RK-3566-PC EMMC Root Partition gets corrupted frequently
Type: Self-Compiled Firmware
SDK Package Name: ROC-RK3566-PC-MIPI_Rk356x_v1.3.2f_240202.img
Modification Content: no modification
Log: log.zip
At random times, ubuntu 20.04 running on emmc breaks. The /boot partition becomes completely empty and all /usr/bin applications become inaccessible.
For example
root@aquadata:~# ls
-bash: /usr/bin/ls: No such file or directory
Even the basic linux application “ls” cannot be used. After this happens, the device does not boot at all on reboot. The only way to reboot is to use SD-boot or rewrite emmc with RkDevTool. I can’t understand why.
I think it is a power problem or an automatic update problem.
I am using a 5v 2.4A adapter.
I have about 30 RK-3566-PCs and this problem is happening with all of them, no matter if they are Offical Image or Custom Image.
Can you help me with this ?
log.zip (785 Bytes)
There has never been such a situation as you mentioned before
1 Because this situation would not have occurred if EMMC had not been erased, could you recall what special actions were taken before this issue occurred?
2 Provide complete boot logs
3 Provide corresponding version information based on Wikipedia
https://wiki.t-firefly.com/en/Firefly-Linux-Guide/manual_ubuntu.html#display-version-information
Thanks for sharing. The apps really bring better improvements to use.
my honest reaction it’s cool
