Type: Official Firmware
Filename: ubuntu-22.04.2-preinstalled-server-arm64+roc-rk332
Download Address: Index of /ci/ubuntu/22.04/
Log: sensor_i2c_roc3328cc.zip
Hello,I have been trying to interface a sensor that communicates through the I2C protocol with the dev board ROC-RK3328-cc’s SDA0 and SCL0 pins( pin 3 and pin 5). I have flashed Ubuntu 22.04 server version OS in this processor and was successful in installing the i2ctools package involving the required library packages. I am unable to detect the sensor on either of the i2c bus of the system using debugging i2ctools commands such as i2cdetect and i2cdump and i2cget. I hope to get help for the following problems, thank you in advance,
- How do I interface the i2c device physically to the dev board?
- Do I have to add pull-up resistors?
- i2cdetect command does not detect the sensor in the system. How do I debug if the dev board is able to detect the i2c device?
I have attached debug commands I used to verify if the sensor is connected to the board and which i2c bus, pfa. The sensor’s address is 0x41 but while using command: i2cdetect -y 1 the address doesn’t show up.
Looking forward to some support, thank you once again.
sensor_i2c_roc3328cc.zip (396 KB)
Hello, how can I help you?
Reading this article has given me new plans for my career development. With the help of this 300-820 reliable exam forum, I earned a promotion and a pay raise. Now I’m offering it for free to everyone. Wishing you all success in your careers!
結果として、ITIL-4-Foundationの質問トレントはユーザーレベルのニーズに合わせて調整され、文化レベルは不均一であり、大学生が学校に多く、労働者に多くの仕事があり、さらには教育レベルが低い人もいます。オフなので、ユーザーのさまざまなレベルの違いに適応するために、テキスト情報の表現に特に焦点を当てた教材を作成するときにITIL-4-Foundation試験の質問が行われるため、ITIL-4-Foundation学習ガイドの内容を理解できますITIL-4-Foundation試験に簡単に合格します。
Thank you for your insightful article, it really left a mark. Thanks to the LEED-AP-Homes exam cram review, I received a promotion and raise. Now it’s free for all. Wishing you all a fast climb in your career!
78202Tテスト準備は高品質です。合格率とヒット率は両方とも高いです。合格率は約98%-100%です。試験に合格する可能性が非常に高いことを保証できます。 78202Tガイドトレントは、専門家によって編集され、豊富な経験を持つ専門家によって承認されています。 78202TのMogiExam準備トレントは、高品質の製品であり、精巧にコンパイルされ、以前の試験の論文と業界で人気のある傾向に従って、厳密な分析と要約が行われました。 78202T試験の教材の言語はシンプルで理解しやすいです。
Aufgrund der großen Übereinstimmung mit den echten Amazon SCS-C02 Prüfungsfragen und -antworten (AWS Certified Security - Specialty) können wir Ihnen 100%-Pass-Garantie versprechen. Wir aktualisieren jeden Tag nach den Informationen von Prüfungsabsolventen oder Mitarbeitern aus dem Testcenter unsere Prüfungsfragen und Antworten zu Amazon SCS-C02 Fragenpool (AWS Certified Security - Specialty). Wir extrahieren jeden Tag die Informationen der tatsächlichen Prüfungen und integrieren in unsere Produkte.
I’m stunned by how wonderful your article is, thank you for sharing it! I’m sharing Reliable exam Analytics-Arch-201 questions pdf resources for free. Wishing you all the best!
Thank you for the brilliant share, the article is truly eye-opening! Free access to FCP_FML_AD-7.4 latest exam vce materials—the stepping stone to promotions and salary growth!
