Ubuntu Gnome Linux is not working
I done everything from instruction:
https://wiki.t-firefly.com/en/Core-3588J/linux_compile_ubuntu.html
SDK version 0.0.1 (maybe we can get newer version?).
  1. When I use Ubuntu core minimal - system is working normal, when I tried to use Ubuntu Gnome then suddenly it turned out that the system is read-only - there was no such problem with the minimal image.
  2. Also video is not working over HDMI but there is no information about it in DMESG.
  3. Also I have a question about how to expand rootfs partition in flash? There is 7 partitions here and one partition after rootfs that’s why I cant expand it with GPARTED for example.
    Sum up: there is 3 problems:
  4. Read only ubuntu rootfs:
  5. Tiny rootfs:
  6. Not working HDMI (but it is working with Android).
try to update SDK, the newest SDK seems to be v1.0.0c, v0.0.1 is too old
read the README-IMPORTANT file in google drive where you download the SDK
It is impossible to download 0.1.0 from this link because google says:
This file cannot be retrieved because the download quota has been reached
sorry, maybe you got a wrong link
I send you the right SDK link through PM
Please don’t leak this link to someone else, SDK is part of after-sales service
Thank you!
The problems with read-only filesystem and small rootfs is not gone.
It is something like this:
  1. If there is very small rootfs - there is also lots of errors, some services cannot start and system remain RW, GUI is working but I can barely do something with the system that has 0B free memory;
  2. I tried artificially expand rootfs partition size with GPARTED - after this system starting without GUI and also without lots of services because of read-only file system. I can avoid this problem after start with this command:
    mount -o remount,rw /
    But services that has not started from the boot - I can’t start it. Like Wayland and Gnome, for example.
    SDK version 1.0.0 and the latest ubuntu from your repo.
I think it may be a problem with boot options in U-BOOT, but I also cant stay in uboot while booting - CTRL+C (like it said) is not working…
I really don’t know what to do and why rootfs booting in read-only…
There is no such problem with debian 11 - coming out that it is a problem with your ubuntu. But your debian is Chinese language and there are lots of problems with the network here - DNS is not working and I can’t see any web sites from there, but ping exact IP is working normally (for example google - 8.8.8.8).
Also we afrid thet GPU is not working too because demo video (1080@60) became a slide show…
Hi v.redin!
What contains in bootargs of your build? I have the same problem and fix it by adding “rw”, like this: bootargs = “earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 ro root=PARTLABEL=rootfs rootfstype=ext4 rootwait overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1”;
Also, does your kernel source directory (in SDK) contains “ramdisk.img” file? If no, you should copy them from old version.
I also thought so, but there is no root pattern in my uboot vars. There is no RO pattern too. And there is no problem with similar uboot but booting debian. The problem is only with Ubuntu.
My printenv flie:
=> printenv
arch=arm
autoload=no
baudrate=1500000
board=evb_rk3588
board_name=evb_rk3588
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=mmc1 mmc0 mtd2 mtd1 mtd0 usb0 pxe dhcp
bootargs=storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal  storagenode=/mmc@fe2c0000
bootcmd=boot_android ${devtype} ${devnum};boot_fit;bootrkp;run distro_bootcmd;
bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_mtd0=setenv devnum 0; run mtd_boot
bootcmd_mtd1=setenv devnum 1; run mtd_boot
bootcmd_mtd2=setenv devnum 2; run mtd_boot
bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=0
cpu=armv8
devnum=1
devplist=3
devtype=mmc
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
eth1addr=da:d7:72:14:64:b7
ethaddr=d6:d7:72:14:64:b7
fdt_addr_r=0x0a100000
fileaddr=0xedf00000
filesize=0x1f34a
kernel_addr_c=0x05480000
kernel_addr_r=0x00400000
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
mtd_boot=if mtd_blk dev ${devnum}; then setenv devtype mtd; run scan_dev_for_boot_part; fi
partitions=uuid_disk=${uuid_gpt_disk};name=uboot,start=8MB,size=4MB,uuid=${uuid_gpt_loader2};name=trust,size=4M,uuid=${uuid_gpt_atf};name=misc,size=4MB,uuid=${uuid_gpt_misc};name=resource,size=16MB,uuid=${uuid_gpt_resource};name=kernel,size=32M,uuid=${uuid_gpt_kernel};name=boot,size=32M,bootable,uuid=${uuid_gpt_boot};name=recovery,size=32M,uuid=${uuid_gpt_recovery};name=backup,size=112M,uuid=${uuid_gpt_backup};name=cache,size=512M,uuid=${uuid_gpt_cache};name=system,size=2048M,uuid=${uuid_gpt_system};name=metadata,size=16M,uuid=${uuid_gpt_metadata};name=vendor,size=32M,uuid=${uuid_gpt_vendor};name=oem,size=32M,uuid=${uuid_gpt_oem};name=frp,size=512K,uuid=${uuid_gpt_frp};name=security,size=2M,uuid=${uuid_gpt_security};name=userdata,size=-,uuid=${uuid_gpt_userdata};
pxefile_addr_r=0x00600000
ramdisk_addr_r=0x0a200000
rkimg_bootdev=if mmc dev 1 && rkimgtest mmc 1; then setenv devtype mmc; setenv devnum 1; echo Boot from SDcard;elif mmc dev 0; then setenv devtype mmc; setenv devnum 0;elif mtd_blk dev 0; then setenv devtype mtd; setenv devnum 0;elif mtd_blk dev 1; then setenv devtype mtd; setenv devnum 1;elif mtd_blk dev 2; then setenv devtype mtd; setenv devnum 2;elif rknand dev 0; then setenv devtype rknand; setenv devnum 0;elif rksfc dev 0; then setenv devtype spinand; setenv devnum 0;elif rksfc dev 1; then setenv devtype spinor; setenv devnum 1;elsesetenv devtype ramdisk; setenv devnum 0;fi;
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x00500000
serial#=e84ddba3be4d1555
soc=rockchip
stderr=serial,vidconsole
stdout=serial,vidconsole
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
vendor=rockchip
Environment size: 4188/32764 bytes
arch=arm
autoload=no
baudrate=1500000
board=evb_rk3588
bootdelay=0
cpu=armv8
devnum=1
devplist=3
devtype=mmc
fileaddr=0xedf00000
filesize=0x1f34a
soc=rockchip
vendor=rockchip
I also tried to add rw to boot_prefixes var like this:
boot_prefixes=/ /boot/ rw
Everything is OK with the debian. DNS is easy to fix, language fixing in mk-base-debian.sh
GPU is working normaly - there is a lot of problem with the base videoplayer, but with MPV everything is OK - 2160@60 has good performance.
Thanks for everyone - the problem was solved
This article is brilliant beyond words, thank you for sharing. Get the New exam CIS-SM camp questions test questions for free—your key to the next level in your career!
Your article is truly stunning, thank you for sharing! CIS-Discovery valid test objectives pdf offers free access to a wealth of helpful material, supporting your learning goals.
Thank you for the article; it really piqued my interest. The Ok-Life-Accident-and-Health-or-Sickness-Producer latest dumps questions helped me land a promotion and salary increase. It’s free for everyone now. Best of luck with your promotions!
The content is top-notch, liking it right now. The free JN0-750 Training Tools test materials are available for all. Good luck!
