Dear Firefly,
I have a question about the "Firefly Zebra Screen effect on my industrial tablet IPC-M10R800-A3568J. How or where can I deactivate this? The video shows the “Firefly Zebra Screen” effect on the screen of my industrial tablet. See this you Video on my Youtube channel: https://youtube.com/shorts/JEKNYEERp8g
Best regards
Dear Firefly,
I have a question about the Firefly Zebra screen effect on my industrial tablet IPC-M10R800-A3568J. How or where can I deactivate this? The video shows the “Firefly Zebra” effect on the screen of the industrial tablet. See this image
1 Try using the latest firmware on the official website
https://en.t-firefly.com/doc/download/108.html
2 If the latest firmware still has issues, please provide debugging serial port logs
https://wiki.t-firefly.com/en/Core-3568J/debug.html#senial-debug
Have you ever done any other special operations? A normal board shouldn’t be like this? Of course, it cannot be ruled out whether there is any hardware damage
Hello,
The attached file is the dmesg boot log and the serial terminal log. I already used the latest FW image from your download page.-> Ubuntu20.04 2021-11-08
serial_terminal.log.tar.gz (28.4 KB)
dmesg.log.tar.gz (24.1 KB)
It doesn’t matter whether the Android or Linux image is used. The result is the same in both cases. The kernel was compiled from your GitLab repository branch rk356x/firefly. This is currently in the log files. I built the kernel with the configuration from the original FW image and simply removed those stupid overlay FS options. In addition, the rootfs is booted on the built-in SSD. The rootfs also comes from the original FW image. I also fixed the Himax touchscreen driver error in the kernel, which shows up as a keyboard in userspace. This leads to problems with QT 5.15.2 QPA KMS/EVDEV. I saw the report_type property in the rk3568-firefly-aioj-ipc.dts file that supposedly should select the A/B/B_3PA report type, but the driver source does not reflect any changes. So I reworked the entire driver so that the property does what it’s intended to do. The Mali Bifrost/Midgard DDK and the libMali libraries are unchanged.
BTW: ROFL → Ubuntu18.04 2021-12-07
404. Dies ist ein Fehler.
(HTTP Error 404 at Google)
Best Regards
I’m deeply thankful for your article, it really stood out to me. Get access to the New study guide C-ARSUM-2508 questions exam that helped me achieve a promotion and pay raise, now free for everyone today. Best wishes in your professional development!
獲得JN0-224認證已經成為大多數IT員工獲得更好工作的一種選擇,然而,許多考生一直在努力嘗試卻失敗了。如果你選擇使用我們的Juniper JN0-224題庫產品,幫您最大程度保證取得成功。充分利用JN0-224題庫你將得到不一樣的效果,這是一個針對性強,覆蓋面廣,更新快,最完整的學習資料,保證您一次通過JN0-224考試。如果您想要真實的考試模擬,就選擇我們軟件版本的Juniper JN0-224題庫,安裝在電腦上進行模擬,簡單易操作。
