EDP屏调试遇到问题,大神们帮看下
kernel信息:
DDR Version 1.00 20141007
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-02 (Nov 26 2014 - 09:28:44)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2014-11-26#2.17
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to load fdt from boot!
kernel @ 0x02000000 (0x006505b8)
ramdisk @ 0x04bf0000 (0x00122fc0)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 04809000, end 048267c8 … OK
[ 0.000000] Linux version 3.10.0 (lb@sam) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Mar 10 08:29:35 CST 2016
[ 0.000000] ion heap(cma): base(40000000) size(28000000) align(0)
[ 0.000000] cma: CMA: reserved 640 MiB at 40000000
[ 0.000000] ion_reserve: cma reserved base 40000000 size 671088640
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1dd7000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-11-26_09:28:44 hdmi.vic=-1
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1388504k/1388504k available, 708648k reserved, 663552K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0ade680 (11098 kB)
[ 0.000000] .init : 0xc0adf000 - 0xc0b736c0 ( 594 kB)
[ 0.000000] .data : 0xc0b74000 - 0xc0c7b2f8 (1053 kB)
[ 0.000000] .bss : 0xc0c7b2f8 - 0xc0d997c4 (1146 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rkclk_init_clks: cnt_rate = 31
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:24
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:21
[ 0.305609] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.305624] pid_max: default: 32768 minimum: 301
[ 0.305729] Security Framework initialized
[ 0.305746] SELinux: Initializing.
[ 0.305816] Mount-cache hash table entries: 512
[ 0.306453] Initializing cgroup subsys debug
[ 0.306467] Initializing cgroup subsys memory
[ 0.306494] Initializing cgroup subsys freezer
[ 0.306522] CPU: Testing write buffer coherency: ok
[ 0.306832] /cpus/cpu@0 missing clock-frequency property
[ 0.306845] /cpus/cpu@1 missing clock-frequency property
[ 0.306854] /cpus/cpu@2 missing clock-frequency property
[ 0.306863] /cpus/cpu@3 missing clock-frequency property
[ 0.306920] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.306970] Setting up static identity map for 0xc07def38 - 0xc07def90
[ 0.309385] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x16b6 (version 3.0)
[ 0.383717] CPU1: Booted secondary processor
[ 0.383751] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.403402] CPU2: Booted secondary processor
[ 0.403426] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.423114] CPU3: Booted secondary processor
[ 0.423139] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.423241] Brought up 4 CPUs
[ 0.423269] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.423278] CPU: All CPU(s) started in SVC mode.
[ 0.423996] devtmpfs: initialized
[ 0.428951] pinctrl core: initialized pinctrl subsystem
[ 0.429196] regulator-dummy: no parameters
[ 0.440626] NET: Registered protocol family 16
[ 0.442496] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.442777] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0d74d84 (version 0.1)
[ 0.443069] Registered FIQ tty driver
[ 0.443474] fiq-debugger is disabled in device tree
[ 0.444106] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.444126] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.444143] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.444159] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.444245] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.444309] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.444371] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.444431] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.444498] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.444561] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.444622] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.444681] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.444747] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.444808] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.444821] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.444833] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.444844] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.445347] rockchip_interrupts_register:bank_num=7
[ 0.447255] rockchip_pinctrl_probe:init ok
[ 0.453290] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.453376] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453389] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.453556] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.453628] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453640] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.453796] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.453863] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.453876] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.454035] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.454102] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.454114] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.454273] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.454347] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.454358] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.454517] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.454591] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.454603] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.454765] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.454836] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.454848] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.456473] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.456486] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.456689] DDR DEBUG: version 1.00 20140603
[ 0.456718] DDR DEBUG: Channel a:
[ 0.456726] DDR DEBUG: DDR3 Device
[ 0.456739] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.456748] DDR DEBUG: Channel b:
[ 0.456755] DDR DEBUG: DDR3 Device
[ 0.456767] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.456775] DDR DEBUG: addr=0xc83000
[ 0.456785] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.456794] DDR DEBUG: socAddr[0]=0xc83000, socAddr[1]=0xc83100
[ 0.456803] DDR DEBUG: chAddr[0]=0xc83000, chAddr[1]=0xc83000
[ 0.456814] DDR DEBUG: dtar[0]=0x30190000, dtar[1]=0x30190000
[ 0.457055] DDR DEBUG: init success!!! freq=300MHz
[ 0.457062] DDR DEBUG: Channel a:
[ 0.457074] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457086] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457098] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457110] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457121] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.457131] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.457139] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.457146] DDR DEBUG: Channel b:
[ 0.457157] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457169] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457181] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457193] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
[ 0.457203] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.457212] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.457220] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.479399] bio: create slab at 0
[ 0.480200] SCSI subsystem initialized
[ 0.480344] usbcore: registered new interface driver usbfs
[ 0.480390] usbcore: registered new interface driver hub
[ 0.480469] usbcore: registered new device driver usb
[ 0.481798] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.483929] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.485518] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.486452] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.486687] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.487339] i2c i2c-4: 1 i2c clients have been registered at 0x68
[ 0.487512] media: Linux media interface: v0.10
[ 0.487549] Linux video capture interface: v2.00
[ 0.487596] pps_core: LinuxPPS API ver. 1 registered
[ 0.487605] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.487628] PTP clock support registered
[ 0.488093] Rockchip ion module is successfully loaded (v1.0)
[ 0.488250] Advanced Linux Sound Architecture Driver Initialized.
