I successfully compiled Ubuntu firmware and now i want to upgrade firmware on my Core-3568 module.
Previously i successfulyl upgraded it via USB cable from Android to Ubuntu 18.04 using thuis link: https://wiki.t-firefly.com/en/Core-3568J/03-upgrade_firmware.html#
I used Windows firmware upgrade mode, DriverAssitant_v5.1.1, RKDevTool_Release_v2.95 and all was OK, Ubuntu 18.04 works fine.
Now i try to make upgrade in the same way, but use my own compiled image AIO-3568J_Rk356x_v1.2.4a_220706.img
But now i have a problem - when i start ADB utility in adb shell with next command:
adb.exe reboot loader
ADB cannot recognize device ! Deriver is installed successfully like before, but ADB don’t see device, i even tryed
adb.exe devices
What i’m doing wrong ?
ADB (Android Debug Bridge) working only on Android device ? But as i mentioned before, i upgraded Core-3568 firmware from Android to Ubuntu.
May be i should try use second MaskRom Upgrade Mode ?
yes, i pressed Recovery button.
but read what i have wrote before :
But now i have a problem - when i start ADB utility in adb shell with next command: adb.exe reboot loader
ADB cannot recognize device ! Driver is installed successfully like before, but ADB don’t see device, i even tryed
adb.exe devices
I feel so motivated after reading this article, thanks for sharing! I reached my career goals thanks to the New FCSS_SDW_AR-7.4 exam dumps exam, and now you can access it for free!
The viewpoints in the article are very innovative, and they’ve given me many ideas. Free Valid test L5M1 questions vce materials available—wishing you all success in your exams!
I really appreciate your article, it has been truly eye-opening. The Latest XSOAR-Engineer exam cram materials content is very helpful, and you don’t need to pay for it.
