockchip-vop ff940000.vop: Adding to iommu group 1
[ 1.911692] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d66830)
[ 1.920275] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d66830)
[ 1.928959] usbcore: registered new interface driver udl
[ 1.939328] brd: module loaded
[ 1.949147] loop: module loaded
[ 1.953013] lkdtm: No crash points registered, enable through debugfs
[ 1.962780] tun: Universal TUN/TAP device driver, 1.6
[ 1.969986] PPP generic driver version 2.4.2
[ 1.975129] usbcore: registered new interface driver rt2800usb
[ 1.981733] usbcore: registered new interface driver rndis_wlan
[ 1.988366] pegasus: Pegasus/Pegasus II USB Ethernet driver
[ 1.994647] usbcore: registered new interface driver pegasus
[ 2.001064] usbcore: registered new interface driver rtl8150
[ 2.007458] usbcore: registered new interface driver r8152
[ 2.013631] usbcore: registered new interface driver asix
[ 2.019727] usbcore: registered new interface driver ax88179_178a
[ 2.026574] usbcore: registered new interface driver cdc_ether
[ 2.033149] usbcore: registered new interface driver dm9601
[ 2.039448] usbcore: registered new interface driver smsc75xx
[ 2.045918] usbcore: registered new interface driver smsc95xx
[ 2.052391] usbcore: registered new interface driver net1080
[ 2.058771] usbcore: registered new interface driver rndis_host
[ 2.065424] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.073760] usbcore: registered new interface driver cdc_ncm
[ 2.080151] usbcore: registered new interface driver cdc_mbim
[ 2.087086] dwc2 ff540000.usb: supply vusb_d not found, using dummy regulator
[ 2.095198] dwc2 ff540000.usb: supply vusb_a not found, using dummy regulator
[ 2.167185] dwc2 ff540000.usb: DWC OTG Controller
[ 2.172467] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 2.180404] dwc2 ff540000.usb: irq 49, io mem 0xff540000
[ 2.186559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.17
[ 2.195828] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.203920] usb usb1: Product: DWC OTG Controller
[ 2.209192] usb usb1: Manufacturer: Linux 5.17.6 dwc2_hsotg
[ 2.215422] usb usb1: SerialNumber: ff540000.usb
[ 2.221188] hub 1-0:1.0: USB hub found
[ 2.225417] hub 1-0:1.0: 1 port detected
[ 2.230534] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[ 2.238673] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[ 2.386979] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 2.395116] dwc2 ff580000.usb: DWC OTG Controller
[ 2.400423] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 2.408345] dwc2 ff580000.usb: irq 50, io mem 0xff580000
[ 2.414466] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.17
[ 2.423733] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.431834] usb usb2: Product: DWC OTG Controller
[ 2.437109] usb usb2: Manufacturer: Linux 5.17.6 dwc2_hsotg
[ 2.443345] usb usb2: SerialNumber: ff580000.usb
[ 2.449094] hub 2-0:1.0: USB hub found
[ 2.453321] hub 2-0:1.0: 1 port detected
[ 2.459501] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.466805] ehci-platform: EHCI generic platform driver
[ 2.472985] usbcore: registered new interface driver cdc_acm
[ 2.479341] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.488456] usbcore: registered new interface driver cdc_wdm
[ 2.494862] usbcore: registered new interface driver usb-storage
[ 2.501687] usbcore: registered new interface driver usbserial_generic
[ 2.509037] usbserial: USB Serial support registered for generic
[ 2.515797] usbcore: registered new interface driver cp210x
[ 2.522067] usbserial: USB Serial support registered for cp210x
[ 2.528753] usbcore: registered new interface driver ftdi_sio
[ 2.535198] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.543482] usbcore: registered new interface driver keyspan
[ 2.549847] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.558639] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.566830] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.575044] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 2.583274] usbcore: registered new interface driver option
