RK3399 ffmpeg - librga/mpp errors
I’m using the GPT ubuntu 20.04 build and have tried to read a udp mpegts stream by using:
ffplay -fflags nobuffer -f:v mpegts -an -probesize 8192 udp://0.0.0.0:8554
Instead I get alot of repeating errors that appear to originate from librga:
rga_api version 1.7.0_[1]
RgaBlit(1387) RGA_BLIT fail: Invalid argument
RgaBlit(1388) RGA_BLIT fail: Invalid argument
fd-vir-phy-hnd-format[22, (nil), (nil), (nil), 0]
rect[0, 0, 640, 360, 640, 368, 10, 0]
f-blend-size-rotation-col-log-mmu[0, 0, 0, 0, 0, 0, 1]
fd-vir-phy-hnd-format[0, 0x7f0c009ca0, (nil), (nil), 0]
rect[0, 0, 640, 360, 640, 384, 11, 0]
This output the user patamaters when rga call blit fail
[h264_rkmpp @ 0x7f14008d00] Doing slow software conversion
This also appears when trying to simply play an mp4. i.e from learnopencv VideoReadWriteDisplay/chaplin,mp4
ffplay chaplin.mp4
At startup it also shows the following error in mpp:
mpp[1875]: mpp_info: mpp version: 8a85dc5d author: Herman Chen 2022-03-14 [mpp_enc]: Fix stuck on reset
async mode encoder
mpp[1875]: mpp_rt: NOT found ion allocator
mpp[1875]: mpp_rt: found drm allocator
mpp[1875]: hal_h264d_rkv_reg: control info: fmt 7, w 640, h 360
mpp[1875]: mpp_buf_slot: set frame info: w 640 h 360 hor 640 ver 368
mpp[1875]: mpp_dec: setting default w 640 h 360 h_str 640 v_str 368
[h264_rkmpp @ 0x7f14008d00] Decoder noticed an info change (640x360), format=0
librga fail to get driver version! Legacy mode will be enabled.
Thank you for any help in getting this working properly
Maybe the firmware or file system you are using is older, what board are you using? I will upload it to google drive to share with you.
Thank you for responding. I have a Station P1 board and have flashed with the ROC-RK3399-PC-PLUS firmware from:
https://en.t-firefly.com/doc/download/78.html
This is from my current setup:
firefly@firefly:~$ ffgo version
OS: Ubuntu 20.04.4 LTS
MODEL: Firefly roc-rk3399-pc PLUS
FIREFLY: v2.10-62-g087b2b2
DATE: 20211228-1443
KERNEL: Linux version 4.4.194+ (jincheng@jincheng-PC) (local/new/internal-gitlab/rk3399/firefly: bcd190d4221dcefe664a1fe9aebe17819db54b22) (gcc
version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #12 SMP Wed Dec 29 13:42:43 CST 2021
If you have a more recent firmware I would appreciate it.
Some additional Data…
  • The log that I placed at the beginning of this thread was after flashing the ROC-RK3399-PC-PLUS-UBUNTU-20.04_DESKTOP-GPT-20211229-1348.img.7z and then performing a sudo apt update, sudo apt upgrae. the rga_api changed from 1.3 .0 to 1.7.0
  • Although I get the same error messages, If I simply attempt to play a mp4 file prior to the update/upgrade (/usr/local/bin/test_ffmpeg.sh … ffplay -vcodec h264_rkmpp -i /usr/local/test.mp4) it fails and will lockup the board
  • Running the same test script (/usr/local/bin/test_ffmpeg.sh) will also fail if I reflash the board with Ubuntu 18.04 ( ROC-RK3399-PC-PLUS-UBUNTU-18.04_DESKTOP-GPT-20211228-1710.img.7z).
  • By performing the updata/upgrade it also upgrades the mpp driver from:
    mpp[1222]: mpp_info: mpp version: 49f29006 author: Jeffy Chen 2021-08-04 [drm]: Add mmap flag detection
    to
    mpp[4293]: mpp_info: mpp version: 8a85dc5d author: Herman Chen 2022-03-14 [mpp_enc]: Fix stuck on reset async mode encoder
jbholtz_bd17 Posted at 5/27/2022 10:48
  • The log that I placed at the beginning of this thread was after flashi …
I tested the third item and there was a problem, let me see how to solve it.
