I made ERASE ALL operation in RKDevTool_Release_v2.81 and after that my RK3568 went into MASKROM mode.
I made all operations under 4.3. Maskrom Mode in this link 4. Switching Upgrade Storage — Firefly Wiki
but writing firmaware in LOADER mode is failed and i got Error:Layer<1-7>:Download Firmware Fail (please see attached log.zip).
How can i write firmware into FLASH memory, not to NOR-FLASH ?
The ERASE ALL procedure seems to have caused a problem! I propose double-checking the instructions in the link to ensure all prerequisites are met because you’re stuck in MASKROM mode and having problems writing firmware in LOADER mode. Try an alternative USB cable or port, as connectivity issues can cause firmware writing failures. If the situation persists, seek community or support for customized assistance. Good luck!
paweja Posted at 11/29/2024 19:21
Good job! The ball rolls at increasing speeds, making each moment more intense than the last slope 3 …
@Subway Surfers Great work! With each passing second, the online experience becomes more thrilling as the ball races forward at ever-increasing speeds.
