Hello,
I’m trying make Automatic compilation for Linux for AIO-3568J mainboard with core board Core-3568
I use this link
https://wiki.t-firefly.com/en/Core-3568J/ubuntu_compile.html
I make 2.2.4. Automatic compilation
./build.sh
Please see content of Config-file BoardConfig.mk:
[b]source $CUR_DIR/firefly-rk3568-buildroot.mk
# Target arch
export RK_ARCH=arm64 # 64-bit ARM
# Uboot defconfig
export RK_UBOOT_DEFCONFIG=firefly_rk3568 # u-boot configuration
# Kernel defconfig
export RK_KERNEL_DEFCONFIG=firefly_linux_defconfig # kernel configuration
# Kernel dts
export RK_KERNEL_DTS=firefly-rk3568-aioj # dts file
# parameter for GPT table
export RK_PARAMETER=parameter-ubuntu-fit.txt # partition table
# rootfs image path
export RK_ROOTFS_IMG=ubuntu_rootfs/rk356x_ubuntu_rootfs.img # filesystem path
# Kernel dts
export RK_KERNEL_DTS=rk3568-firefly-aioj-cam_2ms2mf
# PRODUCT MODEL
export RK_PRODUCT_MODEL=AIO_3568J[/b]
After ./build.sh i got error:
============Start building uboot============
TARGET_UBOOT_CONFIG=firefly_rk3568
grep: .config: No such file or directory
configs/android6.0-rk3399_defconfig
ERROR: No configs/firefly_rk3568_defconfig
ERROR: Running build_uboot failed!
ERROR: exit code 1 from line 557:
./make.sh $RK_UBOOT_DEFCONFIG $UBOOT_COMPILE_COMMANDS
There is no /configs directory in my /rk356x_linux_release_20211019 directory
Can you help me with that ?
