ROC-RK3399-PC Pro, wifi and bluetooth doesn't work
Type: Self-Compiled Firmware
SDK Package Name: firefly-sdk-20200629
Modification Content: rootfs: ubuntu 20.04
kernel: 4.4
Log: dmesg_44pro_0.zip
I have the ROC-RK3399-PC Pro board, but I can’t find any information on which device tree to use to build the kernel. When I try to compile it with different rk3399pro-* trees, in all of them wifi and bluetooth don’t work!
And which wireless driver should I choose in kernel?
Here is dmesg:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194 (build@vm-LCoreRep) (neotek: 2190803a4f2022) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #51 SMP Tue Jan 17 01:19:16 CST 2023
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] On node 0 totalpages: 1007616
[    0.000000]   DMA zone: 15864 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 1007616 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ec6000 s46312 r8192 d31512 u86016
[    0.000000] pcpu-alloc: s46312 r8192 d31512 u86016 alloc=21*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 991752
[    0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal  androidboot.slot_suffix= androidboot.serialno=e3e23f15f8a446da  ro rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0xf7e7d000-0xf7ebd000] (0MB)
[    0.000000] Memory: 3921896K/4030464K available (14526K kernel code, 1890K rwdata, 5696K rodata, 1216K init, 2008K bss, 108568K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
                   vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
                     .init : 0xffffff8009450000 - 0xffffff8009580000   (  1216 KB)
                     .text : 0xffffff8008080000 - 0xffffff8008eb0000   ( 14528 KB)
                   .rodata : 0xffffff8008eb0000 - 0xffffff8009450000   (  5760 KB)
                     .data : 0xffffff8009580000 - 0xffffff8009758808   (  1891 KB)
                   vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
                             0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
                   fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
                   PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
                   memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @f2c80000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x00000000f2c10000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x00000000f2c20000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.002364] Console: colour dummy device 80x25
[    0.002809] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[    0.003800] pid_max: default: 32768 minimum: 301
[    0.004339] Security Framework initialized
[    0.004810] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.005452] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006943] Initializing cgroup subsys io
[    0.007354] Initializing cgroup subsys memory
[    0.007799] Initializing cgroup subsys devices
[    0.008231] Initializing cgroup subsys freezer
[    0.008675] Initializing cgroup subsys perf_event
[    0.009130] Initializing cgroup subsys net_prio
[    0.009569] Initializing cgroup subsys pids
[    0.010003] ftrace: allocating 52028 entries in 204 pages
[    0.146454] sched-energy: Sched-energy-costs installed from DT
[    0.147022] CPU0: update cpu_capacity 401
[    0.147466] ASID allocator initialised with 32768 entries
[    0.151450] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.152945] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.155393] Detected VIPT I-cache on CPU1
[    0.155432] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.155469] CPU1: using LPI pending table @0x00000000f2ed0000
[    0.155531] CPU1: update cpu_capacity 401
[    0.155535] CPU1: Booted secondary processor [410fd034]
[    0.156424] Detected VIPT I-cache on CPU2
[    0.156459] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.156496] CPU2: using LPI pending table @0x00000000f2f00000
[    0.156554] CPU2: update cpu_capacity 401
[    0.156558] CPU2: Booted secondary processor [410fd034]
[    0.157421] Detected VIPT I-cache on CPU3
[    0.157454] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.157490] CPU3: using LPI pending table @0x00000000f2f50000
[    0.157546] CPU3: update cpu_capacity 401
[    0.157549] CPU3: Booted secondary processor [410fd034]
[    0.158431] Detected PIPT I-cache on CPU4
[    0.158458] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.158498] CPU4: using LPI pending table @0x00000000f2f90000
[    0.158536] CPU4: update cpu_capacity 1024
[    0.158540] CPU4: Booted secondary processor [410fd082]
[    0.159239] Detected PIPT I-cache on CPU5
[    0.159267] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.159306] CPU5: using LPI pending table @0x00000000f2fc0000
[    0.159346] CPU5: update cpu_capacity 1024
[    0.159349] CPU5: Booted secondary processor [410fd082]
[    0.159454] Brought up 6 CPUs
[    0.171815] SMP: Total of 6 processors activated.
[    0.172266] CPU features: detected feature: GIC system register CPU interface
[    0.172955] CPU features: detected feature: 32-bit EL0 Support
[    0.173515] CPU: All CPU(s) started at EL2
[    0.173947] alternatives: patching kernel code
[    0.175862] devtmpfs: initialized
[    0.195570] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.196504] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.197549] xor: measuring software checksum speed
[    0.207712]    8regs     :  2856.000 MB/sec
[    0.217767]    8regs_prefetch:  2564.000 MB/sec
[    0.227821]    32regs    :  3208.000 MB/sec
[    0.237875]    32regs_prefetch:  2848.000 MB/sec
[    0.238304] xor: using function: 32regs (3208.000 MB/sec)
[    0.238826] pinctrl core: initialized pinctrl subsystem
[    0.239543] regulator-dummy: no parameters
[    0.241141] Failed to find legacy iommu devices
[    0.241963] NET: Registered protocol family 16
[    0.246666] cpuidle: using governor ladder
[    0.250679] cpuidle: using governor menu
[    0.251063] Registered FIQ tty driver
[    0.251945] vdso: 2 pages (1 code @ ffffff8008eb6000, 1 data @ ffffff8009584000)
[    0.252670] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.253843] DMA: preallocated 1024 KiB pool for atomic allocations
[    0.270833] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.270908] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.270983] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.271056] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.271125] gpiochip_add_data: registered GPIOs 128 to 159 on device: gpio4
[    0.278668] console [pstore-1] enabled
[    0.279021] pstore: Registered ramoops as persistent store backend
[    0.279599] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.283538] console [ttyFIQ0] enabled
[    0.284223] bootconsole [uart0] disabled
[    0.285158] Registered fiq debugger ttyFIQ0
[    0.335499] raid6: int64x1  gen()   468 MB/s
[    0.352524] raid6: int64x1  xor()   412 MB/s
[    0.369675] raid6: int64x2  gen()   675 MB/s
[    0.386744] raid6: int64x2  xor()   601 MB/s
[    0.403818] raid6: int64x4  gen()   972 MB/s
[    0.420884] raid6: int64x4  xor()   667 MB/s
[    0.438032] raid6: int64x8  gen()   789 MB/s
[    0.455072] raid6: int64x8  xor()   628 MB/s
[    0.472195] raid6: neonx1   gen()   964 MB/s
[    0.489267] raid6: neonx1   xor()   675 MB/s
[    0.506382] raid6: neonx2   gen()  1277 MB/s
[    0.523459] raid6: neonx2   xor()   984 MB/s
[    0.540529] raid6: neonx4   gen()  1726 MB/s
[    0.557622] raid6: neonx4   xor()  1181 MB/s
[    0.574723] raid6: neonx8   gen()  1687 MB/s
[    0.591809] raid6: neonx8   xor()  1240 MB/s
[    0.592191] raid6: using algorithm neonx4 gen() 1726 MB/s
[    0.592670] raid6: .... xor() 1181 MB/s, rmw enabled
[    0.593115] raid6: using intx1 recovery algorithm
[    0.594699] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vccadc-ref[0]'
[    0.594726] vcc1v8_sys: 1800 mV
[    0.594901] reg-fixed-voltage vccadc-ref: vcc1v8_sys supplying 1800000uV
[    0.594957] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3v3-sys[0]'
[    0.594974] vcc3v3_sys: 3300 mV
[    0.595137] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[    0.595193] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcca-0v9[0]'
[    0.595212] reg-fixed-voltage vcca-0v9: Looking up vin-supply from device tree
[    0.595345] vcca_0v9: supplied by vcc3v3_sys
[    0.595765] vcca_0v9: 900 mV
[    0.595918] reg-fixed-voltage vcca-0v9: vcca_0v9 supplying 900000uV
[    0.596086] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc5v0-host-regulator[0]' - status (0)
[    0.596137] vcc5v0_host: no parameters
[    0.596300] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[    0.596437] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc_hub_en-regulator[0]' - status (0)
[    0.596481] vcc_hub_en: no parameters
[    0.596630] reg-fixed-voltage vcc_hub_en-regulator: vcc_hub_en supplying 0uV
[    0.596797] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-wifi[0]' - status (0)
[    0.596843] vcc_wifi: 5000 mV
[    0.597012] reg-fixed-voltage vcc-wifi: vcc_wifi supplying 5000000uV
[    0.597145] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-pcie[0]' - status (0)
[    0.597188] vcc_pcie: 5000 mV
[    0.597344] reg-fixed-voltage vcc-pcie: vcc_pcie supplying 5000000uV
[    0.597482] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-sd[0]' - status (0)
