because CONFIG_NETFILTER_XT_MATCH_COMMENT is not set, iptables can’t use -m comment, k3s faild to set iptables rules. so I need to compile a custom kernel
make -j 8 will get a vmlinux, but It’s size is 300MB+, /boot space is only 232MB
The actual files installed to /boot are typically vmlinuz (compressed kernel), System.map, and initramfs, which are much smaller. However, even these might exceed your 232MB free space if /boot already has old kernels or large files. sprunki retake
Get ready to swing for the fences in Baseball Bros IO - a lightning-fast, cartoon-style multiplayer baseball game that blends strategy, speed, and pure fun.
To solve the issue, don’t use the large vmlinux file—instead, compile and use the compressed bzImage (via make bzImage), which is much smaller and suitable for /boot. Then install modules with make modules_install, copy bzImage to /boot, and update your bootloader (like update-grub). Make sure CONFIG_NETFILTER_XT_MATCH_COMMENT is enabled in your .config (set to y or m) so iptables can use -m comment, which K3s requires. ragdoll hit
Oh, looks like someone’s having trouble with their kernel config. “CONFIGNETFILTERXTMATCHCOMMENT not set” huh? Hope they figure it out! Good luck debugging! Maybe once it’s sorted, they can relax with something fun like the AI Video Generator — or even mess around with the AI Kissing Video Generator for a laugh after all that terminal stress
Oh, looks like someone’s having trouble with their kernel config. “CONFIGNETFILTERXTMATCHCOMMENT not set” huh? Hope they figure it out! Good luck debugging! Maybe once it’s sorted, they can relax with something fun like the AI Video Generator from Lanta AI for a laugh after all that terminal stress
Okay, looks like someone’s having a bit of trouble with their Firefly board. That CONFIGNETFILTER thingy sounds kinda technical. Hope they figure it out! Maybe they’ll find some help through communities on Reddit List . And while waiting on a fix, a round of Queens Game or Tango Game might be just the break they need!
The content is impressive, definitely worthy of a like. The DP-300 reliable cram materials helped me secure a promotion and salary raise. Now it’s free to all. Best wishes for your career advancements!
That’s a tricky situation! Compiling a custom kernel can be a bit of a rabbit hole. Seeing as space is tight, before diving too deep, have you considered trimming down the kernel config? Disabling unnecessary modules might save a lot of space. It’s a bit like how Granny used to prune her garden – only keep what you need to flourish! Maybe look into options besides iptables as well? Good luck, hope you find a solution!
