install wireguard on ubuntu minimal fails
When I try to install wireguard as follows I get an error:
root@firefly:~# apt-get install wireguard
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
  wireguard-dkms wireguard-tools
Suggested packages:
  openresolv | resolvconf
The following NEW packages will be installed:
  wireguard wireguard-dkms wireguard-tools
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/344 kB of archives.
After this operation, 2093 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Selecting previously unselected package wireguard-dkms.
(Reading database ... 101021 files and directories currently installed.)
Preparing to unpack .../wireguard-dkms_1.0.20201112-1~20.04.1_all.deb ...
Unpacking wireguard-dkms (1.0.20201112-1~20.04.1) ...
Selecting previously unselected package wireguard-tools.
Preparing to unpack .../wireguard-tools_1.0.20200513-1~20.04.2_arm64.deb ...
Unpacking wireguard-tools (1.0.20200513-1~20.04.2) ...
Selecting previously unselected package wireguard.
Preparing to unpack .../wireguard_1.0.20200513-1~20.04.2_all.deb ...
Unpacking wireguard (1.0.20200513-1~20.04.2) ...
Setting up wireguard-dkms (1.0.20201112-1~20.04.1) ...
Loading new wireguard-1.0.20201112 DKMS files...
Building for 5.10.66
Building initial module for 5.10.66
Error!  The /var/lib/dkms/wireguard/1.0.20201112/5.10.66/aarch64/dkms.conf for module wireguard includes a BUILD_EXCLUSIVE directive which
does not match this kernel/arch.  This indicates that it should not be built.
Skipped.
Setting up wireguard-tools (1.0.20200513-1~20.04.2) ...
wg-quick.target is a disabled or a static unit, not starting it.
Setting up wireguard (1.0.20200513-1~20.04.2) ...
How can I solve the problem?
GoShikenは、Plat-Admn-301-JPNの実際のテストの品質を非常に重視しています。 すべての製品は厳格な検査プロセスを受けます。 さらに、さまざまな種類のPlat-Admn-301-JPN学習資料間でランダムチェックが行われます。 Plat-Admn-301-JPN学習教材の品質はあなたの信頼に値します。 試験を準備するための最も重要なことは、重要なポイントを確認することです。 優れたPlat-Admn-301-JPN試験問題により、合格率は他の受験者よりもはるかに高くなっています。 Plat-Admn-301-JPNのSalesforce Certified Platform Administrator II (Plat-Admn-301日本語版)試験の準備にはショートカットがあります。
I’m absolutely sold on this content, liking it now. Sending positive vibes for the New GCIH exam book exam – wish me luck!
The viewpoints in the article have been very insightful, and I’ve learned a great deal. The D-PSC-DY-23 test question questions are the key to success—get them for free and unlock your promotion!
It was a truly rewarding and enlightening piece of writing. About to face the Real SOA-C03 Exams exam – hoping for good results!