[    0.597518] vcc_sd: 3300 mV
[    0.597688] reg-fixed-voltage vcc-sd: vcc_sd supplying 3300000uV
[    0.597744] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc5v0-sys[0]'
[    0.597772] vcc5v0_sys: 5000 mV
[    0.597923] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[    0.597974] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    0.597991] vcc_phy: no parameters
[    0.598150] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV
[    0.598291] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-lcd-regulator[0]' - status (0)
[    0.598335] vcc_lcd: no parameters
[    0.598494] reg-fixed-voltage vcc-lcd-regulator: vcc_lcd supplying 0uV
[    0.598630] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc_mipi[0]' - status (0)
[    0.598668] vcc_mipi: no parameters
[    0.598850] reg-fixed-voltage vcc_mipi: vcc_mipi supplying 0uV
[    0.598976] of_get_named_gpiod_flags: parsed 'gpio' property of node '/dvdd-1v2[0]' - status (0)
[    0.599013] dvdd_1v2: no parameters
[    0.599172] reg-fixed-voltage dvdd-1v2: dvdd_1v2 supplying 0uV
[    0.599305] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fan-regulator[0]' - status (0)
[    0.599346] fan_enable: no parameters
[    0.599511] reg-fixed-voltage fan-regulator: fan_enable supplying 0uV
[    0.599572] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/poe-12v[0]'
[    0.599590] poe_12v: 12000 mV
[    0.599748] reg-fixed-voltage poe-12v: poe_12v supplying 12000000uV
[    0.599855] rockchip-pinctrl pinctrl: pin gpio4-27 already requested by vcc-wifi; cannot claim for vcc3v3-ngff
[    0.600736] rockchip-pinctrl pinctrl: pin-155 (vcc3v3-ngff) status -22
[    0.601321] rockchip-pinctrl pinctrl: could not request pin 155 (gpio4-27) from group vcc3v3-ngff-en  on device rockchip-pinctrl
[    0.602344] reg-fixed-voltage vcc3v3-ngff: Error applying setting, reverse things back
[    0.603106] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-ngff[0]' - status (0)
[    0.603124] vcc3v3_ngff: GPIO 155 is already used
[    0.603136] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    0.603159] vcc3v3_ngff: unable to resolve supply
[    0.603169] vcc3v3_ngff: 3300 mV
[    0.603302] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    0.603325] vcc3v3_ngff: regulator get failed, ret=-517
[    0.603813] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    0.603834] vcc3v3_ngff: unable to resolve supply
[    0.603845] reg-fixed-voltage vcc3v3-ngff: vcc3v3_ngff supplying 3300000uV
[    0.603919] rockchip-pinctrl pinctrl: pin gpio1-17 already requested by vcc-pcie; cannot claim for vcc3v3-pcie
[    0.604797] rockchip-pinctrl pinctrl: pin-49 (vcc3v3-pcie) status -22
[    0.605381] rockchip-pinctrl pinctrl: could not request pin 49 (gpio1-17) from group vcc3v3-pcie-en  on device rockchip-pinctrl
[    0.606391] reg-fixed-voltage vcc3v3-pcie: Error applying setting, reverse things back
[    0.607147] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie[0]' - status (0)
[    0.607163] vcc3v3_pcie: GPIO 49 is already used
[    0.607175] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    0.607197] vcc3v3_pcie: unable to resolve supply
[    0.607206] vcc3v3_pcie: 3300 mV
[    0.607339] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    0.607362] vcc3v3_pcie: regulator get failed, ret=-517
[    0.607849] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    0.607871] vcc3v3_ngff: unable to resolve supply
[    0.607880] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    0.607901] vcc3v3_pcie: unable to resolve supply
[    0.607912] reg-fixed-voltage vcc3v3-pcie: vcc3v3_pcie supplying 3300000uV
[    0.608607] iommu: Adding device ff650000.vpu_service to group 0
[    0.609233] iommu: Adding device ff660000.rkvdec to group 1
[    0.609834] iommu: Adding device ff8f0000.vop to group 2
[    0.610402] iommu: Adding device ff900000.vop to group 3
[    0.610963] iommu: Adding device ff910000.rkisp1 to group 4
[    0.611553] iommu: Adding device ff920000.rkisp1 to group 5
[    0.612562] rk_iommu ff650800.iommu: can't get sclk
[    0.613265] rk_iommu ff660480.iommu: can't get sclk
[    0.613923] rk_iommu ff8f3f00.iommu: can't get sclk
[    0.614525] rk_iommu ff903f00.iommu: can't get sclk
[    0.615147] rk_iommu ff914000.iommu: can't get sclk
[    0.615744] rk_iommu ff924000.iommu: can't get sclk
[    0.616567] SCSI subsystem initialized
[    0.617071] libata version 3.00 loaded.
[    0.617277] usbcore: registered new interface driver usbfs
[    0.617806] usbcore: registered new interface driver hub
[    0.618372] usbcore: registered new device driver usb
[    0.619109] media: Linux media interface: v0.10
[    0.619551] Linux video capture interface: v2.00
[    0.620043] pps_core: LinuxPPS API ver. 1 registered
[    0.620489] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.621315] PTP clock support registered
[    0.622813] Advanced Linux Sound Architecture Driver Initialized.
[    0.623858] Bluetooth: Core ver 2.21
[    0.624199] NET: Registered protocol family 31
[    0.624608] Bluetooth: HCI device and connection manager initialized
[    0.625176] Bluetooth: HCI socket layer initialized
[    0.625620] Bluetooth: L2CAP socket layer initialized
[    0.626084] Bluetooth: SCO socket layer initialized
[    0.627035] nfc: nfc_init: NFC Core ver 0.1
[    0.627445] NET: Registered protocol family 39
[    0.627979] rockchip-cpuinfo cpuinfo: Serial		: e3e23f15f8a446da
[    0.629394] clocksource: Switched to clocksource arch_sys_counter
[    0.682108] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.683211] NET: Registered protocol family 2
[    0.684056] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.684970] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    0.686477] TCP: Hash tables configured (established 32768 bind 32768)
[    0.687176] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    0.687944] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    0.688961] NET: Registered protocol family 1
[    0.689675] RPC: Registered named UNIX socket transport module.
[    0.690203] RPC: Registered udp transport module.
[    0.690641] RPC: Registered tcp transport module.
[    0.691063] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.691659] PCI: CLS 0 bytes, default 64
[    0.692608] Trying to unpack rootfs image as initramfs...
[    1.109824] Freeing initrd memory: 8656K
[    1.110986] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.111827] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.115961] Initialise system trusted keyring
[    1.124680] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.126006] NFS: Registering the id_resolver key type
[    1.126496] Key type id_resolver registered
[    1.126874] Key type id_legacy registered
[    1.127251] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.128555] ntfs: driver 2.1.32 [Flags: R/W].
[    1.129329] fuse init (API version 7.23)
[    1.130040] SGI XFS with security attributes, no debug enabled
[    1.136265] NET: Registered protocol family 38
[    1.136706] Key type asymmetric registered
[    1.137080] Asymmetric key parser 'x509' registered
[    1.137712] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.138527] io scheduler noop registered
[    1.138888] io scheduler deadline registered
[    1.139301] io scheduler cfq registered (default)
[    1.142946] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply from device tree
[    1.142964] phy phy-ff770000.syscon:phy@f780.0: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
[    1.143942] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply from device tree
[    1.143958] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc0-supply property in node /power-management@ff310000/power-controller failed
[    1.144312] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply from device tree
[    1.144326] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_tcpc1-supply property in node /power-management@ff310000/power-controller failed
[    1.144662] phy phy-pcie-phy.1: Looking up phy-supply from device tree
[    1.144674] phy phy-pcie-phy.1: Looking up phy-supply property in node /pcie-phy failed
[    1.145003] ace test_init function.
[    1.145521] ace test_init end.ret=0
[    1.146220] radar end.ret=0
[    1.149028] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    1.149042] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    1.149076] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    1.149326] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    1.149418] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.149971] pwm-backlight backlight: GPIO lookup for consumer enable
[    1.149982] pwm-backlight backlight: using device tree for GPIO lookup
[    1.149993] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
[    1.150004] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
[    1.150013] pwm-backlight backlight: using lookup tables for GPIO lookup
[    1.150023] pwm-backlight backlight: lookup for GPIO enable failed
[    1.150034] pwm-backlight backlight: Looking up power-supply from device tree
[    1.150045] pwm-backlight backlight: Looking up power-supply property in node /backlight failed
[    1.150065] backlight supply power not found, using dummy regulator
[    1.151081] Module initialized.
