Linux distribution image
Hi, can someone share a ready-made Linux distribution with a working HDMI (an image with a file system, bootloader, kernel, etc.) for this board?
Edit 1: It is possible without a bootloader, only the root partition with the /boot directory, in which the kernel and the device tree are located.
Maybe you can check this: https://en.t-firefly.com/doc/download/91.html
zooora111 Posted at 8/19/2022 14:33
Yes, I have already examined everything, the system is not going as I need it, but there is no ready-made one, so I ask if anyone has a ready-made and working one.
Paquq Posted at 8/19/2022 19:41
Yes, I have already examined everything, the system is not going as I need it, but there is no rea …
Hey, do you want a mainline kernel?
Javier Posted at 8/20/2022 10:57
Hello, I need a kernel on which the console is running via HDMI and a working frame buffer, so I also need an up-to-date device tree and a kernel boot command
After reading this article, I feel that I’ve made progress in both thinking and actions. The C_P2WFI_2023 exam lab questions helped me secure my promotion and raise. It’s free now for everyone. Best of luck with your career!
The article is so thought-provoking, thank you for your valuable share! Boost your IT knowledge with free CPHQ latest test simulator. Best of luck to everyone!
Manchmal bedeutet ein kleinem Schritt ein großem Fortschritt des Lebens. Die Salesforce Plat-Arch-203 Prüfung scheit nur ein kleinem Test zu sein, aber der Vorteil der Prüfungszertifizierung der Salesforce Plat-Arch-203 für Ihr Arbeitsleben darf nicht übersehen werden. Diese internationale Zertifikat beweist Ihre ausgezeichnete IT-Fähigkeit. Neben Salesforce Plat-Arch-203 sind auch andere Zertifizierungsprüfung sehr wichtig, deren neueste Unterlagen können Sie auch auf unserer Webseite finden.