[ 0.488605] Bluetooth: Core ver 2.16
[ 0.488640] NET: Registered protocol family 31
[ 0.488649] Bluetooth: HCI device and connection manager initialized
[ 0.488664] Bluetooth: HCI socket layer initialized
[ 0.488676] Bluetooth: L2CAP socket layer initialized
[ 0.488716] Bluetooth: SCO socket layer initialized
[ 0.488930] cfg80211: Calling CRDA to update world regulatory domain
[ 0.489633] act8846_i2c_probe,line=898
[ 0.490591] act8846_parse_dt,line=746
[ 0.491277] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.491296] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.491311] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.491325] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.493161] act_dcdc1: 1200 mV
[ 0.495877] vccio: 3300 mV
[ 0.497728] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.500427] act_dcdc4: 2000 mV
[ 0.501667] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.503743] act_ldo2: 1000 mV
[ 0.505810] act_ldo3: 2800 mV
[ 0.507875] act_ldo4: 3300 mV
[ 0.509964] act_ldo5: 3300 mV
[ 0.512051] act_ldo6: 1000 mV
[ 0.514114] vcc_18: 1800 mV
[ 0.516177] act_ldo8: 1800 mV
[ 0.520944] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.525647] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.526453] Switching to clocksource arch_sys_counter
[ 0.546370] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.546382] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.546761] rk-screen rk_screen.8: rockchip screen probe success
[ 0.546914] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.546933] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.547493] rk32-edp rk32-edp: rk32 edp driver probe success
[ 0.548159] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.548463] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.548612] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.548769] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.549339] rk3288-lcdc lcdc0: lcdc0: dclk:147800000>>fps:60
[ 0.549548] rk32-edp rk32-edp: edp pll locked
[ 0.550180] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:2
[ 0.557100] rk32-edp rk32-edp: hw lt err:4
[ 0.557112] rk32-edp rk32-edp: link train failed!
[ 0.578020] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.608613] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.632224] alloc_buffer:ion_phy_addr=0x40000000
[ 0.644085] fb0:phy:40000000>>vir:f0171000>>len:0x1800000
[ 0.651844] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
[ 0.652001] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.652012] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.652229] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.652520] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.652679] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.652830] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.699931] alloc_buffer:ion_phy_addr=0x41800000
[ 0.699947] fb0:phy:41800000>>vir: (null)>>len:0x3000000
[ 0.699962] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
[ 0.700579] rockchip_set_mux:warning ignore bank num 15
[ 0.700704] rockchip_set_mux:warning ignore bank num 15
[ 0.700811] rockchip_set_mux:warning ignore bank num 15
[ 0.700916] rockchip_set_mux:warning ignore bank num 15
[ 0.701023] rockchip_set_mux:warning ignore bank num 15
[ 0.701123] rockchip_set_mux:warning ignore bank num 15
[ 0.701686] rockchip_set_mux:warning ignore bank num 15
[ 0.701826] rockchip_set_mux:warning ignore bank num 15
[ 0.702367] rockchip_set_mux:warning ignore bank num 15
[ 0.702499] rockchip_set_mux:warning ignore bank num 15
[ 0.703044] rockchip_set_mux:warning ignore bank num 15
[ 0.703184] rockchip_set_mux:warning ignore bank num 15
[ 0.703717] rockchip_set_mux:warning ignore bank num 15
[ 0.703861] rockchip_set_mux:warning ignore bank num 15
[ 0.705219] NET: Registered protocol family 2
[ 0.705654] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.705785] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.705919] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.705969] TCP: reno registered
[ 0.705983] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.706016] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.706218] NET: Registered protocol family 1
[ 0.706388] Unpacking initramfs…
[ 0.768661] Freeing initrd memory: 1160K (c4bf0000 - c4d12000)
[ 0.769286] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.769745] probe device ff9a0000.vpu_service
[ 0.769919] vpu_service: power on
[ 0.770973] checking hw id 4831
[ 0.771348] vpu_service set to auto frequency mode
[ 0.771381] vpu_service: power off…
[ 0.771417] done
[ 0.771425] init success
[ 0.771472] probe device ff9c0000.hevc_service
[ 0.771662] hevc_service: power on
[ 0.772695] checking hw id 6867
[ 0.772912] hevc_service: power off…
[ 0.772949] done
[ 0.772956] init success
[ 0.773061] rknandbase v1.0 2014-03-31
[ 0.773166] rknand ff400000.nandc0: no irq resource?