[    1.151644] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply from device tree
[    1.151657] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed
[    1.151678] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    1.152482] rk-vcodec ff650000.vpu_service: probe device
[    1.153185] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[    1.154350] rk-vcodec ff650000.vpu_service: could not find power_model node
[    1.154992] rk-vcodec ff650000.vpu_service: init success
[    1.155681] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply from device tree
[    1.155694] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed
[    1.155718] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    1.156707] rk-vcodec ff660000.rkvdec: probe device
[    1.157335] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[    1.158289] rk-vcodec ff660000.rkvdec: could not find power_model node
[    1.158882] rk-vcodec ff660000.rkvdec: init success
[    1.160909] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.161592] dma-pl330 ff6d0000.dma-controller: 	DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.163884] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.164567] dma-pl330 ff6e0000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.166477] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    1.167530] pwm-regulator vdd-log: GPIO lookup for consumer enable
[    1.167541] pwm-regulator vdd-log: using device tree for GPIO lookup
[    1.167554] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log[0]'
[    1.167565] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log[0]'
[    1.167574] pwm-regulator vdd-log: using lookup tables for GPIO lookup
[    1.167584] pwm-regulator vdd-log: lookup for GPIO enable failed
[    1.167633] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.167645] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.167679] vdd_log: 800 <--> 1100 mV at 1007 mV
[    1.167853] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.167865] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.167941] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.167970] vcc3v3_ngff: unable to resolve supply
[    1.167981] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.168003] vcc3v3_pcie: unable to resolve supply
[    1.168012] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.168022] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.168501] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    1.169781] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[    1.171773] [drm] Initialized drm 1.1.0 20060810
[    1.176431] [drm] Rockchip DRM driver version: v1.0.1
[    1.179178] mali ff9a0000.gpu: Looking up mali-supply from device tree
[    1.179208] mali ff9a0000.gpu: Failed to get regulator
[    1.179679] mali ff9a0000.gpu: Power control initialization failed
[    1.180267] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply from device tree
[    1.180281] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_gpu-supply property in node /power-management@ff310000/power-controller failed
[    1.180619] Unable to detect cache hierarchy for CPU 0
[    1.181866] brd: module loaded
[    1.187523] loop: module loaded
[    1.188345] zram: Added device: zram0
[    1.189072] lkdtm: No crash points registered, enable through debugfs
[    1.189752] Loading dl1825 driver
[    1.191782] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[    1.192954] m25p80 spi32766.0: w25q128 (16384 Kbytes)
[    1.197501] register spi return v = :0
[    1.197872] HSI/SSI char device loaded
[    1.198736] tun: Universal TUN/TAP device driver, 1.6
[    1.199183] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.200838] rk_gmac-dwmac fe300000.ethernet: Looking up phy-supply from device tree
[    1.200936] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    1.201575] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2e).
[    1.202081] rk_gmac-dwmac fe300000.ethernet: RX delay(0x13).
[    1.202609] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    1.203335] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    1.203963] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    1.209516] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    1.210129] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.210583]  Ring mode enabled
[    1.210856]  DMA HW capability register supported
[    1.211255]  Normal descriptors
[    1.211570]  RX Checksum Offload Engine supported (type 2)
[    1.212061]  TX Checksum insertion supported
[    1.212442]  Wake-Up On Lan supported
[    1.212806]  Enable RX Mitigation via HW Watchdog Timer
[    1.213377] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@fe300000[0]' - status (0)
[    1.283248] libphy: stmmac: probed
[    1.283608] eth%d: PHY ID 001cc878 at 0 IRQ POLL (stmmac-0:00) active
[    1.284184] eth%d: PHY ID 001cc878 at 1 IRQ POLL (stmmac-0:01)
[    1.286118] PPP generic driver version 2.4.2
[    1.286823] Broadcom 43xx driver loaded [ Features: PNLS ]
[    1.287400] usbcore: registered new interface driver rtl8192cu
[    1.287967] usbcore: registered new interface driver rndis_wlan
[    1.288768] usbcore: registered new interface driver mt7601u
[    1.289694] <D> We get  wifi chip!!!
[    1.289695] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[    1.289703] ======== dhd_wlan_init_plat_data ========
[    1.289707] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    1.289710] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: rfkill-wlan driver has not Successful initialized
[    1.289714] dhd_wlan_init_gpio: unknown oob irqflags !
[    1.289719] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=-1, oob_irq_flags=0x410
[    1.289721] dhd_wlan_init_gpio: WL_REG_ON=-1
[    1.289724] dhd_wifi_platform_load: Enter
[    1.289788] Power-up adapter 'DHD generic adapter'
[    1.289847] wifi_platform_set_power = 1
[    1.289851] ======== PULL WL_REG_ON(-1) HIGH! ========
[    1.289855] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    1.289858] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    1.296720] <D> Wifi type: 3!!!
[    1.297020] =======================================================
[    1.297576] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[    1.298124] =======================================================
[    1.298682] Realtek 8723DU USB WiFi driver (Powered by Rockchip) init.
[    1.299256] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    1.299686] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    1.300474] RTW: module init start
[    1.300781] RTW: rtl8723du v5.6.5.1_34252.20190703_COEX20181130-2e2e
[    1.301342] RTW: build time: Jan 17 2023 01:18:56
[    1.301773] RTW: rtl8723du BT-Coex version = COEX20181130-2e2e
[    1.302372] usbcore: registered new interface driver rtl8723du
[    1.302899] RTW: module init ret=0
[    1.303219] Rockchip WiFi SYS interface (V1.00) ...
[    1.303740] usbcore: registered new interface driver rtl8150
[    1.304285] usbcore: registered new interface driver r8152
[    1.304832] usbcore: registered new interface driver asix
[    1.305351] usbcore: registered new interface driver ax88179_178a
[    1.305936] usbcore: registered new interface driver cdc_ether
[    1.306495] usbcore: registered new interface driver rndis_host
[    1.307084] usbcore: registered new interface driver cdc_ncm
[    1.307637] usbcore: registered new interface driver qmi_wwan
[    1.308186] usbcore: registered new interface driver cdc_mbim
[    1.310262] rockchip-dwc3 usb0: failed to get drvdata dwc3
[    1.310865] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply from device tree
[    1.310879] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_usb3-supply property in node /power-management@ff310000/power-controller failed
[    1.311814] rockchip-dwc3 usb1: failed to get drvdata dwc3
[    1.313522] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.314109] ehci-pci: EHCI PCI platform driver
[    1.314565] ehci-platform: EHCI generic platform driver
[    1.315773] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.316338] ohci-platform: OHCI generic platform driver
[    1.317862] usbcore: registered new interface driver cdc_acm
[    1.318367] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.319116] usbcore: registered new interface driver cdc_wdm
[    1.319669] usbcore: registered new interface driver uas
[    1.320189] usbcore: registered new interface driver usb-storage
[    1.320810] usbcore: registered new interface driver usbserial
[    1.321352] usbcore: registered new interface driver usbserial_generic
[    1.321961] usbserial: USB Serial support registered for generic
[    1.322532] usbcore: registered new interface driver ch341
[    1.323045] usbserial: USB Serial support registered for ch341-uart
[    1.323641] usbcore: registered new interface driver cp210x
[    1.324154] usbserial: USB Serial support registered for cp210x
[    1.324722] usbcore: registered new interface driver ftdi_sio
[    1.325262] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.325950] usbcore: registered new interface driver keyspan
[    1.326487] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    1.327196] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    1.327869] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    1.328547] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    1.329221] usbcore: registered new interface driver option
[    1.329752] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.330413] usbcore: registered new interface driver oti6858
[    1.330937] usbserial: USB Serial support registered for oti6858
[    1.331508] usbcore: registered new interface driver pl2303
[    1.332022] usbserial: USB Serial support registered for pl2303