[ 2.589542] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.596935] usb 1-1: new high-speed USB device number 2 using dwc2
[ 2.597462] usbcore: registered new interface driver oti6858
[ 2.610579] usbserial: USB Serial support registered for oti6858
[ 2.617350] usbcore: registered new interface driver pl2303
[ 2.623608] usbserial: USB Serial support registered for pl2303
[ 2.630290] usbcore: registered new interface driver qcserial
[ 2.636736] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.644585] usbcore: registered new interface driver sierra
[ 2.650854] usbserial: USB Serial support registered for Sierra USB modem
[ 2.659122] usbcore: registered new interface driver iforce
[ 2.665412] usbcore: registered new interface driver xpad
[ 2.671563] usbcore: registered new interface driver usbtouchscreen
[ 2.679069] i2c_dev: i2c /dev entries driver
[ 2.686879] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 2.696965] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 2.708624] rtc-hym8563 0-0051: registered as rtc0
[ 2.714294] rtc-hym8563 0-0051: setting system clock to 2017-01-01T13:50:09 UTC (1483278609)
[ 2.737360] usbcore: registered new interface driver uvcvideo
[ 2.745961] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 2.755828] Bluetooth: HCI UART driver ver 2.3
[ 2.760823] Bluetooth: HCI UART protocol H4 registered
[ 2.766568] Bluetooth: HCI UART protocol ATH3K registered
[ 2.772681] usbcore: registered new interface driver bfusb
[ 2.778883] usbcore: registered new interface driver btusb
[ 2.788110] sdhci: Secure Digital Host Controller Interface driver
[ 2.795023] sdhci: Copyright(c) Pierre Ossman
[ 2.797787] random: fast init done
[ 2.799903] Synopsys Designware Multimedia Card Interface Driver
[ 2.810674] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.810927] dwmmc_rockchip ff0d0000.mmc: IDMAC supports 32-bit address mode.
[ 2.824894] dwmmc_rockchip ff0d0000.mmc: Using internal DMA controller.
[ 2.832296] dwmmc_rockchip ff0d0000.mmc: Version ID is 270a
[ 2.838560] dwmmc_rockchip ff0d0000.mmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[ 2.838814] hid: raw HID events driver (C) Jiri Kosina
[ 2.849603] dwmmc_rockchip ff0d0000.mmc: Failed getting OCR mask: 0
[ 2.857167] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[ 2.862455] usbcore: registered new interface driver usbhid
[ 2.862459] usbhid: USB HID core driver
[ 2.862602] ashmem: initialized
[ 2.864256] usbcore: registered new interface driver snd-usb-audio
[ 2.865634] u32 classifier
[ 2.865637] input device check on
[ 2.866085] IPVS: Registered protocols ()
[ 2.866104] IPVS: Connection hash table configured (size=4096, memory=16Kbytes)
[ 2.866194] IPVS: ipvs loaded.
[ 2.866309] Initializing XFRM netlink socket
[ 2.866567] NET: Registered PF_INET6 protocol family
[ 2.871140] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.871577] Segment Routing with IPv6
[ 2.871596] In-situ OAM (IOAM) with IPv6
[ 2.871672] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.872015] NET: Registered PF_PACKET protocol family
[ 2.872029] NET: Registered PF_KEY protocol family
[ 2.872061] Bridge firewalling registered
[ 2.872144] Bluetooth: RFCOMM socket layer initialized
[ 2.872164] Bluetooth: RFCOMM ver 1.11
[ 2.872173] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.872179] Bluetooth: HIDP socket layer initialized
[ 2.872205] 8021q: 802.1Q VLAN Support v1.8
[ 2.872220] lib80211: common routines for IEEE802.11 drivers
[ 2.872249] Key type dns_resolver registered
[ 2.872540] ThumbEE CPU extension supported.
[ 2.872547] Registering SWP/SWPB emulation handler
[ 2.872907] Loading compiled-in X.509 certificates
[ 2.881656] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 2.915285] mmc_host mmc0: card is non-removable.