[ 0.773287] rknand_driver:ret = 0
[ 0.774047] audit: initializing netlink socket (disabled)
[ 0.774083] type=2000 audit(0.470:1): initialized
[ 0.774819] bounce pool size: 64 pages
[ 0.779213] fuse init (API version 7.22)
[ 0.779569] msgmni has been set to 1450
[ 0.781307] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.781321] io scheduler noop registered
[ 0.781331] io scheduler deadline registered
[ 0.781419] io scheduler cfq registered (default)
[ 0.784724] rga2 ff920000.rga: rga ion client create success!
[ 0.784865] rga: Driver loaded succesfully
[ 0.785454] IEP Driver loaded succesfully
[ 0.785539] Module initialized.
[ 0.786378] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.786395] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.787649] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.787666] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.788016] vdd_logic: 925 ↔ 1400 mV at 1000 mV
[ 0.788065] vdd_logic: Failed to create debugfs directory
[ 0.788466] rk_serial.c v1.8 2014-03-04
[ 0.788665] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.788852] serial ff180000.serial: membase f1972000
[ 0.788979] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 2.447934] console [ttyS2] enabled
[ 2.451539] serial ff690000.serial: membase fed60000
[ 2.459072] loop: module loaded
[ 2.462724] SCSI Media Changer driver v0.25
[ 2.467265] tun: Universal TUN/TAP device driver, 1.6
[ 2.472234] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.478449] vmac_init.
[ 2.481261] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 2.487953] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 2.494905] stmmac_probe_config_dt: clock input or output? (input).
[ 2.501067] stmmac_probe_config_dt: TX delay(0x30).
[ 2.505873] stmmac_probe_config_dt: RX delay(0x20).
[ 2.510717] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 2.516034] stmmc_pltfr_init:
[ 2.519228] stmmc_pltfr_init: init for RGMII
[ 2.523428] tx delay=0x30
[ 2.523428] rx delay=0x20
[ 2.529020] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.534001] Normal descriptors
[ 2.537082] Ring mode enabled
[ 2.540085] DMA HW capability register supported
[ 2.544562] RX Checksum Offload Engine supported (type 2)
[ 2.550134] TX Checksum insertion supported
[ 2.554340] Wake-Up On Lan supported
[ 2.557967] Enable RX Mitigation via HW Watchdog Timer
[ 2.563521] PPP generic driver version 2.4.2
[ 2.567855] PPP BSD Compression module registered
[ 2.572482] PPP Deflate Compression module registered
[ 2.577484] PPP MPPE Compression module registered
[ 2.582197] NET: Registered protocol family 24
[ 2.586598] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 2.596105] CSLIP: code copyright 1989 Regents of the University of California.
[ 2.603299] Rockchip WiFi SYS interface (V1.00) …
[ 2.608213] esp_mem_init enter date Mar 10 2016 08:29:08
[ 2.613486] esp_mem_init complete
[ 2.616889] usbcore: registered new interface driver catc
[ 2.622224] usbcore: registered new interface driver kaweth
[ 2.627728] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.635038] usbcore: registered new interface driver pegasus
[ 2.640627] usbcore: registered new interface driver rtl8150
[ 2.646243] usbcore: registered new interface driver r8152
[ 2.651636] hso: drivers/net/usb/hso.c: Option Wireless
[ 2.656846] usbcore: registered new interface driver hso
[ 2.662129] usbcore: registered new interface driver asix
[ 2.667467] usbcore: registered new interface driver ax88179_178a
[ 2.673498] usbcore: registered new interface driver cdc_ether
[ 2.679271] usbcore: registered new interface driver cdc_eem
[ 2.684873] usbcore: registered new interface driver dm9601
[ 2.690378] usbcore: registered new interface driver dm9620
[ 2.695920] usbcore: registered new interface driver smsc75xx
[ 2.701619] usbcore: registered new interface driver smsc95xx
[ 2.707304] usbcore: registered new interface driver gl620a
[ 2.712832] usbcore: registered new interface driver net1080
[ 2.718422] usbcore: registered new interface driver plusb
[ 2.723867] usbcore: registered new interface driver rndis_host
[ 2.729729] usbcore: registered new interface driver cdc_subset
[ 2.735592] usbcore: registered new interface driver zaurus
[ 2.741124] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.748437] usbcore: registered new interface driver int51x1
[ 2.754042] usbcore: registered new interface driver kalmia
[ 2.759563] usbcore: registered new interface driver ipheth
[ 2.765085] usbcore: registered new interface driver sierra_net
[ 2.770950] usbcore: registered new interface driver cx82310_eth
[ 2.776904] usbcore: registered new interface driver cdc_ncm
[ 2.782512] usbcore: registered new interface driver qmi_wwan
[ 2.788189] usbcore: registered new interface driver cdc_mbim
[ 2.793859] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.802645] ehci_rk_probe f1a00000 f1a00010
[ 2.806780] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 2.814251] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 2.822690] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 2.848754] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 2.855319] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.862022] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.869133] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 2.875390] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 2.880712] usb usb1: SerialNumber: ff500000.usb
[ 2.885654] hub 1-0:1.0: USB hub found
[ 2.889381] hub 1-0:1.0: 1 port detected
[ 2.917632] ehci_rk_probe ok
[ 2.920601] usbcore: registered new interface driver cdc_acm
[ 2.926180] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.934110] usbcore: registered new interface driver usblp
[ 2.939567] usbcore: registered new interface driver cdc_wdm
[ 2.945180] usbcore: registered new interface driver usb-storage
[ 2.951128] usbcore: registered new interface driver ums-alauda
[ 2.957000] usbcore: registered new interface driver ums-cypress
[ 2.962942] usbcore: registered new interface driver ums-datafab
[ 2.968886] usbcore: registered new interface driver ums_eneub6250
[ 2.974999] usbcore: registered new interface driver ums-freecom
[ 2.980949] usbcore: registered new interface driver ums-isd200
