Type: Self-Compiled Firmware
SDK Package Name: AIO-RV1126-JD4-BE-45_Debian_v2.2.5e_240204.img
Modification Content: nothing
Last (I used repo init, repo sync - I don't know how to find commit ID)
Log: ZZ.zip
你好,
我有这些包:
AIO-1126-JD4 + DM-M10R800 + OS04A10
板上闪现的图像是Buildroot。 然后我在上面安装了Ubuntu。 根据你的维基百科。
现在我需要一个指南:
如何将 OS04A10 驱动程序添加到我的 Ubuntu 中?
我有AIO-1126-JD4 + DM-M10R800 + OS04A10
我用ubuntu(基于wiki)刷了它。 但我找不到哪个 /dev/videX 与 OS04A10 相关。
你能指导一下吗? 你的 /dev/video 的编号是多少?
ZZ.zip (134 KB)
Hi again,
This commands work fine :
v4l2-ctl -d /dev/v4l-subdev5 --set-ctrl ‘band_stop_filter=1’
v4l2-ctl -d /dev/v4l-subdev5 --set-ctrl ‘band_stop_filter=0’
But I can not get frame from OS04A10 sensor :
v4l2-ctl -d /dev/video5 --stream-mmap --stream-count=1 --stream-to=/home/firefly/out.yuv
Result of above command : rkisp0: check video link or isp input
Please guide me.
nobody here!!!
Should I use media-ctl to config video port?
To add the OS04A10 driver to your Ubuntu, compile the driver from source, install it, and then use ls /dev/video* to check for the corresponding /dev/videoX device. If it’s not recognized, check the kernel logs with dmesg | grep video for errors.
plants vs brainrots
The article is written excellently and has given me a lot of inspiration. I’m sharing the C_S4CFI_2504 latest real exam questions questions that helped me achieve my promotion and raise—get them for free today!
Great content; my like is locked in. The Trustworthy SAA-C03 exam content helped me move forward in my career with a promotion and salary increase. Now, I’m sharing it for free. Wishing you career success!
The writing was absolutely captivating. The Actual GH-100 Test content is highly useful, and it’s offered free of charge.
This is so good, I’m liking it immediately. Thanks to the Portworx-Enterprise-Professional Testking learning materials program, I secured a promotion and salary increase. It’s available for free now. Wishing you all quick promotions!