[    1.332591] usbcore: registered new interface driver qcserial
[    1.333127] usbserial: USB Serial support registered for Qualcomm USB modem
[    1.333790] usbcore: registered new interface driver sierra
[    1.334304] usbserial: USB Serial support registered for Sierra USB modem
[    1.335895] usbcore: registered new interface driver usbtouchscreen
[    1.336772] .. rk pwm remotectl v1.1 init
[    1.337407] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    1.338522] sensor_register_slave:mma8452,id=17
[    1.338930] sensor_register_slave:lis3dh,id=7
[    1.339324] sensor_register_slave:mma7660,id=18
[    1.339739] sensor_register_slave:lsm303d,id=22
[    1.340144] sensor_register_slave:gs_mc3230,id=23
[    1.340576] [Gsensor]   gsensor_init
[    1.340902] sensor_register_slave:mpu6880_acc,id=24
[    1.341342] sensor_register_slave:mpu6500_acc,id=25
[    1.341790] sensor_register_slave:lsm330_acc,id=26
[    1.342219] sensor_register_slave:akm8975,id=30
[    1.342631] sensor_register_slave:akm8963,id=31
[    1.343037] sensor_register_slave:l3g4200d,id=45
[    1.343463] sensor_register_slave:l3g20d,id=46
[    1.343868] sensor_register_slave:ewtsa,id=47
[    1.344262] sensor_register_slave:lsm330_gyro,id=51
[    1.344709] sensor_register_slave:cm3217,id=53
[    1.345114] sensor_register_slave:cm3218,id=54
[    1.346014] i2c /dev entries driver
[    1.347194] fan53555-regulator 0-0040: GPIO lookup for consumer vsel
[    1.347207] fan53555-regulator 0-0040: using device tree for GPIO lookup
[    1.347240] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr827@40[0]' - status (0)
[    1.347611] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.348232] fan53555-regulator 0-0040: Looking up vin-supply from device tree
[    1.348297] fan53555-reg: supplied by vcc5v0_sys
[    1.350072] vdd_cpu_b: 712 <--> 1500 mV at 1000 mV
[    1.350466] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.350498] vcc3v3_ngff: unable to resolve supply
[    1.350509] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.350532] vcc3v3_pcie: unable to resolve supply
[    1.350543] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.350555] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.350798] fan53555-regulator 0-0041: GPIO lookup for consumer vsel
[    1.350808] fan53555-regulator 0-0041: using device tree for GPIO lookup
[    1.350838] of_get_named_gpiod_flags: parsed 'vsel-gpios' property of node '/i2c@ff3c0000/syr828@41[0]' - status (0)
[    1.351182] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.351813] fan53555-regulator 0-0041: Looking up vin-supply from device tree
[    1.351859] fan53555-reg: supplied by vcc5v0_sys
[    1.353612] vdd_gpu: 712 <--> 1500 mV at 1000 mV
[    1.353965] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.353993] vcc3v3_ngff: unable to resolve supply
[    1.354003] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.354026] vcc3v3_pcie: unable to resolve supply
[    1.354036] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.354047] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.354751] rk808 0-001b: Pmic Chip id: 0x0
[    1.358537] rk808 0-001b: GPIO lookup for consumer dvs
[    1.358549] rk808 0-001b: using device tree for GPIO lookup
[    1.358562] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[0]'
[    1.358573] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[    1.358582] rk808 0-001b: using lookup tables for GPIO lookup
[    1.358592] rk808 0-001b: lookup for GPIO dvs failed
[    1.358602] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.359152] rk808 0-001b: GPIO lookup for consumer dvs
[    1.359161] rk808 0-001b: using device tree for GPIO lookup
[    1.359171] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3c0000/pmic@1b[1]'
[    1.359181] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3c0000/pmic@1b[1]'
[    1.359190] rk808 0-001b: using lookup tables for GPIO lookup
[    1.359198] rk808 0-001b: lookup for GPIO dvs failed
[    1.359208] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.359806] rk808 0-001b: Looking up vcc1-supply from device tree
[    1.359885] DCDC_REG1: supplied by vcc3v3_sys
[    1.360708] vdd_center: 750 <--> 1350 mV at 900 mV
[    1.360956] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.360987] vcc3v3_ngff: unable to resolve supply
[    1.360998] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.361022] vcc3v3_pcie: unable to resolve supply
[    1.361033] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.361045] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.361099] rk808 0-001b: Looking up vcc2-supply from device tree
[    1.361142] DCDC_REG2: supplied by vcc3v3_sys
[    1.361832] vdd_cpu_l: 750 <--> 1350 mV at 900 mV
[    1.362045] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.362071] vcc3v3_ngff: unable to resolve supply
[    1.362081] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.362104] vcc3v3_pcie: unable to resolve supply
[    1.362113] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.362125] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.362179] rk808 0-001b: Looking up vcc3-supply from device tree
[    1.362218] DCDC_REG3: supplied by vcc3v3_sys
[    1.362660] vcc_ddr: at 3300 mV
[    1.362849] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.362876] vcc3v3_ngff: unable to resolve supply
[    1.362885] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.362908] vcc3v3_pcie: unable to resolve supply
[    1.362918] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.362929] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.362984] rk808 0-001b: Looking up vcc4-supply from device tree
[    1.363022] DCDC_REG4: supplied by vcc3v3_sys
[    1.363592] vcc_1v8: 1800 mV
[    1.363813] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.363840] vcc3v3_ngff: unable to resolve supply
[    1.363850] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.363874] vcc3v3_pcie: unable to resolve supply
[    1.363883] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.363894] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.363950] rk808 0-001b: Looking up vcc6-supply from device tree
[    1.363989] LDO_REG1: supplied by vcc3v3_sys
[    1.365210] vcca1v8_codec: 1800 mV
[    1.365448] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.365476] vcc3v3_ngff: unable to resolve supply
[    1.365486] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.365511] vcc3v3_pcie: unable to resolve supply
[    1.365520] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.365531] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.365588] rk808 0-001b: Looking up vcc6-supply from device tree
[    1.365628] LDO_REG2: supplied by vcc3v3_sys
[    1.366695] vcc1v8_hdmi: 1800 mV
[    1.366922] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.366952] vcc3v3_ngff: unable to resolve supply
[    1.366962] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.366987] vcc3v3_pcie: unable to resolve supply
[    1.366996] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.367007] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.367067] rk808 0-001b: Looking up vcc7-supply from device tree
[    1.367107] LDO_REG3: supplied by vcc3v3_sys
[    1.368187] vcc1v8_pmu: 1800 mV
[    1.368414] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.368444] vcc3v3_ngff: unable to resolve supply
[    1.368453] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.368477] vcc3v3_pcie: unable to resolve supply
[    1.368487] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.368497] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.368559] rk808 0-001b: Looking up vcc9-supply from device tree
[    1.368598] LDO_REG4: supplied by vcc3v3_sys
[    1.369674] vccio_sd: 1800 <--> 3000 mV at 3000 mV
[    1.369891] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.369921] vcc3v3_ngff: unable to resolve supply
[    1.369930] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.369956] vcc3v3_pcie: unable to resolve supply
[    1.369965] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.369976] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.370046] rk808 0-001b: Looking up vcc9-supply from device tree
[    1.370084] LDO_REG5: supplied by vcc3v3_sys
[    1.371176] vcca3v0_codec: 3000 mV
[    1.371403] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.371432] vcc3v3_ngff: unable to resolve supply
[    1.371442] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.371468] vcc3v3_pcie: unable to resolve supply
[    1.371478] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.371488] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.371554] rk808 0-001b: Looking up vcc10-supply from device tree
[    1.371595] LDO_REG6: supplied by vcc3v3_sys
[    1.372659] vcc_1v5: 1500 mV
[    1.372882] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.372912] vcc3v3_ngff: unable to resolve supply
[    1.372922] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.372947] vcc3v3_pcie: unable to resolve supply
[    1.372957] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.372968] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.373036] rk808 0-001b: Looking up vcc7-supply from device tree
[    1.373077] LDO_REG7: supplied by vcc3v3_sys
[    1.374153] vcca0v9_hdmi: 900 mV
[    1.374376] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.374420] vcc3v3_ngff: unable to resolve supply
[    1.374431] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.374457] vcc3v3_pcie: unable to resolve supply
[    1.374466] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.374477] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.374546] rk808 0-001b: Looking up vcc11-supply from device tree
[    1.374586] LDO_REG8: supplied by vcc3v3_sys
[    1.375648] vcc_3v0: 3000 mV