[ 2.986848] usbcore: registered new interface driver ums-jumpshot
[ 2.992885] usbcore: registered new interface driver ums-karma
[ 2.998663] usbcore: registered new interface driver ums-onetouch
[ 3.004692] usbcore: registered new interface driver ums-sddr09
[ 3.010553] usbcore: registered new interface driver ums-sddr55
[ 3.016411] usbcore: registered new interface driver ums-usbat
[ 3.022230] usbcore: registered new interface driver usbserial
[ 3.028008] usbcore: registered new interface driver usbserial_generic
[ 3.034444] usbserial: USB Serial support registered for generic
[ 3.040407] usbcore: registered new interface driver option
[ 3.045917] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.052817] usbcore: registered new interface driver trancevibrator
[ 3.059005] usb20_otg: version 3.10a 21-DEC-2012
[ 3.063905] f1a80040
[ 3.066073] Core Release: 3.10a
[ 3.069165] Setting default values for core params
[ 3.073989] Using Buffer DMA mode
[ 3.077264] Periodic Transfer Interrupt Enhancement - disabled
[ 3.082997] Multiprocessor Interrupt Enhancement - disabled
[ 3.088496] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.092780] ^^^^^^^^^^^^^^^^^Device Mode
[ 3.096648] Dedicated Tx FIFOs mode
[ 3.100087] pcd_init otg_dev = ed5da640
[ 3.103995] usb20_otg ff580000.usb: DWC OTG Controller
[ 3.109077] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.116461] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 3.122170] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.128859] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.135971] usb usb2: Product: DWC OTG Controller
[ 3.140607] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.146182] usb usb2: SerialNumber: ff580000.usb
[ 3.151063] hub 2-0:1.0: USB hub found
[ 3.154791] hub 2-0:1.0: 1 port detected
[ 3.158932] usb20_host: version 3.10a 21-DEC-2012
[ 3.166020] f1b00040
[ 3.168175] Core Release: 3.10a
[ 3.171278] Setting default values for core params
[ 3.176089] Using Buffer DMA mode
[ 3.179351] Periodic Transfer Interrupt Enhancement - disabled
[ 3.185097] Multiprocessor Interrupt Enhancement - disabled
[ 3.190586] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.194879] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.198668] usb20_host ff540000.usb: DWC OTG Controller
[ 3.203840] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 3.211297] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 3.217121] Init: Power Port (0)
[ 3.220349] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.227036] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.234154] usb usb3: Product: DWC OTG Controller
[ 3.238792] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.244369] usb usb3: SerialNumber: ff540000.usb
[ 3.249249] hub 3-0:1.0: USB hub found
[ 3.253011] hub 3-0:1.0: 1 port detected
[ 3.257368] .. rk pwm remotectl v1.0 init
[ 3.261381] remotectl probe j=0x0
[ 3.264795] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 3.271298] pwm enable val=0x646205
[ 3.275078] usbcore: registered new interface driver xpad
[ 3.280427] usbcore: registered new interface driver usb_acecad
[ 3.286310] usbcore: registered new interface driver aiptek
[ 3.291836] usbcore: registered new interface driver gtco
[ 3.297177] usbcore: registered new interface driver hanwang
[ 3.302827] usbcore: registered new interface driver kbtab
[ 3.308265] usbcore: registered new interface driver wacom
[ 3.334636] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 1
[ 3.371211] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 2
[ 3.400724] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 3
[ 3.430245] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 4
[ 3.459764] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 5
[ 3.489288] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 6
[ 3.518808] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 7
[ 3.548332] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 8
[ 3.577851] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 9
[ 3.607367] synaptics_dsx_i2c 1-0020: synaptics_rmi4_i2c_set_page: I2C retry 10
[ 3.635953] synaptics_dsx_i2c 1-0020: synaptics_rmi4_set_input_dev: Failed to query device
[ 3.644083] synaptics_dsx synaptics_dsx.0: synaptics_rmi4_probe: Failed to set up input device
[ 3.652578] synaptics_dsx: probe of synaptics_dsx.0 failed with error -5
[ 3.661684] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 3.672026] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 3.678342] i2c /dev entries driver
[ 3.682467] IR NEC protocol handler initialized
[ 3.686941] IR RC5(x) protocol handler initialized
[ 3.691651] IR RC6 protocol handler initialized
[ 3.696117] IR JVC protocol handler initialized
[ 3.700579] IR Sony protocol handler initialized
[ 3.705129] IR RC5 (streamzap) protocol handler initialized
[ 3.710606] IR SANYO protocol handler initialized
[ 3.715247] IR MCE Keyboard/mouse protocol handler initialized
[ 3.721114] usbcore: registered new interface driver uvcvideo
[ 3.726776] USB Video Class driver (1.1.1)
[ 3.730819] CamSys driver version: v0.23.0, CamSys head file version: v0.9.0
[ 3.739164] D1:camsys_platform_probe(1067): 1-gpios-cifpower锛gpio=236
[ 3.745795] D1:camsys_platform_probe(1070): gpios-cifpower锛gpio_request
[ 3.752559] D1:camsys_platform_probe(1072): 1-gpios-cifpower锛gpio_request=0
[ 3.759674] D1:camsys_platform_probe(1079): gpios-cifpower锛236 high
[ 3.766177] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 3.776998] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf19b0000 size: 0x4000)
[ 3.789749] D1:camsys_platform_probe(1183): ff910000.isp memory:
[ 3.795690] D1:camsys_platform_probe(1193): Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000)
[ 3.805618] D1:camsys_platform_probe(1188): I2c memory (phy: 0x2d64e000 vir: 0xed64e000 size: 0x1000)
[ 3.815039] D1:camsys_platform_probe(1208): Probe ff910000.isp device success
[ 3.823331] rockchip_temp_probe,line=362
[ 3.881949] tsadc ff280000.tsadc: initialized
[ 3.886585] device-mapper: uevent: version 1.0.3
[ 3.891343] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 3.899926] Bluetooth: HCI UART driver ver 2.2
[ 3.904314] Bluetooth: HCI H4 protocol initialized
