Hello,
I’m using ROC-RK3588S-PC_Debian11_v1.0.0c_220610.7z for work, but it doesn’t support wireguard vpn.
Could you build a new kernel with wireguard protocol support?
Now when I try to up the wireguard interface, I get the message:
wg-quick up wg0
[#] ip link add wg0 type wireguard
Error: Unknown device type.
Unable to access interface: Protocol not supported
[#] ip link delete dev wg0
Cannot find device “wg0”
Hello,
Could you make a new full Debian 11 build for ROC-RK3588S-PC with wireguard vpn support?
I really need it, I really look forward to your help.
Thank you in advance.
daijh,
Good afternoon, why are you silent? I didn’t buy this PC board just to admire it. I have big plans for this board in the field of industrial automation, I’m going to buy dozens of pieces of it, but without wireguard it is not suitable for these purposes. Please comment on my suggestion, I need a new version of Debian 11 with wireguard support. Additionally, I will inform the seller of this product, because in my opinion the product is not very high quality. Perhaps I will claim compensation due to inadequate technical support.
daijh Posted at 7/14/2022 09:38
I think the extboot.img I provided has been tested and works. If Hdmi cannot display, please uploa …
Dear comrade, could you conduct the testing more thoroughly? On my 2K monitor (2560x1440), the HDMI signal disappears after the system starts.
If the monitor is disconnected from the 3588s (hdmi cable is disconnected), and after starting the system, reconnect the monitor, the system will work with a maximum resolution of 1920x1080.
Most likely, this version of the kernel does not support resolutions higher than 1920x1080.
Please fix it.
I don’t have a your“2560x1440”screen and can’t test it (I tested on a 4k TV and 2k resolution is available). If you are not willing to provide the log then I cannot analyze it. I can only make some guesses, try this extboot.img
I don’t have a your“2560x1440”screen and can’t test it (I tested on a 4k TV and 2k resolutio …
My seller (Embedded Development Store) has already sent me a link to the new kernel, as I understand it - this is your job. I am very pleased with the result, the 2K monitor is working and wireguard is also working. For complete happiness, I ask you to add f2fs support to the kernel so that the userdata partition works on f2fs, can you do this?
Drive Mad is a 2D driving game where players control a vehicle across multiple obstacle-filled levels. Unlike traditional racing games, Drive Mad focuses on balance and physics, requiring precision and patience to complete each stage successfully.
It really broadened my horizons. I owe my promotion and raise to the Cloud-Deployment-and-Operations regular updates questions, and today I’m sharing them for free with all of you!
