Can't boot from SATA/NVMe/USB
I cant’ understand - why I can’t boot from SATA for example, using your SDK.
I have done everything like always - created bootable SATA device, plug it, then:
setenv bootcmd 'scsi scan; scsi dev 0; ext4load scsi 0:1 0x00400000 /boot/Image-5.10.66;ext4load scsi 0:1 0x0a100000 /boot/rk3588-firefly-itx-3588j.dtb;setenv bootargs console=ttyFIQ0 root=/dev/sda1 rw rootwait; booti 0x00400000 - 0x0a100000'
run bootcmd
And I can see that bootargs var is ignoring. Then, to prove it, I wrote “console=nothing”, but it booting in my SDCARD like always. How I can see - bootargs var completely ignoring.
I tried to find kernel option CMDLINE_OVERRIDE that can cause such effect, but there is no such option you using to compile kernel. So, I can’t understand what to do…
I can’t use such an option like hardcoding my BOOTCMD in Linux Device Tree, because I need to create hot boot from each bootable device - I need to have an ability to boot from SD/SATA/NVMe/USB/EMMC - without recompiling something.
Also I need GUI for this process…
Die PECB NIS-2-Directive-Lead-Implementer Zertifizierungsprüfung ist heutztage in der konkurrenzfähigen IT-Branche immer beliebter geworden. Immer mehr Leute haben die PECB NIS-2-Directive-Lead-Implementer Prüfung abgelegt. Aber ihre Schwierigkeit nimmt doch nicht ab. Es ist schwer, die PECB NIS-2-Directive-Lead-Implementer Prüfung zu bestehen, weil sie sowieso eine autoritäre Prüfung ist, die Computerfachkenntnisse und die Fähigkeiten zur Informationstechnik prüft. Viele Leute haben viel Zeit und Energie auf die PECB NIS-2-Directive-Lead-Implementer Zertifizierungsprüfung aufgewendet.
Your article was a pleasant surprise, thank you for sharing it. Here are the free PEGACPBA24V1 reliable braindumps sheet materials. Best of luck to everyone!
The content is excellent, so I’m liking it now. Taking on the FCSS_EFW_AD-7.6 valid exam simulator online exam soon. Hope I nail it!
Thank you for sharing this incredible article, it’s truly breathtaking! Wishing you the best in your exams! Here are the free C_ARSOR_2404 latest exam pattern questions.
This article is truly top-notch, thank you for sharing it with me. CKS vce test simulator contains comprehensive material, available at no cost to support your learning.