[ 3.909025] Bluetooth: HCILL protocol initialized
[ 3.916207] cpufreq version 1.0, suspend freq 1200 MHz
[ 3.921438] cpuidle: using governor ladder
[ 3.925469] cpuidle: using governor menu
[ 3.929363] Synopsys Designware Multimedia Card Interface Driver
[ 3.935510] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 3.941623] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 3.948616] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 3.955055] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 3.960947] 1390..dw_mci_set_ios: no card. [mmc0]
[ 3.980361] 1390..dw_mci_set_ios: no card. [mmc0]
[ 4.000079] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 4.000100] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 4.000143] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 4.000820] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 4.030902] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 4.037941] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
[ 4.044343] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.050201] mmc1: no vmmc regulator found
[ 4.054306] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 4.061129] 1390..dw_mci_set_ios: no card. [mmc1]
[ 4.078755] 1390..dw_mci_set_ios: no card. [mmc1]
[ 4.083492] mmc0: BKOPS_EN bit is not set
[ 4.089352] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
[ 4.099060] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 4.099140] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 4.099150] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 4.099489] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 4.129189] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
[ 4.129217] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 4.129384] 3379..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 4.129391] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.129722] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.147641] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.164043] mmc0: new high speed MMC card at address 0001
[ 4.169428] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 4.169609] mmcblk0: mmc0:0001 AGND3R 14.5 GiB
[ 4.169863] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 4.169870] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 4.169875] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 4.169880] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 4.169885] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 4.169890] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 4.169895] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 4.169900] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 4.169904] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 4.169909] system: 0x012400000 – 0x042400000 (768 MB)
[ 4.169914] metadata: 0x042400000 – 0x042800000 (4 MB)
[ 4.169918] userdata: 0x042800000 – 0x082800000 (1024 MB)
[ 4.169923] radical_update: 0x082800000 – 0x086800000 (64 MB)
[ 4.169928] user: 0x086800000 – 0x3a3a00000 (12754 MB)
[ 4.171171] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141390..dw_mci_set_ios: no card. [mmc1]
[ 4.172164] 1390..dw_mci_set_ios: no card. [mmc2]
[ 4.273967] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 4.280078] leds-gpio leds.32: pins are not configured from the driver
[ 4.286673] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.293061] usbcore: registered new interface driver usbhid
[ 4.298544] usbhid: USB HID core driver
[ 4.302533] zram: Created 1 device(s) …
[ 4.306697] ashmem: initialized
[ 4.309857] logger: created 256K log ‘log_main’
[ 4.314382] logger: created 256K log ‘log_events’
[ 4.319077] logger: created 256K log ‘log_radio’
[ 4.323676] logger: created 256K log ‘log_system’
[ 4.329173] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input1
[ 4.336711] es8323 probe i2c recv ok
[ 4.340398] i2c-core: driver [ES8323] using legacy suspend method
[ 4.346403] i2c-core: driver [ES8323] using legacy resume method
[ 4.352945] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[ 4.361242] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 4.367779] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[ 4.376660] es8323_probe
[ 5.014942] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 5.022739] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 5.030676] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 5.039048] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 5.046777] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 5.054962] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 5.063112] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 5.070915] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 5.078786] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 5.086657] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 5.094526] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 5.102903] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 5.111257] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 5.119211] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 5.126841] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 5.134499] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 5.142127] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 5.150520] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 5.158960] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 5.166718] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 5.174476] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 5.182233] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 5.189972] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 5.198721] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 5.207194] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 5.215171] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 5.223135] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 5.231120] dwc_otg_hcd_enable, enable host controller