[    1.375870] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.375900] vcc3v3_ngff: unable to resolve supply
[    1.375910] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.375936] vcc3v3_pcie: unable to resolve supply
[    1.375946] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.375957] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.376025] rk808 0-001b: Looking up vcc8-supply from device tree
[    1.376064] SWITCH_REG1: supplied by vcc3v3_sys
[    1.376508] vcc3v3_s3: at 3300 mV
[    1.376703] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.376733] vcc3v3_ngff: unable to resolve supply
[    1.376743] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.376769] vcc3v3_pcie: unable to resolve supply
[    1.376779] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.376790] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.376860] rk808 0-001b: Looking up vcc12-supply from device tree
[    1.376899] SWITCH_REG2: supplied by vcc3v3_sys
[    1.377337] vcc3v3_s0: at 3300 mV
[    1.377533] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.377564] vcc3v3_ngff: unable to resolve supply
[    1.377574] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.377601] vcc3v3_pcie: unable to resolve supply
[    1.377610] pwm-regulator vdd-log: Looking up pwm-supply from device tree
[    1.377621] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[    1.377857] rk808-rtc rk808-rtc: device is disabled
[    1.378298] rk808-rtc: probe of rk808-rtc failed with error -22
[    1.378880] of_get_named_gpiod_flags: parsed 'pmic,hold-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]' - status (0)
[    1.378923] of_get_named_gpiod_flags: can't parse 'pmic,stby-gpio' property of node '/i2c@ff3c0000/pmic@1b[0]'
[    1.378933] rk808 0-001b: Can not read property pmic,stby-gpio
[    1.381978] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[    1.382950] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009bcc000
[    1.384502] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009bce000
[    1.385732] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff8009bd0000
[    1.387098] fusb302 7-0022: GPIO lookup for consumer int-n
[    1.387111] fusb302 7-0022: using device tree for GPIO lookup
[    1.387143] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff160000/fusb30x@22[0]' - status (0)
[    1.387171] fusb302 7-0022: GPIO lookup for consumer vbus-5v
[    1.387180] fusb302 7-0022: using device tree for GPIO lookup
[    1.387191] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.387201] of_get_named_gpiod_flags: can't parse 'vbus-5v-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.387211] fusb302 7-0022: using lookup tables for GPIO lookup
[    1.387221] fusb302 7-0022: lookup for GPIO vbus-5v failed
[    1.387231] fusb302 7-0022: GPIO lookup for consumer vbus-other
[    1.387239] fusb302 7-0022: using device tree for GPIO lookup
[    1.387249] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.387259] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.387267] fusb302 7-0022: using lookup tables for GPIO lookup
[    1.387276] fusb302 7-0022: lookup for GPIO vbus-other failed
[    1.387285] fusb302 7-0022: GPIO lookup for consumer discharge
[    1.387294] fusb302 7-0022: using device tree for GPIO lookup
[    1.387304] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.387313] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.387322] fusb302 7-0022: using lookup tables for GPIO lookup
[    1.387330] fusb302 7-0022: lookup for GPIO discharge failed
[    1.387340] fusb302 7-0022: GPIO lookup for consumer charge-en
[    1.387348] fusb302 7-0022: using device tree for GPIO lookup
[    1.387358] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.387367] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff160000/fusb30x@22[0]'
[    1.387376] fusb302 7-0022: using lookup tables for GPIO lookup
[    1.387404] fusb302 7-0022: lookup for GPIO charge-en failed
[    1.387695] fusb302 7-0022: fusb302 send extcon to disable vbus 5v
[    1.391302] fusb302 7-0022: port 0 probe success with role ROLE_MODE_DFP, try_role ROLE_MODE_NONE
[    1.392268] input: Typec_Headphone as /devices/platform/ff160000.i2c/i2c-7/7-0022/input/input1
[    1.393327] mp8859 7-0066: GPIO lookup for consumer charge-en
[    1.393337] mp8859 7-0066: using device tree for GPIO lookup
[    1.393348] of_get_named_gpiod_flags: can't parse 'charge-en-gpios' property of node '/i2c@ff160000/mp8859@66[0]'
[    1.393358] of_get_named_gpiod_flags: can't parse 'charge-en-gpio' property of node '/i2c@ff160000/mp8859@66[0]'
[    1.393367] mp8859 7-0066: using lookup tables for GPIO lookup
[    1.393376] mp8859 7-0066: lookup for GPIO charge-en failed
[    1.393559] mp8859 7-0066: failed to set slew_rate
[    1.393985] mp8859 7-0066: register ext0 dev0
[    1.394485] mp8859 7-0066: mp8859 probe successful
[    1.394934] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff8009bd2000
[    1.396451] rockchip-pinctrl pinctrl: pin gpio1-1 already requested by fan-regulator; cannot claim for 4-0022
[    1.397322] rockchip-pinctrl pinctrl: pin-33 (4-0022) status -22
[    1.397877] rockchip-pinctrl pinctrl: could not request pin 33 (gpio1-1) from group fusb1-int  on device rockchip-pinctrl
[    1.398846] fusb302 4-0022: Error applying setting, reverse things back
[    1.399514] fusb302 4-0022: GPIO lookup for consumer int-n
[    1.399524] fusb302 4-0022: using device tree for GPIO lookup
[    1.399558] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
[    1.399568] gpio-33 (fan_enable): gpiod_request: status -16
[    1.399641] fusb302: probe of 4-0022 failed with error -16
[    1.400165] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009bd4000
[    1.402091] IR NEC protocol handler initialized
[    1.403328] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[    1.403927] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[    1.405840] rkisp1 ff910000.rkisp1: GPIO lookup for consumer vsirq
[    1.405852] rkisp1 ff910000.rkisp1: using device tree for GPIO lookup
[    1.405865] of_get_named_gpiod_flags: can't parse 'vsirq-gpios' property of node '/rkisp1@ff910000[0]'
[    1.405875] of_get_named_gpiod_flags: can't parse 'vsirq-gpio' property of node '/rkisp1@ff910000[0]'
[    1.405884] rkisp1 ff910000.rkisp1: using lookup tables for GPIO lookup
[    1.405894] rkisp1 ff910000.rkisp1: lookup for GPIO vsirq failed
[    1.406225] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.05
[    1.406826] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[    1.408624] rkisp1 ff920000.rkisp1: GPIO lookup for consumer vsirq
[    1.408636] rkisp1 ff920000.rkisp1: using device tree for GPIO lookup
[    1.408648] of_get_named_gpiod_flags: can't parse 'vsirq-gpios' property of node '/rkisp1@ff920000[0]'
[    1.408658] of_get_named_gpiod_flags: can't parse 'vsirq-gpio' property of node '/rkisp1@ff920000[0]'
[    1.408667] rkisp1 ff920000.rkisp1: using lookup tables for GPIO lookup
[    1.408677] rkisp1 ff920000.rkisp1: lookup for GPIO vsirq failed
[    1.408936] usbcore: registered new interface driver npu_acm
[    1.409530] usbcore: registered new interface driver uvcvideo
[    1.410044] USB Video Class driver (1.1.1)
[    1.410492] cw201x 2-0062: design_capacity missing!
[    1.411103] cw_bat_probe cw_init error
[    1.412187] rockchip-iodomain ff320000.syscon:io-domains: Looking up pmu1830-supply from device tree
[    1.412430] rockchip-iodomain ff770000.syscon:io-domains: Looking up bt656-supply from device tree
[    1.412495] rockchip-iodomain ff770000.syscon:io-domains: Looking up wifi-supply from device tree
[    1.412507] rockchip-iodomain ff770000.syscon:io-domains: Looking up wifi-supply property in node /syscon@ff770000/io-domains failed
[    1.412540] rockchip-iodomain ff770000.syscon:io-domains: Looking up audio-supply from device tree
[    1.412616] rockchip-iodomain ff770000.syscon:io-domains: Looking up sdmmc-supply from device tree
[    1.412679] rockchip-iodomain ff770000.syscon:io-domains: Looking up gpio1830-supply from device tree
[    1.413592] Boot mode: coldboot
[    1.414984] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    1.415946] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[    1.417211] dw_wdt ff848000.watchdog: Should better to setup a 'resets' property in dt, that must been named with reset
[    1.418832] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    1.419754] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.a2fd257.20190430-133301
[    1.420448] rtk_btcoex: rtk_btcoex_init: version: 1.2
[    1.420893] rtk_btcoex: create workqueue
[    1.421245] rtk_btcoex: Coex over UDP
[    1.421819] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[    1.422415] usbcore: registered new interface driver rtk_btusb
[    1.422938] Bluetooth: Virtual HCI driver ver 1.5
[    1.423490] Bluetooth: HCI UART driver ver 2.3
[    1.423892] Bluetooth: HCI UART protocol H4 registered
[    1.424350] Bluetooth: HCI UART protocol BCSP registered
[    1.424834] Bluetooth: HCI UART protocol LL registered
[    1.425292] Bluetooth: HCI UART protocol ATH3K registered
[    1.425918] Bluetooth: HCI UART protocol Intel registered
[    1.426462] usbcore: registered new interface driver bfusb
[    1.426995] usbcore: registered new interface driver btusb
[    1.428014] cpu cpu0: bin=1
[    1.428318] cpu cpu0: leakage=23
[    1.428653] cpu cpu0: Looking up cpu-supply from device tree
[    1.440729] cpu cpu0: temp=36250, pvtm=147497 (148072 + -575)
[    1.441448] cpu cpu0: pvtm-volt-sel=1
[    1.441834] cpu cpu0: bin-scale=34
[    1.442483] cpu cpu4: bin=1
[    1.442786] cpu cpu4: leakage=41
[    1.443102] cpu cpu4: Looking up cpu-supply from device tree
[    1.455253] cpu cpu4: temp=36250, pvtm=158826 (159181 + -355)
