Type: Self-Compiled Firmware
SDK Package Name: ??
Modification Content: ??
Log: log.zip
I am starting with this device, and compiled the image for it.
Flahsed the device, and now it does not start in normal mode. It turns LAN1 leds on, then in 3 seconds off, then on again and so on.
Is there any way to have diagnostic console where I can see all the output starting U-boot? And potentially can see where boot fails?
Thanks.
log.zip (155 Bytes)
Hello, which kind of device or board do you use? And firmware?
iHC-3308GW, openwrt build (I guess originally from here - https://gitlab.com/TeeFirefly/rk3308-linux).
Edit: it is NOT openwrt! It is buildroot.
Is there any open source openwrt for 3308GW? This one https://dev.t-firefly.com/thread-104203-1-1.html is a firmware, not a source code.
I’m very grateful for your article, it really caught my attention. Examcode materials are free for everyone—good luck! Exam PTOE collection pdf
Cisco인증200-901시험덤프의 문제와 답은 모두 우리의 엘리트들이 자신의 지식과 몇 년간의 경험으로 완벽하게 만들어낸 최고의 문제집입니다. 전문적으로Cisco인증200-901시험을 응시하는 분들을 위하여 만들었습니다. 여러분이 다른 사이트에서도Cisco인증200-901시험 관련덤프자료를 보셨을 것입니다 하지만 우리ITDumpsKR의 자료만의 최고의 전문가들이 만들어낸 제일 전면적이고 또 최신 업데이트일 것입니다.Cisco인증200-901시험을 응시하고 싶으시다면 ITDumpsKR자료만의 최고의 선택입니다.
This article is truly eye-opening, thank you for sharing. Valid test API-1169 dumps.zip provides great resources, and they are completely free.
あなたへの紹介よりあなたに自分で体験させたほうがいいと思います。弊社のCertJukenで無料でMicrosoftのMB-700ソフトのデモを直ちにダウンロードできます。MicrosoftのMB-700ソフトを利用してこのソフトはあなたの愛用するものになることを信じています。MicrosoftのMB-700ソフトはあなたにITという職業での人材に鳴らせます。
