Problems building Linux kernel with RT patch PREEMPT_RT
Type: Official Firmware
Filename: rk356x_linux5.10_bsp_release_20240222_v1.4.0b
Download Address: https://drive.google.com/drive/folders/1qPrblHSK9ZAjidzG92no-c4gWp1aJF8m
Log: logs_and_configForKernel.tar.gz
Hello.
When building the Linux kernel with the RT patch PREEMPT_RT 5.10.198, the errors below appear. Please tell me what needs to be done to correct them.
AS .tmp_vmlinux.kallsyms2.S
LD vmlinux
BTFIDS vmlinux
SORTTAB vmlinux
SYSMAP System.map
OBJCOPY arch/arm64/boot/Image
MODPOST modules-only.symvers
LZ4C arch/arm64/boot/Image.lz4
drivers/mmc/core/.mmc_blk_data.cmd: No such file or directory
make[2]: *** [scripts/Makefile.modpost:168: modules-only.symvers] Ошибка 1
make[1]: *** [Makefile:1856: modules] Ошибка 2
make: *** [arch/arm64/Makefile:214: rk3568-firefly-itx-3568q.img] Error 2
make: Leaving directory ‘/home/andy/PROJECTS_RT/rk356x_linux5.10_release/kernel’
ERROR: Running /home/andy/PROJECTS_RT/rk356x_linux5.10_release/device/rockchip/common/build-hooks/10-kernel.sh - run_command failed!
ERROR: exit code 2 from line 36:
ERROR: call stack:
build-helper: run_command(36)
10-kernel.sh: do_build(61)
10-kernel.sh: build_hook(209)
build-helper: try_func(63)
SDK name: rk356x_linux5.10_bsp_release_20240319_v1.4.0b
Configuration kernel in logs_and_configForKernel.tar.gz
The following errors that occurred when building the kernel have been fixed:
ERROR:
security/smack/smack_lsm.c:54:21: warning: ‘smack_ipv6_lock’ defined but not used [-Wunused-variable]
error, forbidden warning:smack_lsm.c:54
54 | static DEFINE_MUTEX(smack_ipv6_lock);
FOR CORRECTION:
#ifdef SMACK_IPV6_PORT_LABELING
#endif
ERROR:
drivers/usb/dwc2/platform.c: In function ‘dwc2_resume’:
drivers/usb/dwc2/platform.c:816:12: error: ‘struct dwc2_hsotg’ has no member named ‘driver’
816 | if (!dwc2->driver)
make[4]: *** [scripts/Makefile.build:273: drivers/usb/dwc2/platform.o] Ошибка 1
make[3]: *** [scripts/Makefile.build:516: drivers/usb/dwc2] Ошибка 2
make[2]: *** [scripts/Makefile.build:516: drivers/usb] Ошибка 2
make[2]: *** Ожидание завершения заданий…
FOR CORRECTION: (file .config)
DesignWare USB2 DRD Core Support
затем выбрать
DWC2 Mode Selection (Dual Role mode) —>
ERROR:
rivers/rpmsg/virtio_rpmsg_bus.c:194:3: error: ‘const struct rpmsg_endpoint_ops’ has no member named ‘get_mtu’
194 | .get_mtu = virtio_rpmsg_get_mtu,
drivers/rpmsg/virtio_rpmsg_bus.c:194:13: error: initialization of ‘__poll_t (*)(struct rpmsg_endpoint *, struct file *, poll_table )’ {aka 'unsigned int ()(struct rpmsg_endpoint *, struct file *, struct poll_table_struct )'} from incompatible pointer type 'ssize_t ()(struct rpmsg_endpoint )’ {aka 'long int ()(struct rpmsg_endpoint *)’} [-Werror=incompatible-pointer-types]
drivers/rpmsg/virtio_rpmsg_bus.c:194:13: note: (near initialization for ‘virtio_endpoint_ops.poll’)
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:273: drivers/rpmsg/virtio_rpmsg_bus.o] Ошибка 1
make[2]: *** [scripts/Makefile.build:516: drivers/rpmsg] Ошибка 2
FOR CORRECTION:
.trysend_offchannel = virtio_rpmsg_trysend_offchannel,
#ifdef CONFIG_NO_GKI
#endif
ERROR:
drivers/rpmsg/virtio_rpmsg_bus.c:712:16: warning: ‘virtio_rpmsg_get_mtu’ defined but not used [-Wunused-function]
error, forbidden warning:virtio_rpmsg_bus.c:712
712 | static ssize_t virtio_rpmsg_get_mtu(struct rpmsg_endpoint *ept)
FOR CORRECTION:
static ssize_t virtio_rpmsg_get_mtu(struct rpmsg_endpoint *ept);
#endif
struct rpmsg_device *rpdev = ept->rpdev;
struct virtio_rpmsg_channel *vch = to_virtio_rpmsg_channel(rpdev);
return vch->vrp->buf_size - sizeof(struct rpmsg_hdr);
#endif
Log_files.tar.gz (67.3 KB)
logs_and_configForKernel.tar.gz (267 KB)
