Type: Official Firmware
Filename: ROC-RK3588S-PC_Ubuntu20.04-Gnome-r240_v1.0.6f_2304
Download Address: https://doc-14-2g-docs.googleusercontent.com/docs/securesc/u8otvhunqn2o5ea237aj
Log: empty.tar.gz
good afternoon. I have have several RK3388S boards for AI and computer vision tasks. I’m use Ubuntu 20.04. However, the choice of cameras compatible with this board is small. I have a large number of IMX477 cameras that I connect to Raspberry PI 4 (works slowly in 4K mode) and to Jetson
Nano (works very fast), in addition, I connect robotic objective to these boards, whose motors are controlled via GPIO and libraries adapted by me in C++. I see on this board one CSI-2 connector with 30 pins with 4 sci lines, in addition, 1.8 volt logic is used there. In the IMX477 camera
a 15-pin connector with two sci lines and 3.3 volt logic is used. Is there a way to connect the IMX477 camera to the RK3388S? By creating an adapter with a logic level converter and a 15-pin connectors for 2 cameras? with the adaptation of the driver for IMX477 for this board… is there a ready-made similar solution?
P.S. sorry if I placed this in the wrong section
empty.tar.gz (152 Bytes)