[ 5.239871] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 5.247826] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 5.255806] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 5.263766] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 5.271727] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 5.279698] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 5.287392] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 5.295098] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 5.302797] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 5.310503] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 5.318626] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 5.326746] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 5.334541] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 5.339558] Using Buffer DMA mode
[ 5.339563] Periodic Transfer Interrupt Enhancement - disabled
[ 5.339565] Multiprocessor Interrupt Enhancement - disabled
[ 5.339569] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 5.339572] ^^^^^^^^^^^^^^^^^^Host Mode
[ 5.364825] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 5.372609] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 5.380397] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 5.387540] Init: Power Port (0)
[ 5.391856] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 5.400351] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 5.406255] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 5.412080] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 5.417904] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 5.423660] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 5.433002] rockchip-es8323 rockchip-es8323.29: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
[ 5.441436] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.29/sound/card0/input2
[ 5.450473] rockchip-hdmi-i2s rockchip-hdmi-i2s.26: rk-hdmi-i2s-hifi ↔ rockchip-i2s.0 mapping ok
[ 5.459688] u32 classifier
[ 5.462348] Actions configured
[ 5.465691] Netfilter messages via NETLINK v0.30.
[ 5.470396] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.476633] ctnetlink v0.93: registering with nfnetlink.
[ 5.481900] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.488749] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.494667] xt_time: kernel timezone is -0000
[ 5.499103] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.504409] arp_tables: (C) 2002 David S. Miller
[ 5.508977] TCP: cubic registered
[ 5.512233] Initializing XFRM netlink socket
[ 5.516597] NET: Registered protocol family 10
[ 5.521344] mip6: Mobile IPv6
[ 5.524273] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.529677] sit: IPv6 over IPv4 tunneling driver
[ 5.534451] NET: Registered protocol family 17
[ 5.538841] NET: Registered protocol family 15
[ 5.543239] Bridge firewalling registered
[ 5.547187] Ebtables v2.0 registered
[ 5.550821] Bluetooth: RFCOMM TTY layer initialized
[ 5.555634] Bluetooth: RFCOMM socket layer initialized
[ 5.560681] Bluetooth: RFCOMM ver 1.11
[ 5.564364] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.569589] Bluetooth: BNEP filters: protocol multicast
[ 5.574730] Bluetooth: BNEP socket layer initialized
[ 5.579606] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.585428] Bluetooth: HIDP socket layer initialized
[ 5.590316] l2tp_core: L2TP core driver, V2.0
[ 5.594606] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 5.599312] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 5.604069] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 5.608777] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 5.615623] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 5.622633] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 5.631010] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 5.638289] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 5.647273] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 5.656332] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 5.661477] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 5.669800] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 5.674458] [BT_RFKILL]: Enter rfkill_rk_init
[ 5.678842] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 5.682682] Indeed it is in host mode hprt0 = 00021501
[ 5.691932] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 5.699888] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 5.707844] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 5.715713] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 5.723952] [BT_RFKILL]: Request irq for bt wakeup host
[ 5.729150] [BT_RFKILL]: ** disable irq
[ 5.732981] [BT_RFKILL]: ap6335 device registered.
[ 5.738492] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 5.745118] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 5.752671] rk3288_init_suspend
[ 5.755759] rk3288_suspend_init enter
[ 5.759467] rk3288_suspend_init: pm_ctrbits =200007
[ 5.764294] gpio_get_dts_info suspend:4
[ 5.768061] gpio_get_dts_info resume:4
[ 5.771759] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 5.779842] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 5.787852] clks_gating_suspend_init:clkgt info ok
[ 5.792649] Registering SWP/SWPB emulation handler
[ 5.797646] ddrfreq: verion 1.2 20140526
[ 5.801522] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
[ 5.812562] ddrfreq: auto-freq=0
[ 5.815733] ddrfreq: auto-freq-table[0] 240MHz
[ 5.820105] ddrfreq: auto-freq-table[1] 324MHz
[ 5.824475] ddrfreq: auto-freq-table[2] 396MHz
[ 5.828838] ddrfreq: auto-freq-table[3] 528MHz
[ 5.838662] regulator-dummy: disabling
[ 5.842657] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
[ 5.850898] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 5.857401] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
[ 5.859807] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 5.859871] Indeed it is in host mode hprt0 = 00001101
[ 5.877669] pcd_pullup, is_on 0
[ 5.880807] file system registered
[ 5.884607] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 5.891369] android_usb gadget: Number of LUNs=2
[ 5.895905] lun0: LUN: removable file: (no medium)
[ 5.900704] lun1: LUN: removable file: (no medium)
[ 5.905608] android_usb gadget: android_usb ready
[ 5.910765] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:02 UTC (1293883202)
[ 5.923441] rk_spdif:rk_spdif_init
[ 5.926939] rk_spdif:Entered spdif_probe
[ 5.930979] rk_spdif:spdif:spdif probe ok!
