DDR Version 1.00 20150318
Channel a: DDR3 200MHz
Memory OK
U-Boot 2014.10-RK3288-10 (Feb 27 2016 - 11:51:00)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
Adding bank:0000000000000000(0000000040000000)
128 MiB
storage init OK!
GetParam
checpower key: bank-0 pin-5
pmic:act8846
#Boot ver: 2016-02-27#2.19
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x005f0b68)
ramdisk @ 0x05bf0000 (0x00275548)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561b713 … OK
Add bank:0000000000000000, 0000000040000000
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
check parameter success
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
代码和镜像从下面链接获取的,
android 5.1 sdk 和固件
http://developer.t-firefly.com/thread-4424-1-1.html
上面是重新编译android5.1中内核,使用 mkbootimg 生成 linux-boot.img, 打包成统一固件后烧写。
换成官方的android5.1固件,烧写完后,也出现上面的问题。