[ 2.925673] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[ 2.933665] hub 1-1:1.0: USB hub found
[ 2.937661] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[ 2.939618] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d66830)
[ 2.939882] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d66830)
[ 2.939990] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.940460] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0d69d7c)
[ 2.940881] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[ 2.940943] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 2.941013] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[ 2.941512] rk_gmac-dwmac ff290000.ethernet: IRQ eth_lpi not found
[ 2.941576] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
[ 2.941678] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 2.941684] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[ 2.941689] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[ 2.941696] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
[ 2.941724] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
[ 2.941729] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 2.942114] hub 1-1:1.0: 4 ports detected
[ 2.946739] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 2.947004] rk_gmac-dwmac ff290000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[ 2.947013] rk_gmac-dwmac ff290000.ethernet: DWMAC1000
[ 2.947017] rk_gmac-dwmac ff290000.ethernet: DMA HW capability register supported
[ 2.947021] rk_gmac-dwmac ff290000.ethernet: RX Checksum Offload Engine supported
[ 2.947025] rk_gmac-dwmac ff290000.ethernet: COE Type 2
[ 2.947029] rk_gmac-dwmac ff290000.ethernet: TX Checksum insertion supported
[ 2.947033] rk_gmac-dwmac ff290000.ethernet: Wake-Up On Lan supported
[ 2.947072] rk_gmac-dwmac ff290000.ethernet: Normal descriptors
[ 2.947077] rk_gmac-dwmac ff290000.ethernet: Ring mode enabled
[ 2.947080] rk_gmac-dwmac ff290000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 2.947089] rk_gmac-dwmac ff290000.ethernet: device MAC address d2:97:32:1b:d2:86
[ 2.961756] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 3.294053] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[ 3.301755] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[ 3.323184] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 3.364631] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[ 3.372356] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[ 3.393911] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 3.442432] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[ 3.450220] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[ 3.471384] mmc_host mmc0: Bus speed (slot 0) = 187500Hz (slot req 100000Hz, actual 93750HZ div = 1)
[ 4.006743] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 4.017538] mdio_bus stmmac-0:01: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 4.031317] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 4.040732] dwmmc_rockchip ff0c0000.mmc: IDMAC supports 32-bit address mode.
[ 4.041009] dwmmc_rockchip ff0f0000.mmc: IDMAC supports 32-bit address mode.
[ 4.048680] dwmmc_rockchip ff0c0000.mmc: Using internal DMA controller.
[ 4.048698] dwmmc_rockchip ff0c0000.mmc: Version ID is 270a
[ 4.056614] dwmmc_rockchip ff0f0000.mmc: Using internal DMA controller.
[ 4.064066] dwmmc_rockchip ff0c0000.mmc: DW MMC controller at irq 34,32 bit host data width,256 deep fifo
[ 4.070259] dwmmc_rockchip ff0f0000.mmc: Version ID is 270a
[ 4.094764] dwmmc_rockchip ff0f0000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[ 4.106751] mmc_host mmc2: card is non-removable.
[ 4.222095] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 4.230783] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.231852] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.231991] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.241569] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.267485] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.269042] ALSA device list:
[ 4.277301] cfg80211: failed to load regulatory.db
[ 4.280683] No soundcards found.
[ 4.290192] dw-apb-uart ff690000.serial: forbid DMA for kernel console
[ 4.298006] Waiting for root device /dev/mmcblk2p7…
[ 4.335586] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[ 4.346745] mmc2: new high speed MMC card at address 0001
[ 4.353340] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[ 4.362332] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8
[ 4.368604] mmcblk2boot0: mmc2:0001 AJTD4R 4.00 MiB
[ 4.375351] mmcblk2boot1: mmc2:0001 AJTD4R 4.00 MiB
[ 4.381984] mmcblk2rpmb: mmc2:0001 AJTD4R 4.00 MiB, chardev (246:0)
[ 4.448820] List of all partitions:
[ 4.452733] 0100 4096 ram0
[ 4.452738] (driver?)