[ 5.935481] usbcore: registered new interface driver snd-usb-audio
[ 5.941567] ALSA device list:
[ 5.944499] #0: RK_ES8323
[ 5.947255] #1: RK-HDMI-I2S
[ 5.947351] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
[ 5.959576] #2: RK-HDMI-SPDIF
[ 5.962992] Freeing unused kernel memory: 592K (c0adf000 - c0b73000)
[ 5.973528] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 5.981501] SELinux: the above unknown classes and permissions will be denied
[ 6.056934] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 6.063527] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.070571] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 6.075480] hub 3-1:1.0: USB hub found
[ 6.079268] hub 3-1:1.0: 4 ports detected
[ 6.158744] type=1403 audit(1293883202.740:2): policy loaded auid=4294967295 ses=4294967295
[ 6.167091] SELinux: Loaded policy from /sepolicy
[ 6.173582] type=1404 audit(1293883202.760:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 7.100830] init: could not import file ‘/init.usbstorage.rc’ from ‘/init.rc’
[ 7.107893] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 7.176734] init: /dev/hw_random not found
[ 7.180849] keychord: using input dev ff680000.pwm for fevent
[ 7.186495] keychord: using input dev rk29-keypad for fevent
[ 7.197993] fs_mgr: parse_link_device : path = NULL
[ 7.202826] fs_mgr: parse_link_device : path = NULL
[ 7.207634] fs_mgr: parse_link_device : path = NULL
[ 7.212500] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 7.231716] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
[ 7.249628] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 7.266037] EXT4-fs (mmcblk0p8): recovery complete
[ 7.271131] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.282213] EXT4-fs (mmcblk0p11): recovery complete
[ 7.287029] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.425006] EXT4-fs (mmcblk0p12): 2 orphan inodes deleted
[ 7.430312] EXT4-fs (mmcblk0p12): recovery complete
[ 7.439392] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.464870] mali pd enabled
[ 7.467625] clk enabled
[ 7.471185] MALI_DVFS_STEP=5,div_dvfs=7
[ 7.474976] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
[ 7.481991] mali_dvfs_infotbl[1].clock=179000,min_threshold=66,max_threshold=77
[ 7.489210] mali_dvfs_infotbl[2].clock=297000,min_threshold=73,max_threshold=84
[ 7.496406] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
[ 7.503634] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
[ 7.511035] turn on mali power
[ 7.514059] kbase_platform_rk_init,register_reboot_notifier
[ 7.519565] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 7.526413] mali ffa30000.gpu: Probed as mali0
[ 7.533508] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 7.554104] init: /dev/hw_random not found
[ 7.565716] binder: 164:164 transaction failed 29189, size 0-0
[ 7.566902] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
[ 7.569365] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
[ 7.573439] init: cannot find ‘/system/etc/install-recovery.sh’, disaling ‘flash_recovery’
[ 7.574865] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
[ 7.575797] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 7.575808] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 7.575983] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 7.759762] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
[ 7.767841] init: powerctl: cannot expand ‘${sys.powerctl}’
[ 7.773528] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
[ 7.784394] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
[ 7.794851] init: property ‘sys.sysctl.tcp_def_init_rwnd’ doesn’t exist while expanding ‘${sys.sysctl.tcp_def_init_rwnd}’
[ 7.805706] init: cannot expand ‘${sys.sysctl.tcp_def_init_rwnd}’ while writing to ‘/proc/sys/net/ipv4/tcp_default_init_rwnd’
[ 7.817667] android_usb: already disabled
[ 7.823719] read descriptors
[ 7.826561] read strings
[ 7.829113] pcd_pullup, is_on 1
shell@rk3288:/ $ [ 7.924755] fs_mgr: parse_link_device : path = NULL
[ 7.929617] fs_mgr: parse_link_device : path = NULL
[ 7.934448] fs_mgr: parse_link_device : path = NULL
[ 8.809778] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 8.817156] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 8.824537] D1:camsys_open(717): camsys_marvin(ed571d10) is opened!
[ 8.830765] rockchip_gpio_request:GPIO7-13
[ 8.834813] rockchip_gpio_set:GPIO7-13 level = 1
[ 8.839366] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 8.845216] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 8.851910] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
[ 8.862444] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 8.869225] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
[ 8.903202] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 8.911201] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 8.916195] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 8.921139] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 8.930421] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 8.938762] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 8.947029] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 8.957492] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 8.963829] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 8.971069] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 8.978280] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.002165] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.008827] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.017634] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.026035] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.034285] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.041778] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.049267] D1:camsys_release(741): camsys_marvin(ed571d10) is closed
[ 9.065261] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.072654] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.080038] D1:camsys_open(717): camsys_marvin(ed571d10) is opened!
