rk3588 av1 codec is not activated in Ubuntu
Type: Official Firmware
Filename: itx-3588j_ubuntu20.04-xfce-r3115_v1.0c_240131
Download Address: https://drive.google.com/drive/folders/1tlyMGSqBInwQyWGSXBo6CVWPw7jkJ0sy
Log: test.zip
developing a media player in Ubuntu using ITX-3588J.
The firmware is receiving and using itx-3588j_ubuntu20.04-xfce-r3115_v1.0c_240131.7z.
But the h264 and h265 codecs are hardware-accelerated
Av1 codec is not hardware accelerated.
I would appreciate it if you could tell me how av1 codec is hardware acceleration in qt.
test.zip (930 Bytes)
If your codec is not activated in Ubuntu, you might need comcast customer support billing to install or enable the necessary multimedia packages. Use the terminal to install codecs by running commands like sudo apt install ubuntu-restricted-extras for common codecs. Ensure your system is up to date, and check software settings or repositories if issues persist. Proper installation will enable playback of various media formats.
I deeply appreciate your share, this article is simply astonishing! The CLF-C02 new practice questions content is truly valuable, and it’s free.
最近多くの受験者たちはCertShikenの商品で試験に合格しましたので、我々は我々のNSE7_CDS_AR-7.6問題集を推薦します。我々は信頼できる問題集を開発して、皆様はこのような問題集を利用してFortinetのNSE7_CDS_AR-7.6試験に合格するのは我々の喜びです。我々は引き続き商品の質量のために努力します。