root@firefly:~# cat /usr/local/bin/test_ffmpeg.sh
#1. test benchmark
#ffmpeg -benchmark -loglevel 48 -vcodec h264_rkmpp -i /usr/local/test.mp4 -map 0:v:0 -f null -
#2. play
#ffplay -vcodec h264_rkmpp -i /usr/local/test.mp4
#3. decode to yuv
ffmpeg -y -c:v h264_rkmpp -i /usr/local/test.mp4 -an -vf hwdownload,format=nv12,format=yuv420p out.yuv
I have the same problem with lots of BlitRGA errors and warning messages added to syslog and journalctl when using gstreamer with mpph264enc
My gstreamer command takes a MP4 file, decodes it and re-encodes it.
gst-launch-1.0 filesrc location=source.mp4 ! decodebin ! textoverlay text="2023-04-01" ! mpph264enc ! h264parse ! filesink location=encode_mpp.264
The error messages that fill the syslog / journalctl ar
fd-vir-phy-hnd-format[47, (nil), (nil), (nil), 0]
rect[0, 0, 1920, 1080, 1920, 1088, 2560, 0]
fd-vir-phy-hnd-format[44, (nil), (nil), (nil), 0]
fd-vir-phy-hnd-format[52, (nil), (nil), (nil), 0]
This is on a RK3568 board from Firefly.
Linux firefly 4.19.206 #369 SMP Thu Dec 16 10:17:57 CST 2021 aarch64 aarch64 aarch64 GNU/Linux
gst-launch-1.0 --version
GStreamer 1.16.2
gst-inspect-1.0 mpp264enc
Factory Details:
Rank primary + 1 (257)
Long-name Rockchip Mpp H264 Encoder
Klass Codec/Encoder/Video
Description Encode video streams via Rockchip Mpp
Author Randy Li randy.li@rock-chips.com, Jeffy Chen jeffy.chen@rock-chips.com
Plugin Details:
Name rockchipmpp
Description Rockchip Mpp Video Plugin
Filename /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstrockchipmpp.so
Version 1.14.4
License LGPL
Source module gst-rockchip
Binary package GStreamer Rockchip Plug-ins
Origin URL Unknown package origin
cat /root-ro/usr/lib/aarch64-linux-gnu/pkgconfig/rockchip_mpp.pc
prefix=/usr
exec_prefix=${prefix}
libdir=${prefix}/lib/aarch64-linux-gnu
includedir=${prefix}/include
Description: Rockchip Media Process Platform
Requires.private:
Version: 1.3.8
Libs: -L${libdir} -lrockchip_mpp
Libs.private:
Cflags: -I${includedir}
mpp_info_test
mpp[3792273]: mpp_info_test: normal version log:
mpp[3792273]: mpp_info: mpp version: 8a85dc5 author: Herman Chen 2022-03-14 [mpp_enc]: Fix stuck on reset async mode encoder
mpp[3792273]: mpp_info_test: history version log:
mpp[3792273]: mpp_info: mpp version history 10:
mpp[3792273]: mpp_info: 8a85dc5 author: Herman Chen 2022-03-14 [mpp_enc]: Fix stuck on reset async mode encoder (HEAD → master, origin/develop)
mpp[3792273]: mpp_info: c07169d author: Jeffy Chen 2022-03-11 [misc]: Fix a few compile warnings and errors
mpp[3792273]: mpp_info: da6654c author: Yandong Lin 2022-03-10 [h264d_init]: fix h264 video with 10bit parse err
mpp[3792273]: mpp_info: f02fd23 author: Herman Chen 2022-03-09 [mpp_enc]: Use meta with default value to get info
mpp[3792273]: mpp_info: 72a6118 author: Herman Chen 2022-03-09 [mpp_meta]: Add mpp_meta_get with default value
mpp[3792273]: mpp_info: 98ac9b2 author: Hongjin Li 2022-03-09 [h264d_dpb]: Fix h264 video flicker issue
mpp[3792273]: mpp_info: 22caf3f author: toby.zhang 2022-03-08 [hal_vepu580]: Add scene_mode to distinguish ipc and none ipc scene.
mpp[3792273]: mpp_info: 2eb15d5 author: Herman Chen 2022-03-08 [mpp_enc_cfg]: Add tuning scene mode check
mpp[3792273]: mpp_info: ff40ff4 author: Herman Chen 2022-03-07 [mpp_enc_cfg]: Add fine tuning paramter define
mpp[3792273]: mpp_info: 3dea9cc author: zj 2022-03-07 [mpp_soc]: rk3368 has h264 decoder with vdpu1_2160p
I truly appreciate your article; the content really left me in awe! Enhance your IT expertise and download Reliable test C-P2W12-2311 study guide for free. Good luck to all!
I’m amazed at how powerful your article is, thank you for sharing! The C-SIGPM-2403 Examcollection free dumps platform offers detailed material at no cost, aimed at assisting you.
