Type: Self-Compiled Firmware
SDK Package Name: firefly_rk3588_android12.0_git_20220311
Modification Content: Enable Google Play
Log: FireflyLogs.zip
I am trying to compile the Android 12 firmware using the instructions found here: https://wiki.t-firefly.com/en/RO … 12.0_firmware.html.
I have completed upto step 3.1.1.1 without error. After that step I make a change.
I would like to Enable Google Play Services. To do this I tried changing line 86 in /RK3588_Android12.0/device/rockchip/rk3588/BoardConfig.mk.
From
"BUILD_WITH_GOOGLE_MARKET := false"
To
"BUILD_WITH_GOOGLE_MARKET := true"
After making this change I try running step 3.2.1.1:
have you solved this?
I found that somehow when I install a fresh android12 from firefly, i download 3 files in my download folder-
GMS, Framework and playstore.
But after installig it just I only get developer notification " failed to post notification on channel null"
Jetpacks and propeller hats can assist you in navigating doodle jump challenging sections. Utilize them to soar over groups of enemies or unstable platforms.
