Booting from SD card
Hello,
I am following the directions to boot Ubuntu 18.04 from sd card, using the SD Disk tool and the ubuntu image on the google drive. However, when I plug the sd card into my board, Android boots up instead of ubuntu. Any idea of how to fix this? I followed the steps in the wiki, so I don’t think I’m missing anything there. Is there a way for me to force it to boot from the card?
Firefly didn’t provide ubuntu18 firmware, where did you get it?
I believe the cause of the problem is the wrong firmware.
Please use ROC-RK3588S-PC Ubuntu20.04 firmware to make SD card.
Liuth Posted at 7/19/2022 10:04
I believe the cause of the problem …
Now getting a new error- tried two different downloads (most current and second most current) off of the google drive from https://en.t-firefly.com/doc/download/142.html , extracted with 7-zip, but when I hit create, it gives me opening firmware failds
ejaybennett Posted at 7/20/2022 02:11
Now getting a new error- tried two different downloads (most current and second most current) off …
Maybe you need to format sd card to FAT32 first
And try sd card that is 8 or 16G, bigger than 16G may have problems, the sd tool is bad in compatible :frowning:
This article is mind-blowing, thank you for sharing! 350-601 latest exam cram provides excellent materials, and they are free to access.
I’m thankful for this inspiring article, it’s truly motivational! Free C-THR94-2505 valid guide files questions to help you prepare. Wishing you all success!
Booting from an SD card can be a game-changer for testing new OS versions or running lightweight systems without touching your main drive. Just make sure your device supports it and that the SD card is fast enough—Class 10 or UHS cards usually give the best performance. Also, double-check the boot order in your BIOS or UEFI to avoid startup issues. Naturopathic Doctor