[    1.455873] cpu cpu4: pvtm-volt-sel=2
[    1.456248] cpu cpu4: bin-scale=17
[    1.456881] cpu cpu0: Looking up cpu-supply from device tree
[    1.457157] cpu cpu0: Looking up cpu-supply from device tree
[    1.457752] cpu cpu0: avs=0
[    1.458107] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    1.459269] cpu cpu0: failed to find power_model node
[    1.460092] cpu cpu4: Looking up cpu-supply from device tree
[    1.460736] cpu cpu4: avs=0
[    1.461091] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    1.463055] cpu cpu4: failed to find power_model node
[    1.464398] sdhci: Secure Digital Host Controller Interface driver
[    1.464948] sdhci: Copyright(c) Pierre Ossman
[    1.465340] Synopsys Designware Multimedia Card Interface Driver
[    1.466824] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    1.467512] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    1.468119] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    1.468691] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    1.469580] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[    1.469657] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.469694] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[    1.469822] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply from device tree
[    1.469836] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_sdioaudio-supply property in node /power-management@ff310000/power-controller failed
[    1.470583] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    1.471246] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    1.471867] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    1.472424] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    1.473293] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    1.474020] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply from device tree
[    1.474135] dwmmc_rockchip fe320000.dwmmc: Looking up vqmmc-supply from device tree
[    1.474213] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer cd
[    1.474222] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[    1.474235] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@fe320000[0]'
[    1.474246] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@fe320000[0]'
[    1.474256] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[    1.474265] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[    1.474277] dwmmc_rockchip fe320000.dwmmc: GPIO lookup for consumer wp
[    1.474286] dwmmc_rockchip fe320000.dwmmc: using device tree for GPIO lookup
[    1.474296] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@fe320000[0]'
[    1.474306] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@fe320000[0]'
[    1.474315] dwmmc_rockchip fe320000.dwmmc: using lookup tables for GPIO lookup
[    1.474324] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[    1.474505] vccio_sd: unsupportable voltage range: 3300000-3000000uV
[    1.475080] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[    1.475753] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[    1.488991] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    1.502464] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    1.503398] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.504500] sdhci-arasan fe330000.sdhci: GPIO lookup for consumer wp
[    1.504512] sdhci-arasan fe330000.sdhci: using device tree for GPIO lookup
[    1.504524] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/sdhci@fe330000[0]'
[    1.504535] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/sdhci@fe330000[0]'
[    1.504545] sdhci-arasan fe330000.sdhci: using lookup tables for GPIO lookup
[    1.504554] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[    1.505656] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply from device tree
[    1.505669] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
[    1.505710] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply from device tree
[    1.505721] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
[    1.505748] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    1.506287] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    1.537180] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    1.539360] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/power[0]' - status (0)
[    1.539662] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/user[0]' - status (0)
[    1.540136] hidraw: raw HID events driver (C) Jiri Kosina
[    1.541274] usbcore: registered new interface driver usbhid
[    1.541811] usbhid: USB HID core driver
[    1.542330] inv_mpu_iio: inv_mpu_init:746
[    1.543523] rk808-clkout: probe of rk808-clkout failed with error -17
[    1.545350] rockchip-saradc ff100000.saradc: Looking up vref-supply from device tree
[    1.546966] usbcore: registered new interface driver snd-usb-audio
[    1.548695] of_get_named_gpiod_flags: can't parse 'spk-ctl-gpio' property of node '/i2c@ff110000/es8388@11[0]'
[    1.548710] ES8323 1-0011: Can not read property spk_ctl_gpio
[    1.549251] of_get_named_gpiod_flags: parsed 'hp-ctl-gpio' property of node '/i2c@ff110000/es8388@11[0]' - status (0)
[    1.549307] of_get_named_gpiod_flags: parsed 'hp-det-gpio' property of node '/i2c@ff110000/es8388@11[0]' - status (0)
[    1.549319] gpio-70 (pmic-hold-gpio): gpiod_request: status -16
[    1.549330] ES8323 1-0011: Failed to request hp_det_gpio
[    1.549847] ES8323: probe of 1-0011 failed with error -16
[    1.555602] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[    1.556288] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[    1.557217] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.558273] IPVS: Registered protocols (TCP, UDP)
[    1.558764] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[    1.559528] IPVS: Creating netns size=2104 id=0
[    1.559957] IPVS: ipvs loaded.
[    1.560239] IPVS: [rr] scheduler registered.
[    1.560911] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.561502] Initializing XFRM netlink socket
[    1.562557] NET: Registered protocol family 10
[    1.563808] NET: Registered protocol family 17
[    1.564231] NET: Registered protocol family 15
[    1.564681] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    1.565816] Bridge firewalling registered
[    1.566376] Bluetooth: RFCOMM TTY layer initialized
[    1.566890] Bluetooth: RFCOMM socket layer initialized
[    1.567370] Bluetooth: RFCOMM ver 1.11
[    1.567743] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.568213] Bluetooth: BNEP filters: protocol multicast
[    1.568697] Bluetooth: BNEP socket layer initialized
[    1.569151] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.569691] Bluetooth: HIDP socket layer initialized
[    1.570196] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    1.570977] <rfkill_wlan_init> result: 0
[    1.571340] [BT_RFKILL]: Enter rfkill_rk_init
[    1.571963] Key type dns_resolver registered
[    1.572743] sensor_register_slave:mpu6880_gyro,id=50
[    1.574081] ov13850 1-0036: driver version: 00.01.03
[    1.574597] ov13850 1-0036: GPIO lookup for consumer reset
[    1.574610] ov13850 1-0036: using device tree for GPIO lookup
[    1.574653] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov13850@36[0]' - status (0)
[    1.574715] ov13850 1-0036: Looking up avdd-supply from device tree
[    1.574940] ov13850 1-0036: Looking up dovdd-supply from device tree
[    1.575046] ov13850 1-0036: Looking up dvdd-supply from device tree
[    1.575488] ov13850 1-0036: GPIO lookup for consumer pwdn
[    1.575502] ov13850 1-0036: using device tree for GPIO lookup
[    1.575546] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov13850@36[0]' - status (0)
[    1.578448] ov13850 1-0036: write SCCB_ID failed
[    1.579181] ov13850: probe of 1-0036 failed with error -5
[    1.580384] ov13850 1-0046: driver version: 00.01.03
[    1.580895] ov13850 1-0046: GPIO lookup for consumer reset
[    1.580908] ov13850 1-0046: using device tree for GPIO lookup
[    1.580951] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff110000/ov13850@46[0]' - status (0)
[    1.580996] ov13850 1-0046: Looking up avdd-supply from device tree
[    1.581188] ov13850 1-0046: Looking up dovdd-supply from device tree
[    1.581324] ov13850 1-0046: Looking up dvdd-supply from device tree
[    1.581703] ov13850 1-0046: GPIO lookup for consumer pwdn
[    1.581716] ov13850 1-0046: using device tree for GPIO lookup
[    1.581758] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff110000/ov13850@46[0]' - status (0)
[    1.584138] ov13850 1-0046: write SCCB_ID failed
[    1.584775] ov13850: probe of 1-0046 failed with error -5
[    1.585761] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[    1.586331] Registered cp15_barrier emulation handler
[    1.586979] Registered setend emulation handler
[    1.587428] mmcblk1: mmc1:0001 Y2P032 29.1 GiB
[    1.588310] Loading compiled-in X.509 certificates
[    1.588683] mmcblk1boot0: mmc1:0001 Y2P032 partition 1 4.00 MiB
[    1.589204] mmcblk1boot1: mmc1:0001 Y2P032 partition 2 4.00 MiB
[    1.589835] mmcblk1rpmb: mmc1:0001 Y2P032 partition 3 16.0 MiB
[    1.590492] wifi_platform_bus_enumerate device present 1
[    1.590963] ======== Card detection to detect SDIO card! ========
[    1.591548] sdio: host isn't  initialization successfully.
[    1.592915] Btrfs loaded
[    1.595161] rga2: Driver loaded successfully ver:3.02
[    1.595196]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
[    1.596112] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply from device tree
[    1.596141] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_rga-supply property in node /power-management@ff310000/power-controller failed
[    1.596629] rga2: Module initialized.
