Hi everyone, recently i get a Firefly ROC 3566-PC. I flashed it with Ubuntu 18.04, and i want create an UART communication with one microcontroller. I’m using this Embedded board as central PC, to work with AI using the RKNN, but, i need an UART communication between this board, and microcontroller board (Designed by own)..
In the /dev/, i see /dev/ttyFQI0 and /dev/ttyS0, but, i dont get any information in the pins of attached for UART.
I’m new using these microprocessor, i used raspberry and microcontrollers, but in this case, i’m new in this plaftform for embedded systems.
I recent see about modify dts files in kernel, is necessary? pyserial is compatible with this board?
You need to modify dts to enable serial port function. The serial ports available on the expansion port(J1) are uart3/uart5/uart9.
It will be easier to configure uart3, as follows:
&uart3 {
status = “okay”;
Schematic: https://en.t-firefly.com/doc/download/93.html#other_385
EDIT: I solved my problem
The article gave me so many new ideas. Wishing you all the best! Here’s the free OGBA-101 valid test camp materials material.
I really appreciate your article, it had a profound effect on me. The rich content of PSP valid exam vce free is available for free, designed to assist you in your studies.
I really appreciate this inspiring article, thank you for sharing! Let’s do this! Wishing for success in the 100% JN0-452 exam coverage exam!
