SDIO Interface Voltage
Hi!
I have connected a WiFi module to Core-3308Y using the SDIO interface.
The module itself is detected as SDR50 device:
[ 3.329205] mmc2: new ultra high speed SDR50 SDIO card at address 0001
According to the SDIO standard, SDR50 mode uses 1.8v signaling.
I have looked at the interface levels by scope before and after the WiFi module detection, and in all cases they seem to be 3.3v, not 1.8v.
Which volatge is used by SDIO interface on Core-3308Y? Can it somehow be switched to 1.8v?
BTW The interface seem to work at 3.3v, but I had no chance to test the communication quality yet.
Hello, please check this specification: https://download.t-firefly.com/产品规格文档/核心板/Core-3308Y%20Specification.pdf?v=1696668643
According to RK3308 datasheet, SDIO signals correspond to VCCIO4 domain. Its specified voltage is 1.8v. But it seems that on Core-3308Y VCCIO4 is fed by 3.3v by default.
The question is: could the voltage be somehow switched to 1.8v by software (gpio-regulator in terms of Device Tree)?
BTW the MMC interface has this functionality, as it is described in the module datasheet.
ivan.p Posted at 10/9/2023 07:10
According to RK3308 datasheet, SDIO signals correspond to VCCIO4 domain. Its specified voltage is 1. …
No, you can only turn on or off the I/O via software. Switching SDIO voltage needs to change the hardware.
I’m amazed by this article, thank you for sharing it. The Virginia-Real-Estate-Salesperson latest test guide helped me with a promotion and raise. Now it’s free to everyone. May your career progression be swift!