[ 9.086270] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.090844] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.096667] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.103361] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
[ 9.113900] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.120687] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
[ 9.151932] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.159917] rk3288-lcdc lcdc0: blank mode:0
[ 9.159951] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.160055] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.160087] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.161162] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.162217] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.163278] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.166541] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.167765] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 9.167809] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.167815] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.167820] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.251010] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.257657] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.266513] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.271428] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
[ 9.282095] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.290352] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.297819] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.305286] D1:camsys_release(741): camsys_marvin(ed571d10) is closed
[ 9.314396] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.321759] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.329164] D1:camsys_open(717): camsys_marvin(ed571d10) is opened!
[ 9.335402] D1:camsys_extdev_register(230): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.345362] D1:camsys_extdev_register(230): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.355315] D1:camsys_extdev_register(230): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 9.365292] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.369832] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.375727] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.382431] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
[ 9.392991] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.399786] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 9.430969] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.438951] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.443950] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.448858] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.458190] D1:camsys_sysctl_extdev(335): Sysctl 11 success, gpio(11) set 1
[ 9.466110] D1:camsys_sysctl_extdev(339): Sysctl 8 success, gpio(79) set 1
[ 9.473947] D1:camsys_sysctl_extdev(339): Sysctl 7 success, gpio(78) set 1
[ 9.483953] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 9.491445] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 9.497771] D1:camsys_sysctl_extdev(335): Sysctl 7 success, gpio(78) set 0
[ 9.504567] D1:camsys_sysctl_extdev(335): Sysctl 8 success, gpio(79) set 0
[ 9.511380] D1:camsys_sysctl_extdev(339): Sysctl 11 success, gpio(11) set 0
[ 9.546448] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.553110] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.561957] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
[ 9.570357] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.578570] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.586033] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.593486] D1:camsys_release(741): camsys_marvin(ed571d10) is closed
[ 9.605696] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.613087] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.620465] D1:camsys_open(717): camsys_marvin(ed571d10) is opened!
[ 9.626665] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 9.633641] D1:camsys_extdev_register(255): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
[ 9.661929] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.669911] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 9.674891] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 9.679807] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 9.689095] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.697408] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.705651] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.716115] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 9.722459] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
[ 9.729686] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
[ 9.736914] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
[ 9.760877] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 9.767512] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 9.776329] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x1000000) is deregister success
[ 9.784716] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
[ 9.792957] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.800430] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 9.807884] D1:camsys_release(741): camsys_marvin(ed571d10) is closed
[ 10.558471] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
[ 10.976621] vbus detect**
[ 11.155872] Using Buffer DMA mode
[ 11.159159] Periodic Transfer Interrupt Enhancement - disabled
[ 11.164930] Multiprocessor Interrupt Enhancement - disabled
[ 11.170427] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 11.174794] ^^^^^^^^^^^^^^^^^Device Mode
[ 11.178732] soft connect!!!
[ 11.285250] USB RESET
[ 11.440868] android_work: sent uevent USB_STATE=CONNECTED
[ 11.446212] USB RESET
[ 11.712667] android_usb gadget: high-speed config #1: android
[ 11.718476] android_work: sent uevent USB_STATE=CONFIGURED
[ 12.342118] es8323_mic_state_ctrl read: 0
[ 12.346090] mic_state_switch 0
[ 12.349117] hp_det = 0,insert hp
[ 12.352304] hp mic use intern
[ 16.432744] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
[ 16.542017] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 16.549066] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 16.554372] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 16.559798] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 16.565273] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 16.570759] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 16.576248] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 16.823209] phy_power_on: enable = 1
[ 16.866204] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 16.872560] eth0: device MAC address 2e:da:de:df:aa:dd
[ 16.881693] libphy: stmmac: probed
[ 16.885043] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 16.891042] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 17.004843] wifi_driver_write: wifi driver already rmmod
[ 17.040704] acc_open
[ 17.042875] acc_release
[ 17.681909] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 17.713905] avc: denied { set } for property=sys.vold.hasAsec scontext=u:r:vold:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service
[ 17.726706] init: sys_prop: permission denied uid:0 name:sys.vold.hasAsec
[ 17.733859] init: no such service ‘fuse_internal_sd’
[ 18.628984] init: sys_prop: permission denied uid:10037 name:sys.gmali.version
[ 19.470949] init: sys_prop: permission denied uid:10012 name:sys.gmali.version
[ 20.648281] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 20.737990] f26c5234,f26c5234,f26c5234
现在黑屏,背光已经亮了
检查下硬件
谢谢!查了硬件,LANE0_N和LANE0_P接短路了,现在有图像出来了
