I can not connect to board
Type: Official Firmware
Filename: no file
Download Address: no file
Log: boot.zip
Hi,
Debug port on AIO-1126-JD4 board is UART, 3.3 Volt.
It is written in Wiki that: Set the baud rate to the 1.5 M !!!
In the attached image, You can see my minicom configs. But I can’t communicate with the boar yet !
I can’t even connect to the board via LAN (SSH, 192.168.22.33).
I don’t know how to find out if it’s Debian on my board or something else.
boot.zip (101 KB)
With USB-to-TTL with CH340 IC, my problem solved.
did you connected with ssh? and how you learn the ip adress of card,?
Your article was truly stunning, thank you for sharing! Best of luck! Here’s the free Latest test L6M3 cram review test content for everyone.
Your article was incredibly refreshing and inspiring, thank you! Here are the free Reliable SAFe-Practitioner real test question questions. Wishing you all the best for your exams!
I’m genuinely grateful for your share, this article is fantastic! Thanks to the Reliable N16291GC10 exam answers exam, I reached a new level in my career. Now I’m sharing it for free with all of you!
This article has helped me understand related concepts better, and I’ve gained a lot. I used the PRINCE2-Agile-Foundation valid study questions to get promoted and get a pay raise. Now it’s free to all. I hope you all get promoted soon!
DumpTOP의 제품을 구매하시면 우리는 일년무료업데이트 서비스를 제공함으로 여러분을 인증시험을 패스하게 도와줍니다. 만약 인증시험내용이 변경이 되면 우리는 바로 여러분들에게 알려드립니다.그리고 최신버전이 있다면 바로 여러분들한테 보내드립니다. DumpTOP는 한번에Cisco 300-745인증시험을 패스를 보장합니다.