[ 4.459613] b300 15267840 mmcblk2
[ 4.459622] driver: mmcblk
[ 4.467233] b301 4096 mmcblk2p1 2d230000-0000-4e50-8000-07bf00004ea9
[ 4.467239]
[ 4.477274] b302 4096 mmcblk2p2 2c170000-0000-4472-8000-6173000065f3
[ 4.477280]
[ 4.487316] b303 4096 mmcblk2p3 4b650000-0000-487c-8000-2fb100007d14
[ 4.487322]
[ 4.497353] b304 32768 mmcblk2p4 b4590000-0000-4111-8000-70a100007eb5
[ 4.497358]
[ 4.507389] b305 32768 mmcblk2p5 8c520000-0000-4728-8000-3a6c0000247d
[ 4.507394]
[ 4.517426] b306 32768 mmcblk2p6 fe460000-0000-440c-8000-363a00007e15
[ 4.517431]
[ 4.527463] b307 2094080 mmcblk2p7 614e0000-0000-4b53-8000-1d28000054a9
[ 4.527468]
[ 4.537499] b308 12989423 mmcblk2p8 4a510000-0000-4d08-8000-507d00003353
[ 4.537503]
[ 4.547540] b310 4096 mmcblk2boot0
[ 4.547545] (driver?)
[ 4.555139] b320 4096 mmcblk2boot1
[ 4.555144] (driver?)
[ 4.562748] No filesystem could mount root, tried:
[ 4.562751] ext3
[ 4.568213] ext2
[ 4.570351] ext4
[ 4.572500] squashfs
[ 4.574644] vfat
[ 4.577191] iso9660
[ 4.579336] hfsplus
[ 4.581776] fuseblk
[ 4.584213] udf
[ 4.586649]
[ 4.590357] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,7)
[ 4.599786] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.17.6 #2
[ 4.606399] Hardware name: Rockchip (Device Tree)
[ 4.611650] Backtrace:
[ 4.614379] dump_backtrace from show_stack+0x20/0x24
[ 4.620034] r7:c0f19d84 r6:00000000 r5:60000093 r4:c0fd2ed8
[ 4.626352] show_stack from dump_stack_lvl+0x48/0x54
[ 4.631997] dump_stack_lvl from dump_stack+0x14/0x1c
[ 4.637641] r5:00000000 r4:c13d4498
[ 4.641628] dump_stack from panic+0xf8/0x300
[ 4.646495] panic from mount_block_root+0x188/0x210
[ 4.652045] r3:00000000 r2:00000000 r1:c1969ea4 r0:c0f19d84
[ 4.658364] r7:c0f256e0
[ 4.661185] mount_block_root from mount_root+0x80/0x1a0
[ 4.667123] r10:000001b7 r9:c113e864 r8:c106aa18 r7:c13d4000 r6:c113e844 r5:c113e874
[ 4.675869] r4:00000007
[ 4.678691] mount_root from prepare_namespace+0x154/0x190
[ 4.684822] r10:000001b7 r9:c113e864 r8:c106aa18 r7:c13d4000 r6:c113e844 r5:c113e874
[ 4.693569] r4:c13d4028
[ 4.696390] prepare_namespace from kernel_init_freeable+0x200/0x260
[ 4.703491] r5:00000008 r4:c120fcd4
[ 4.707478] kernel_init_freeable from kernel_init+0x24/0x140
[ 4.713903] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0c73848
[ 4.722649] r4:c120af40
[ 4.725470] kernel_init from ret_from_fork+0x14/0x2c
[ 4.731115] Exception stack(0xc1969fb0 to 0xc1969ff8)
[ 4.736747] 9fa0: 00000000 00000000 00000000 00000000
[ 4.745885] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.755021] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 4.762399] r5:c0c73848 r4:00000000
[ 4.766388] CPU3: stopping
[ 4.769408] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.17.6 #2
[ 4.776021] Hardware name: Rockchip (Device Tree)
[ 4.781271] Backtrace:
[ 4.783998] dump_backtrace from show_stack+0x20/0x24
