Dual Camera RK3568 with linux-5.1 sdk
I Compiled Linux 5.10 fireware
using rk3568-firefly-roc-pc-cam-2ms2m.dtsi.
(i use CAM-2MS2MF Binocular camera module )
but i can’t see camera caputred data,
there are only error debug messages.
please help me.
there is no rk3568-firefly-roc-pc-cam-2ms2m.dtsi, please use rk3568-firefly-roc-pc-se-cam-2ms2m.dtsi.
Thank you for your help.
using rk3568-firefly-roc-pc-se-cam-2ms2m.dtsi then dual cam working.
and now i want use gc5035 cam
like sensor2->csi_dphy2->mipi_csi2->vicap->isp_vir1
i change i2c4 in dts
gc5035: gc5035@3f {
status = “okay”;
compatible = “galaxycore,gc5035”;
reg = <0x3f>;
clocks = <&pmucru CLK_WIFI>;
clock-names = “xvclk”;
power-domains = <&power RK3568_PD_VI>;
pinctrl-names = “default”;
pinctrl-0 = <&refclk_pins>;
reset-gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>;
pwdn-gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>;
firefly,clkout-enabled-index = <1>;
rockchip,camera-module-index = <1>;
rockchip,camera-module-facing = “front”;
rockchip,camera-module-name = “DW-RV5035-V1.0”;
rockchip,camera-module-lens-name = “JZ-7070AS-A3”;
port {
gc5035_out: endpoint {
remote-endpoint = <&mipi_in_gc2053_ir>;
data-lanes = <1 2>;
and my board detect camera.
but when running ‘camera_rkisp_test.sh’
after
‘[ 482.694081] rkisp_hw fdff0000.rkisp: set isp clk = 297000000Hz’
nothing captuer.
do you know what is wrong?
The points mentioned in the article are very useful and have helped me a lot. MB-280 dumps questions provides great materials, and they’re offered at no charge.
Thank you for your article, it was incredibly enlightening. Elevate your IT skills and grab free COBIT-2019 reliable test book. Good luck with everything!
This article is superb, thank you for sharing such a masterpiece. The New PRINCE2Foundation test pdf test papers are now available for free. Wishing you all the best!
I really appreciate your article, it had a profound effect on me. Strengthen your IT skills with free L4M4 reliable test questions pdf. Wishing you the best of luck!
Die Prüfungsunterlagen zur GIAC GCIH Zertifizierungsprüfung von ZertPruefung werden von der Praxis überprüft. Wir können breite Erforschungen sowie Erfahrungen in der realen Welt bieten. Unser ZertPruefung hat mehr als zehnjährige Erfahrungen über Ausbildung, und zwar Fragen und Antworten zur GIAC GCIH Zertifizierungsprüfung. Die Fragenkataloge zur GCIH Zertifizierungsprüfung von ZertPruefung sind die besten Schulungsunterlagen. Wir bieten Ihnen die umfassendesten Zertifizierungsfragen und Antworten und einen einjährigen kostenlosen Update-Service.
Can’t resist liking this great content. Best of luck! Here’s the free Valid 200-201 test dumps sheet material to help you.
Sind Sie mit Ihrer Arbeit zufrieden? Sind Sie damit Zufrieden, was Sie jetzt machen? Wollen Sie Ihre Arbeitsfähigkeit erhöhen? Dann müssen Sie zuerst mehr nützliche Fähigkeiten für Ihre Arbeit beherrschen. Und das wichtigste ist, dass Arbietsgeber wissen, Sie mehr Arbeitsfähigkeiten beherrschen. Dann legen Sie Amazon SCS-C02 Prüfung ab. SCS-C02 Prüfung kann Ihren Wunsch erreichen. Und es macht nichts, wenn Sie die Prüfungsfragen nicht genug kennen, weil Sie die Hilfe und die Vorbereitungswerkzeuge an PrüfungFrage finden können. Die Prüfungsfragen und-antworten können Ihnen helfen, Amazon SCS-C02 Zertifikat zu bekommen.
Your article truly made me think, thank you for the fresh viewpoint. The Valid AIGP test collection free system helped me secure a promotion and raise. Now it’s free for all. Hope your promotion is right around the corner!
Thank you for your article, it was a true eye-opener. Get the free Exam 220-1102 Simulations exam materials now—your key to career advancement and salary increase!
