RK3568-PC Unresponsive
When I load Ubuntu20.04 Firmware image I get ‘failed to load’ every time and getting a ‘Test Device Fail’ in red.
When I try to run any of the read back commands in the advanced tab I get failures.
I had posted in another thread, but figured I should start my own issue.
Steps Im Following:
  • Go to the 3568-PC Downloads Page
  • Navigate to the Google Drive Ubuntu Page
  • Download “Ubuntu20.04” Folder
  • Copy Ubuntu20.04 folder to root of C/: drive.
  • Unzip and navigate to the windows folder
  • Run DriverAssistant_v5.11
  • Change Language CFG for RKDevTool_Release_v2.92
  • Run RKDevTool.exe
  • Select “Upgrade Firmware” tab
  • Click “Firmware” button
  • Navigate to downloaded Ubuntu folder and select IMG file that was included. (ROC-RK3568-PC_Ubuntu20.04-r21156_v1.2.4a_220519.img)
  • When that IMG file is loaded the following logs occur:
    • Download Boot Start
    • Download Boot Success
    • Wait For Maskrom Start
    • Wait for Maskrom Success
    • Test Device Start
    • Test Device Fail
    • Note: Communication issues, Certainly please check usb, Comple…(cant see the remainder)
As of right now it seems like the unit is not starting at all. I can connect and flash the unit but it no longer has any output on the video and no lights indicate any activity.
Would there be any reason the device fails the test? If I run ReadFlashID or ReadFlashInfo or ReadChip info or really any of the read back info it just fails. I believe once i sort what is happening here, I should have a successful flash. For some reason the unit just seems like its not leaving MaskRom mode.
try this
https://wiki.t-firefly.com/en/ROC-RK3568-PC/03-upgrade_firmware_with_flash.html#the-method-from-firefly
Liuth Posted at 7/23/2022 09:40
try this
When I follow those steps it fails early on with the following error:
 - Download Boot Start
 - Download Boot Success
 - Wait For Maskrom Start
 - Wait for Maskrom Success
 - Test Device Start
 - Test Device Fail
I also keep getting the error: “Get FlashInfo Fail”
mckay115 Posted at 7/23/2022 10:04
 - Download Boot Star ...
there may be a hardware damage, contact seller for repairing
Your article was very refreshing, thank you for this amazing perspective. The C1000-182 valid braindumps sheet content is excellent, and you can get it without any cost.
I can’t overstate how much I learned from that article. The Portworx-Enterprise-Professional new test guide files test questions are free—good luck with your exam preparations!
Fantastic work, instantly deserving of a like. C-THR97-2505 valid exam camp questions test questions—your key to advancing in your career and boosting your salary!
It was incredibly enriching. The AIP-210 exam questions fee questions were the turning point in my career—now, I’m sharing them with you for free!
This is truly a first-rate article, thank you for sharing. Free Latest 300-740 braindumps files resources available. Best of luck to all!
