Type: Official Firmware
Filename: Ubuntu 20.04.6 LTS
Download Address: https://en.t-firefly.com/doc/download/142.html
Log: kern.zip
Kinda stuck with the raspberry camera module. I’ve connected camera module using ADP-Tfirefly board and there is no reason to doubt the connection, cuz power levels on the pins of the camera module seems correct and I can see connected device on the 7th bus using i2cdetect command. But my platform can’t find /dev/video0 or any device besides /dev/media0. I’ve alredy tried to start video stream with gst-launch-1.0 command and raspivid command, but both did not work (raspivid indicates that it failed to open the vchiq). Is there anyone with similar problem?
kern.zip (317 Bytes)
Ok, so OV5647 is not set in configuration file. Is there any way to connect OV5647 sensor to roc-rk3588s-pc?
I have the same sprunki modded question.
Your article is truly amazing, I appreciate you sharing it. I’m sharing the C_BCBAI_2509 valid study questions pdf questions that helped me achieve my promotion and salary increase—for free!
如果你想購買Salesforce的AP-214學習指南線上服務,那麼我們KaoGuTi是領先用於此目的的網站之一,本站提供最好的品質和最新的培訓資料,我們網站所提供成的所有的學習資料及其它的培訓資料都是符合成本效益的,可以在網站上享受一年的免費更新設施,所以這些培訓產品如果沒有幫助你通過考試,我們將保證退還全部購買費用。
This article is brilliant, thank you for this incredible share. AE-Adult-Echocardiography valid test online is rich with helpful content, offered free to aid your learning.
I appreciate your article, it was so refreshing and insightful. I believe the Reliable AP-207 exam bootcamp content will be helpful, and it’s totally free for you.
I’m amazed by this article, thank you for sharing it. Upgrade your IT skills by downloading free C-S4CS-2508 reliable exam questions answers. Best of luck!