[ 4.789647] r7:c120b7d4 r6:c19e9ec0 r5:60000193 r4:c0fd2ed8
[ 4.795965] show_stack from dump_stack_lvl+0x48/0x54
[ 4.801610] dump_stack_lvl from dump_stack+0x14/0x1c
[ 4.807254] r5:00000003 r4:00000004
[ 4.811240] dump_stack from do_handle_IPI+0x1ac/0x258
[ 4.816981] do_handle_IPI from ipi_handler+0x24/0x30
[ 4.822627] r7:c120b7d4 r6:00000014 r5:c1804c80 r4:c18eb200
[ 4.828945] ipi_handler from handle_percpu_devid_irq+0x68/0x10c
[ 4.835659] handle_percpu_devid_irq from handle_irq_desc+0x2c/0x3c
[ 4.842666] r9:c19e9ec0 r8:c119ba70 r7:c1987f54 r6:f0802000 r5:00000004 r4:c18f0000
[ 4.851315] handle_irq_desc from generic_handle_domain_irq+0x68/0x74
[ 4.858511] generic_handle_domain_irq from gic_handle_irq+0x74/0x84
[ 4.865612] r5:c119b454 r4:c120b7d4
[ 4.869598] gic_handle_irq from generic_handle_arch_irq+0x30/0x44
[ 4.876506] r7:c1987f54 r6:ffffffff r5:00000000 r4:c1987f20
[ 4.882816] generic_handle_arch_irq from __irq_svc+0x50/0x68
[ 4.889235] Exception stack(0xc1987f20 to 0xc1987f68)
[ 4.894870] 7f20: 00000742 00000003 00000003 c0118be0 c19e9ec0 00000000 c120af90 00000008
[ 4.904007] 7f40: c119ba70 410fc0d1 00000000 c1987f7c c1987f80 c1987f70 c01076f0 c01076e0
[ 4.913143] 7f60: 60000013 ffffffff
[ 4.917025] r5:60000013 r4:c01076e0
[ 4.921012] arch_cpu_idle from default_idle_call+0x40/0x5c
[ 4.927242] default_idle_call from do_idle+0x128/0x2a0
[ 4.933081] r5:00000000 r4:00000000
[ 4.937068] do_idle from cpu_startup_entry+0x28/0x2c
[ 4.942713] r9:410fc0d1 r8:0000406a r7:c13d4344 r6:10c0387d r5:00000003 r4:00000097
[ 4.951361] cpu_startup_entry from secondary_start_kernel+0xf4/0x110
[ 4.958557] secondary_start_kernel from 0x1016d4
[ 4.963813] r5:00000051 r4:019ac06a
[ 4.967800] CPU2: stopping
[ 4.970819] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.17.6 #2
[ 4.977432] Hardware name: Rockchip (Device Tree)
[ 4.982682] Backtrace:
[ 4.985409] dump_backtrace from show_stack+0x20/0x24
[ 4.991058] r7:c120b7d4 r6:c19e9480 r5:60000193 r4:c0fd2ed8
[ 4.997376] show_stack from dump_stack_lvl+0x48/0x54
[ 5.003021] dump_stack_lvl from dump_stack+0x14/0x1c
[ 5.008665] r5:00000002 r4:00000004
[ 5.012652] dump_stack from do_handle_IPI+0x1ac/0x258
[ 5.018393] do_handle_IPI from ipi_handler+0x24/0x30
[ 5.024038] r7:c120b7d4 r6:00000014 r5:c1804c80 r4:c18eb200
[ 5.030356] ipi_handler from handle_percpu_devid_irq+0x68/0x10c
[ 5.037069] handle_percpu_devid_irq from handle_irq_desc+0x2c/0x3c
[ 5.044075] r9:c19e9480 r8:c119ba70 r7:c1985f54 r6:f0802000 r5:00000004 r4:c18f0000
[ 5.052724] handle_irq_desc from generic_handle_domain_irq+0x68/0x74
[ 5.059921] generic_handle_domain_irq from gic_handle_irq+0x74/0x84
[ 5.067022] r5:c119b454 r4:c120b7d4
[ 5.071009] gic_handle_irq from generic_handle_arch_irq+0x30/0x44
[ 5.077917] r7:c1985f54 r6:ffffffff r5:00000000 r4:c1985f20
[ 5.084235] generic_handle_arch_irq from __irq_svc+0x50/0x68
[ 5.090655] Exception stack(0xc1985f20 to 0xc1985f68)
