空板,用AndroidTool_Release_v2.33工具,直接烧录update.img固件,android4.4,loader:2.17
失败日志如下:
Connecting to COM3…
Connected.
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Die Bus-Width=16 Size=2048MB
Channel b: DDR3 200MHz
Memory OK
Memory OK
serial_init 1
ChipType = 8
SDC_BusRequest: CMD=8 DATA BUSY 1609
SdmmcInit=0 400
…FlashInit enter…
FtlMallocOffset = 8040 8000
FtlMallocOffset = 10040 8000
FtlMallocOffset = 11040 1000
FtlMallocOffset = 19040 8000
FtlMallocOffset = 1a040 1000
1:200 0 7f7f05 22
…NandcInit enter…
0:1200 0 7f7f05 22
gNandcVer = 6
SDC_BusRequest: CMD=8 SDC_RESP_TIMEOUT 1778
SDC_BusRequest: CMD=5 SDC_RESP_TIMEOUT 1778
SDC_BusRequest: CMD=55 SDC_RESP_TIMEOUT 1778
mmc Ext_csd, ret=0 ,
Ext[226]=20, bootSize=2000,
Ext[215]=3, Ext[214]=a3, Ext[213]=e0, Ext[212]=0,cap =3a3e000
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=3a3e000
FwPartOffset=2000 , 0
UsbHook 653406
powerOn 654418
SRX
U-Boot 2014.10-RK3288-02 (Nov 26 2014 - 09:28:44)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
Adding bank:0000000000000000(0000000100000000)
128 MiB
storage init OK!
GetParam
W: Invalid Parameter’s tag (0x00000000)!
Invalid parameter
Invalid parameter
Invalid parameter
Invalid parameter
Invalid parameter
Invalid parameter
Invalid parameter
Invalid parameter
failed to find part:boot
failed to find part:resource
failed to prepare fdt from resource!
no adc node
can’t find dts node for act8846
can’t find dts node for rk808
can’t find dts node for rk818
#Boot ver: 2014-11-26#2.17
empty serial no.
Writing env to storage…
done
reboot to rockusb.
SRX
CPU: rk3288
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
