In u-boot everything is working great - scsi scan shows my disk and I can work with it. After I booting in debian 11 - I can’t see my sata disks. After I rebooting to U-BOOT - there is no sata disks here to - scsi scan says nothing. Then I can reflash my uboot to sdcard and scsi can see my sata after this until the moment I boot into debian 11. After booting the Debian - system can’t see my sata disks until the next u-boot reflashing…
What can it be? Device Tree is correct due to: https://wiki.t-firefly.com/en/Core-3588J/usage_sata.html
I discovered, that there is the same problem with USB. Moreover - when you plugging USB - kernel sees it but there is no new devices in /dev/ .
There is the same with sata - I see, that system acknowledged it, but there is no such device appeared in /dev
You compiled modules, but lib module on running debian is empty. You should explain in your guide (on wiki) or automate inserting compiled modules to debian compiled rootfs.
Even you SDK 1.0.1b is not building yet: boot_merger ver 1.2
Info:Pack loader ok.
pack loader okay! Input: /home/firefly/rockchip/rk3588/check/rkbin/RKBOOT/RK3588MINIALL.ini
/home/firefly/rockchip/rk3588/check/u-boot
ERROR: pack uboot.img failed! fit/uboot.itb actual: 2107392 bytes, max limit: 2097152 bytes
ERROR: Running build_uboot failed!
ERROR: exit code 1 from line 630:
./make.sh $UBOOT_COMPILE_COMMANDS CROSS_COMPILE=$CROSS_COMPILE
Your article is outstanding, thank you for sharing! Thanks to the Premium JN0-253 exam, I got promoted and received a salary boost. It’s free now. Wishing you all a successful career advancement!
This article is a masterpiece in its own right, thank you for sharing. I advanced with the L5M6 accurate answers, earning both a promotion and salary increase. Now, it’s free for everyone. Best wishes to all!