[ 5.096288] 5f20: 000008b2 00000002 00000002 c0118be0 c19e9480 00000000 c120af90 00000004
[ 5.105425] 5f40: c119ba70 410fc0d1 00000000 c1985f7c c1985f80 c1985f70 c01076f0 c01076e0
[ 5.114560] 5f60: 60000013 ffffffff
[ 5.118451] r5:60000013 r4:c01076e0
[ 5.122437] arch_cpu_idle from default_idle_call+0x40/0x5c
[ 5.128665] default_idle_call from do_idle+0x128/0x2a0
[ 5.134504] r5:00000000 r4:00000000
[ 5.138491] do_idle from cpu_startup_entry+0x28/0x2c
[ 5.144136] r9:410fc0d1 r8:0000406a r7:c13d4344 r6:10c0387d r5:00000002 r4:00000097
[ 5.152785] cpu_startup_entry from secondary_start_kernel+0xf4/0x110
[ 5.159981] secondary_start_kernel from 0x1016d4
[ 5.165236] r5:00000051 r4:019ac06a
[ 5.169214] CPU1: stopping
[ 5.172234] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.17.6 #2
[ 5.178847] Hardware name: Rockchip (Device Tree)
[ 5.184098] Backtrace:
[ 5.186825] dump_backtrace from show_stack+0x20/0x24
[ 5.192474] r7:c120b7d4 r6:c19e8a40 r5:60000193 r4:c0fd2ed8
[ 5.198791] show_stack from dump_stack_lvl+0x48/0x54
[ 5.204436] dump_stack_lvl from dump_stack+0x14/0x1c
[ 5.210080] r5:00000001 r4:00000004
[ 5.214058] dump_stack from do_handle_IPI+0x1ac/0x258
[ 5.219799] do_handle_IPI from ipi_handler+0x24/0x30
[ 5.225445] r7:c120b7d4 r6:00000014 r5:c1804c80 r4:c18eb200
[ 5.231762] ipi_handler from handle_percpu_devid_irq+0x68/0x10c
[ 5.238475] handle_percpu_devid_irq from handle_irq_desc+0x2c/0x3c
[ 5.245481] r9:c19e8a40 r8:c119ba70 r7:c1983f54 r6:f0802000 r5:00000004 r4:c18f0000
[ 5.254129] handle_irq_desc from generic_handle_domain_irq+0x68/0x74
[ 5.261326] generic_handle_domain_irq from gic_handle_irq+0x74/0x84
[ 5.268427] r5:c119b454 r4:c120b7d4
[ 5.272414] gic_handle_irq from generic_handle_arch_irq+0x30/0x44
[ 5.279321] r7:c1983f54 r6:ffffffff r5:00000000 r4:c1983f20
[ 5.285630] generic_handle_arch_irq from __irq_svc+0x50/0x68
[ 5.292050] Exception stack(0xc1983f20 to 0xc1983f68)
[ 5.297684] 3f20: 000007b0 00000001 00000001 c0118be0 c19e8a40 00000000 c120af90 00000002
[ 5.306821] 3f40: c119ba70 410fc0d1 00000000 c1983f7c c1983f80 c1983f70 c01076f0 c01076e0
[ 5.315957] 3f60: 60000013 ffffffff
[ 5.319848] r5:60000013 r4:c01076e0
[ 5.323835] arch_cpu_idle from default_idle_call+0x40/0x5c
[ 5.330063] default_idle_call from do_idle+0x128/0x2a0
[ 5.335901] r5:00000000 r4:00000000
[ 5.339888] do_idle from cpu_startup_entry+0x28/0x2c
[ 5.345532] r9:410fc0d1 r8:0000406a r7:c13d4344 r6:10c0387d r5:00000001 r4:00000097
[ 5.354182] cpu_startup_entry from secondary_start_kernel+0xf4/0x110
[ 5.361378] secondary_start_kernel from 0x1016d4
[ 5.366632] r5:00000051 r4:019ac06a
[ 5.370625] —[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,7) ]—
Regards!
I’m so grateful for your article, it was truly eye-catching and insightful. Free Popular FCP_FML_AD-7.4 Exams to help you enhance your IT skills. Wishing you good luck!