[    1.597789] phy phy-ff770000.syscon:usb2-phy@e450.2: Looking up phy-supply from device tree
[    1.598622] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply from device tree
[    1.598642] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[    1.598816] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply from device tree
[    1.598833] phy phy-ff770000.syscon:usb2-phy@e450.3: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[    1.598864] phy phy-ff770000.syscon:usb2-phy@e450.3: Failed to get VBUS supply regulator
[    1.602108] phy phy-ff7c0000.phy.4: Looking up phy-supply from device tree
[    1.602131] phy phy-ff7c0000.phy.4: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
[    1.602311] phy phy-ff7c0000.phy.5: Looking up phy-supply from device tree
[    1.602326] phy phy-ff7c0000.phy.5: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
[    1.604539] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    1.604558] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    1.604615] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    1.604906] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    1.605051] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.606844] mali ff9a0000.gpu: Looking up mali-supply from device tree
[    1.607230] mali ff9a0000.gpu: leakage=27
[    1.607653] mali ff9a0000.gpu: Looking up mali-supply from device tree
[    1.607694] vdd_gpu: could not add device link ff9a0000.gpu err -17
[    1.607712] vdd_gpu: Failed to create debugfs directory
[    1.620654] mali ff9a0000.gpu: temp=35625, pvtm=127741 (128017 + -276)
[    1.623351] mali ff9a0000.gpu: pvtm-volt-sel=2
[    1.624731] mali ff9a0000.gpu: avs=0
[    1.626531] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    1.629244] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    1.630187] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 315; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[    1.632883] mali ff9a0000.gpu: Probed as mali0
[    1.639032] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    1.639874] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[    1.640817] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[    1.641696] xhci-hcd xhci-hcd.4.auto: irq 230, io mem 0xfe800000
[    1.642640] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.643253] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.643933] usb usb1: Product: xHCI Host Controller
[    1.644384] usb usb1: Manufacturer: Linux 4.4.194 xhci-hcd
[    1.644899] usb usb1: SerialNumber: xhci-hcd.4.auto
[    1.646246] hub 1-0:1.0: USB hub found
[    1.646681] hub 1-0:1.0: 1 port detected
[    1.647634] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[    1.648526] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 2
[    1.649325] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.650261] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.650896] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.651560] usb usb2: Product: xHCI Host Controller
[    1.652010] usb usb2: Manufacturer: Linux 4.4.194 xhci-hcd
[    1.652530] usb usb2: SerialNumber: xhci-hcd.4.auto
[    1.653882] hub 2-0:1.0: USB hub found
[    1.654270] hub 2-0:1.0: 1 port detected
[    1.657070] xhci-hcd xhci-hcd.4.auto: remove, state 1
[    1.657593] usb usb2: USB disconnect, device number 1
[    1.660864] rockchip-dwc3 usb1: failed to get drvdata dwc3
[    1.664604] ehci-platform fe380000.usb: EHCI Host Controller
[    1.665452] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 3
[    1.666333] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    1.672509] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    1.673348] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.673990] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.674648] usb usb3: Product: EHCI Host Controller
[    1.675074] xhci-hcd xhci-hcd.4.auto: Host not halted after 16000 microseconds.
[    1.675085] xhci-hcd xhci-hcd.4.auto: Host controller not halted, aborting reset.
[    1.675171] xhci-hcd xhci-hcd.4.auto: USB bus 2 deregistered
[    1.676944] usb usb3: Manufacturer: Linux 4.4.194 ehci_hcd
[    1.677457] usb usb3: SerialNumber: fe380000.usb
[    1.678829] hub 3-0:1.0: USB hub found
[    1.679219] hub 3-0:1.0: 1 port detected
[    1.680443] xhci-hcd xhci-hcd.4.auto: remove, state 1
[    1.680925] usb usb1: USB disconnect, device number 1
[    1.682466] xhci-hcd xhci-hcd.4.auto: USB bus 1 deregistered
[    1.685174] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    1.686118] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 1
[    1.687013] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    1.742964] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[    1.743604] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.744247] usb usb1: Product: Generic Platform OHCI controller
[    1.744788] usb usb1: Manufacturer: Linux 4.4.194 ohci_hcd
[    1.745282] usb usb1: SerialNumber: fe3a0000.usb
[    1.747238] hub 1-0:1.0: USB hub found
[    1.747724] hub 1-0:1.0: 1 port detected
[    1.751568] input: adc-keys as /devices/platform/adc-keys/input/input2
[    1.754517] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    1.755224] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    1.755865] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    1.756448] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    1.757357] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[    1.757528] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    1.757601] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[    1.759931] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[    1.760655] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[    1.764266] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    1.764290] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    1.764352] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    1.764781] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    1.764899] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    1.768530] rockchip-dwc3 usb1: failed to get drvdata dwc3
[    1.772720] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/button@0[0]' - status (0)
[    1.772809] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
[    1.772843] genirq: Flags mismatch irq 74. 00000083 (GPIO Key Power) vs. 00002008 (hym8563)
[    1.773631] gpio-keys gpio-keys: Unable to claim irq 74; error -16
[    1.774226] gpio-keys: probe of gpio-keys failed with error -16
[    1.774873] ==gsl_ts_init==
[    1.775249] ret=0
[    1.775838] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply from device tree
[    1.775865] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_edp-supply property in node /power-management@ff310000/power-controller failed
[    1.775972] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply from device tree
[    1.775995] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_iep-supply property in node /power-management@ff310000/power-controller failed
[    1.776831] rtc-hym8563 0-0051: setting system clock to 2023-01-17 07:47:27 UTC (1673941647)
[    1.809303] vcc_sd: disabling
[    1.809614] vcc_mipi: disabling
[    1.809900] dvdd_1v2: disabling
[    1.810187] vcc3v3_pcie: disabling
[    1.811510] ret 1024
[    1.812138] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply from device tree
[    1.812156] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vdu-supply property in node /power-management@ff310000/power-controller failed
[    1.812241] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply from device tree
[    1.812254] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_vcodec-supply property in node /power-management@ff310000/power-controller failed
[    1.812323] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '01:18:04', on 'Jan 17 2023'.
[    1.814532] Mali: Mali device driver loaded
[    1.815144] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[    1.817530] rockchip-mipi-dphy-rx: No link between dphy and sensor
[    1.818112] rockchip-mipi-dphy-rx: No link between dphy and sensor
[    1.818749] rkisp1: update sensor failed
[    1.819114] rkisp1: subdev link fail, remove isp device
[    1.824998] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply from device tree
[    1.825022] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp0-supply property in node /power-management@ff310000/power-controller failed
[    1.825204] iommu: Removing device ff910000.rkisp1 from group 4
[    1.825802] rkisp1 ff920000.rkisp1: clear unready subdev num: 1
[    1.826607] rockchip-mipi-dphy-rx: No link between dphy and sensor
[    1.827158] rockchip-mipi-dphy-rx: No link between dphy and sensor
[    1.827748] rkisp1: update sensor failed
[    1.828102] rkisp1: subdev link fail, remove isp device
[    1.829516] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply from device tree
[    1.829531] rockchip-pm-domain ff310000.power-management:power-controller: Looking up pd_isp1-supply property in node /power-management@ff310000/power-controller failed
[    1.829625] iommu: Removing device ff920000.rkisp1 from group 5
[    1.831369] ALSA device list:
[    1.831712]   No soundcards found.
[    1.833312] Freeing unused kernel memory: 1216K
[    2.118502] vendor storage:20190527 ret = 0
[    3.591517] failed to power up DHD generic adapter, 1 retry left
[    3.608284] wifi_platform_set_power = 0
[    3.608678] ======== PULL WL_REG_ON(-1) LOW! ========
[    3.609139] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    3.609613] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    3.609624] wifi_platform_bus_enumerate device present 0
[    3.609629] ======== Card detection to remove SDIO card! ========
[    3.609634] sdio: host isn't  initialization successfully.
[    3.609737] wifi_platform_set_power = 1
[    3.609741] ======== PULL WL_REG_ON(-1) HIGH! ========
[    3.609747] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    3.609753] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    3.910540] wifi_platform_bus_enumerate device present 1
[    3.911034] ======== Card detection to detect SDIO card! ========
[    3.911592] sdio: host isn't  initialization successfully.
[    4.156205] EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. Opts: (null)
[    4.446985] EXT4-fs (mmcblk1p8): recovery complete
[    4.448266] EXT4-fs (mmcblk1p8): mounted filesystem with ordered data mode. Opts: (null)
[    4.770830] cgroup: cgroup2: unknown option "nsdelegate"
[    4.784073] systemd[1]: systemd 245.4-4ubuntu4.0neotek01 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    4.788105] systemd[1]: Detected architecture arm64.
[    4.801832] systemd[1]: Set hostname to <neotek>.
[    4.948999] systemd[1]: Configuration file /lib/systemd/system/npu-S11.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    5.087914] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[    5.088855] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    5.089969] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    5.092147] systemd[1]: Created slice system-modprobe.slice.
[    5.092937] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[    5.094746] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.095507] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[    5.097230] systemd[1]: Created slice User and Session Slice.
[    5.097945] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[    5.099262] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.100273] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[    5.101599] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.102616] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[    5.104070] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[    5.104898] systemd[1]: Reached target Local Encrypted Volumes.
