Hello.
I can’t find the schematics on Core-3399Pro-JD4 v1.3.
I have only schematics on MB-JD4-RK3399_3399PRO v1.1.
My question is about i2c1. I see two TCS4525 and one TCS4526 on Core-3399Pro-JD4.
One TCS4525 and one TCS4526 is connected to i2c0. I see that in device tree file rk3399pro-firefly-aiojd4.dts and using i2cdetect utility. i2c address is 0x1c for TCS4525 and 0x10 for TCS4526. I can not find second TCS4525 in device tree file.
I looking for analogous board based on rk3399pro and saw that board have also two TCS4525 and one TCS4526. Second TCS4525 is connected to i2c1. With i2cdetect utility I see device with 0x1c address on i2c1, but schematics on MB-JD4-RK3399_3399PRO have ALC5640 codec on i2c1 and also with address 0x1c.
There are two TCS4525, but one is not actually used. Just refer to the dts.
895816513 Posted at 10/12/2022 09:29
I looked at the schematics on tb-rk3399prod_33101_201812172.pdf (from https://www.mouser.com/pdfDocs/tb-rk3399prod_33101_201812172.pdf).
The second TCS4525 chip provides NPU_VDD_S0 (sheet 22).
Do you have the schematics for Core-3399Pro-JD4?
If it’s okey then send me please an email to andymaltsev@mail.ru or provide a link.
Thanks for the answer.
I tried to remove resistor R102 from the mb board near pin 39 of ALC5640 (page 9 mb-jd4-rk3399_3399pro-v11-20190.pdf) and the device with address 0x1c on i2c1 disappeared. So it’s a codec chip ALC5640. The question about the second TCS4525 on Core-3399Pro-JD4 remained.
IT업계에 종사하는 분들은 치열한 경쟁을 많이 느낄것입니다. 치열한 경쟁속에서 자신의 위치를 보장하는 길은 더 많이 배우고 더 많이 노력하는것 뿐입니다.국제적으로 인정받은 IT인증자격증을 취득하는것이 제일 중요한 부분이 아닌가 싶기도 합니다. 다른 분이 없는 자격증을 내가 소유하고 있다는 생각만 해도 뭔가 안전감이 느껴지지 않나요? 더는 시간낭비하지 말고Fast2test의Network Appliance인증 NS0-528덤프로Network Appliance인증 NS0-528시험에 도전해보세요.
It was one of the most beneficial pieces I’ve read in a while. Free PRINCE2-Foundation latest braindumps book materials—unlock promotions and higher salary potential!