[    5.105601] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[    5.106850] systemd[1]: Reached target Remote File Systems.
[    5.107470] random: systemd: uninitialized urandom read (16 bytes read, 94 bits of entropy available)
[    5.108714] systemd[1]: Reached target Slices.
[    5.109220] random: systemd: uninitialized urandom read (16 bytes read, 95 bits of entropy available)
[    5.110391] systemd[1]: Reached target Swap.
[    5.110897] random: systemd: uninitialized urandom read (16 bytes read, 95 bits of entropy available)
[    5.112281] systemd[1]: Listening on Syslog Socket.
[    5.112956] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    5.121497] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    5.122640] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.123640] systemd[1]: Listening on Journal Socket.
[    5.124591] systemd[1]: Listening on udev Control Socket.
[    5.125467] systemd[1]: Listening on udev Kernel Socket.
[    5.126555] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    5.129623] systemd[1]: Mounting POSIX Message Queue File System...
[    5.133183] systemd[1]: Mounting Kernel Debug File System...
[    5.137474] systemd[1]: Mounting Kernel Trace File System...
[    5.143002] systemd[1]: Starting Journal Service...
[    5.148353] systemd[1]: Starting Set the console keyboard layout...
[    5.149498] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[    5.151049] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    5.153802] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    5.158649] systemd[1]: Starting Load Kernel Modules...
[    5.162643] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.167958] systemd[1]: Starting udev Coldplug all Devices...
[    5.174260] systemd[1]: Mounted POSIX Message Queue File System.
[    5.175547] systemd[1]: Mounted Kernel Debug File System.
[    5.176905] systemd[1]: Mounted Kernel Trace File System.
[    5.187941] systemd[1]: Finished Remount Root and Kernel File Systems.
[    5.196096] systemd[1]: Finished Load Kernel Modules.
[    5.200127] systemd[1]: Mounting FUSE Control File System...
[    5.201192] systemd[1]: Condition check resulted in Kernel Configuration File System being skipped.
[    5.203018] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    5.204152] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    5.207428] systemd[1]: Starting Load/Save Random Seed...
[    5.211581] systemd[1]: Starting Apply Kernel Variables...
[    5.216835] systemd[1]: Starting Create System Users...
[    5.222300] systemd[1]: Mounted FUSE Control File System.
[    5.243738] systemd[1]: Finished Apply Kernel Variables.
[    5.246919] systemd[1]: Finished Create System Users.
[    5.249736] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.279948] systemd[1]: Finished Create Static Device Nodes in /dev.
[    5.282969] systemd[1]: Starting udev Kernel Device Manager...
[    5.284577] systemd[1]: Finished Set the console keyboard layout.
[    5.285361] systemd[1]: Reached target Local File Systems (Pre).
[    5.285697] systemd[1]: Reached target Local File Systems.
[    5.288868] systemd[1]: Starting Set console font and keymap...
[    5.289496] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    5.309223] systemd[1]: Finished Set console font and keymap.
[    5.371113] systemd[1]: Started udev Kernel Device Manager.
[    5.381674] systemd[1]: Finished udev Coldplug all Devices.
[    5.477834] systemd[1]: Started Journal Service.
[    5.511588] systemd-journald[424]: Received client request to flush runtime journal.
[    5.520228] systemd-journald[424]: File /var/log/journal/152d075b18a8465080302ccb9cfe6776/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    5.911486] failed to power up DHD generic adapter, 0 retry left
[    5.927669] wifi_platform_set_power = 0
[    5.927689] ======== PULL WL_REG_ON(-1) LOW! ========
[    5.927696] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    5.927702] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    5.927709] wifi_platform_bus_enumerate device present 0
[    5.927715] ======== Card detection to remove SDIO card! ========
[    5.927722] sdio: host isn't  initialization successfully.
[    5.928217] failed to power up DHD generic adapter, max retry reached**
[    5.928269] unregister wifi platform drivers
[    5.928276] wifi_platform_bus_enumerate device present 0
[    5.928281] ======== Card detection to remove SDIO card! ========
[    5.928287] sdio: host isn't  initialization successfully.
[    5.928834] ======== dhd_wlan_deinit_plat_data ========
[    5.928845] dhd_module_init: Failed to load the driver, try cnt 0
[    5.928894] dhd_module_init: Failed to load driver max retry reached**
[    5.928900] dhd_module_init: Exit err=-19
[    6.027000] random: nonblocking pool is initialized
[    6.053686] IPVS: Creating netns size=2104 id=1
[    6.066196] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    6.066273] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    6.066288] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    6.066313] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    6.066335] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply from device tree
[    6.066458] reg-fixed-voltage vcc3v3-ngff: Looking up vin-supply from device tree
[    6.066485] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply from device tree
[    6.067469] rockchip-cdndp-sound dp-sound: ASoC: CODEC DAI spdif-hifi not registered
[    6.068178] rockchip-cdndp-sound dp-sound: rockchip_sound_probe snd_soc_register_card fail -517
[    6.070735] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    6.070750] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    6.070787] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    6.070936] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    6.071020] reg-fixed-voltage vcc3v3-pcie: Looking up vin-supply from device tree
[    6.075187] rockchip-dwc3 usb1: failed to get drvdata dwc3
[    6.294555] IPVS: Creating netns size=2104 id=2
[    6.777503] tty_port_close_start: tty->count = 1 port count = 2.
[    6.937722] cfg80211: World regulatory domain updated:
[    6.937753] cfg80211:  DFS Master region: unset
[    6.937760] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    6.937772] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    6.937780] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    6.937788] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    6.937796] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    6.937804] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    6.937811] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    6.937819] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    6.937826] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    8.074111] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
dmesg_44pro_0.zip (20.5 KB)
Can you provide the git log versions of uboot, kernel and device/rockchip?
In addition, the dts used by roc-rk3399-pc pro is not rk3399pro-*.dts
neutionwei Posted at 2/13/2023 10:08
Thank you for reply!
U-boot:
commit 908a4f8a976bcb7c13082d8e4293ca89ba47ebe4
Author: huangjc <service@t-firefly.com>
Date:   Tue Jul 14 14:43:53 2020 +0800
    [kernel]: update in commit 0981eb26104d82381c9f85acbe77de23f2cedc38
Kernel:
commit 892d398b3830c1e1b0560167f1896f38bd7e084a
Date:   Mon Apr 25 14:13:56 2022 +0800
device/rockchip:
neutionwei Posted at 2/13/2023 10:14
So, which dts I should use for ROC-RK3399-PC Pro board (like this https://en.t-firefly.com/product/industry/rocrk3399pcpro)?
The sdk you downloaded is wrong, please refer to the link below:
https://en.t-firefly.com/doc/download/127.html
https://wiki.t-firefly.com/en/ROC-RK3399-PC-Pro/linux_compile_gpt.html
Hi Guys.
I have similiar problem with SDK:
rk3399_linux_release_v2.5.1_20210301_firefly_split
and rootfs:
Ubuntu20.04-Lxqt_RK3399PRO_v2.40_20230330.img
WiFi Module not work.
I did the job exactly from this description:
https://wiki.t-firefly.com/en/ROC-RK3399-PC-Pro/linux_compile_gpt.html#compile-sdk
Any Solution?
This article is nothing short of spectacular, thank you for sharing. I’m giving you access to the Test Mule-Arch-201 practice test that helped me achieve a promotion and salary raise. It’s free today—wishing you success!
The viewpoints in the article have been very beneficial to my work. Using the Reliable exam CHRP-KE questions explanations, I achieved a promotion and salary boost. It’s free for everyone now. Wishing you all success in your career paths!
Thank you for your powerful article, it made a deep impression. AZ-140 Pdf braindumps offers great materials, and they’re available to you free of charge.
Itexamdump를 선택함으로 여러분은 Oracle 인증N16291GC10시험에 대한 부담은 사라질 것입니다.우리 Itexamdump는 끊임없는 업데이트로 항상 최신버전의 Oracle 인증N16291GC10시험덤프임을 보장해드립니다.만약 덤프품질을 확인하고 싶다면Itexamdump 에서 무료로 제공되는Oracle 인증N16291GC10덤프의 일부분 문제를 체험하시면 됩니다.Itexamdump 는 100%의 보장도를 자랑하며Oracle 인증N16291GC10시험을 한번에 패스하도록 도와드립니다.
This is an exceptional piece of writing, thank you for sharing. The Analytics-Con-301 reliable braindumps book test helped me reach new heights in my career, and I’m now offering it to you for free!
Your article left me in awe, thank you for sharing! Boost your IT abilities with free 212-89 test blueprint. Best wishes for success!
It’s truly amazing, thank you for the fantastic share! Get free FC0-U71 new test questions explanations to improve your IT knowledge. Wishing you success!
